Disable Use of Switch or Group  [Solved]
Re: Disable Use of Switch or Group
djdevil wrote: Monday 05 August 2019 23:05 The name of switch is "Presenza"
It looks like the script is not triggered.
So please answer these questions:
  • which version are you on (domoticz and dzVents (look an the about page))
  • did you change the name in the script to reflect the name of your device, like below ?
  • is the script saved as dzVents and as 'On'
-- Secure devices using protect API
-- Add device IDX to protect to deviceList table
return
    on =
    { devices = { 'Presenza' }}, -- !! change to the name of your switch !!
    logging =
        level = domoticz.LOG_DEBUG,    -- Set to error when script is OK
        marker = 'Secure trigger2'
    execute = function(dz, item)
        local deviceList = {    35,  -- !! Replace /  Add your device IDX numbers here !!
                                2228,
                                2277,
        local protectMe = not(item.active)
        local function protect(idx)
            local url = dz.settings['Domoticz url'] ..  '/json.htm?type=setused&used=true' ..
                                                        '&protected=' .. tostring(protectMe) ..
                                                        '&idx=' .. idx
            dz.openURL(url)
        for _, idx in ipairs(deviceList)  do
            protect(idx)
djdevil
Domoticz version: 2021.1
Post by djdevil »
I'm really stupid 😅 I didn't change the name of the switch! now it works perfectly thank you very much, the only thing I tried to protect a scene but it doesn't work you need to add something to the code? thank you so much
djdevil wrote: Tuesday 06 August 2019 8:25 I'm really stupid 😅 I didn't change the name of the switch! now it works perfectly thank you very much, the only thing I tried to protect a scene but it doesn't work you need to add something to the code? thank you so much
Good that it works now.
I asked for your version but have not received an answer. In the most recent version of dzVents (2.4.27) the methods protectionOn() and protectionOff() are natively available for devices, scenes and groups.
for now you can use this.
-- Secure devices, groups, scenes using protect API
-- Add IDX to protect to protectList table
return
    on =
    logging =
        local protectList = {   [35]    = 'device',  -- !! Replace /  Add your device, group , scene IDX numbers here !!
                                [2228]  = 'device',  -- !! and enter to right type (device, scene or group )
                                [44]    = 'group',
                                [43]    = 'scene',
        local function protect(idx, protectItem)
            local url, sceneType, protectItemObject
            if protectItem ~= 'device' then
                if protectItem == 'group' then
                    sceneType = 1
                    protectItemObject = dz.groups(idx)
                elseif protectItem == 'scene' then
                    sceneType = 0
                    protectItemObject = dz.scenes(idx)
                    dz.log('Wrong protectItem. Must be device, scene or group) not: ' .. tostring(protectItem), dz.LOG_ERROR )
                    return
                url = dz.settings['Domoticz url'] .. '/json.htm?type=updatescene&scenetype=' .. sceneType ..
                        '&idx=' .. idx ..
                        '&name='.. dz.utils.urlEncode(protectItemObject.name) ..
                        '&description=' .. dz.utils.urlEncode(protectItemObject.description)
            elseif protectItem == 'device' then
                      '&idx=' .. idx
            dz.openURL(url)
        for idx, protectItem in pairs(protectList)  do
waaren wrote: Tuesday 06 August 2019 9:46
for now you can use this. (untested so please make sure you have a backup of your database)
return
    on =
    logging =
                                [44]    = 'group',
                                [43]    = 'scene',
                    sceneType = 1
                    sceneType = 0
                    return
                        '&idx=' .. idx ..
                      '&idx=' .. idx
            dz.openURL(url)
djdevil
Post by djdevil »
Thx for reply i have this version
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.4.4 (default, Apr 17 2016, 16:02:33) [GCC 5.3.1 20160409]
how can I upgrade to the latest version?
djdevil
Re: Disable Use of Switch or Group  [Solved]
Post by djdevil »
I tried the code and it works perfectly 8-) :) I don't know how to thank you I hope it can be of help also to the other users with the same need
djdevil wrote: Tuesday 06 August 2019 10:15 how can I upgrade to the latest version?
You are on the latest stable version. If you have a need for a bugfix or function that is only available in a Beta version then you can switch to the Beta channel.
[settings][system] and choose Check for updates (Beta) under Software updates.
If everything is working and without bugs for your environment it is probably better to stay on the stable branch.
djdevil
Post by djdevil »
hello the script not work anymore after i change switch with other dummy virtual switcher this is debug
2019-08-06 23:30:30.874 Status: dzVents: Debug: Processing device-adapter for Presenza: Switch device adapter
2019-08-06 23:30:30.875 Status: dzVents: Debug: - Device: Presenza
2019-08-06 23:30:30.909 Status: dzVents: Info: Handling events for: "Presenza", value: "On"
2019-08-06 23:30:30.909 Status: dzVents: Info: Secure trigger2: ------ Start internal script: Script #2: Device: "Presenza (Posizione)", Index: 273
djdevil wrote: Tuesday 06 August 2019 23:31 hello the script not work anymore after i change switch with other dummy virtual switcher this is debug
Please share your script as it is now and the complete log. If there is a Start of the script there should also be an End or an Error.
djdevil
Post by djdevil »
return
    on =
    logging =
        local protectList = {   [42]    = 'Living 2',
                                         [2]    = 'Tapparelle', -- !! Replace /  Add your device, group , scene IDX numbers here !!
                    sceneType = 1
                    sceneType = 0
                    return
                        '&idx=' .. idx ..
                      '&idx=' .. idx
            dz.openURL(url)
2019-08-07 00:24:04.519 Status: dzVents: Debug: Processing device-adapter for Presenza: Switch device adapter
2019-08-07 00:24:04.520 Status: dzVents: Debug: dzVents version: 2.4.19
2019-08-07 00:24:04.520 Status: dzVents: Debug: Event triggers:
2019-08-07 00:24:04.520 Status: dzVents: Debug: - Device: Presenza
2019-08-07 00:24:04.587 Status: dzVents: Info: Handling events for: "Presenza", value: "Off"
2019-08-07 00:24:04.587 Status: dzVents: Info: Secure trigger2: ------ Start internal script: Script #2: Device: "Presenza (Posizione)", Index: 273
2019-08-07 00:24:04.587 Status: dzVents: Error (2.4.19): Secure trigger2: Wrong protectItem. Must be device, scene or group) not: Living 2
2019-08-07 00:24:04.587 Status: dzVents: Error (2.4.19): Secure trigger2: Wrong protectItem. Must be device, scene or group) not: Tapparelle
2019-08-07 00:24:04.587 Status: dzVents: Info: Secure trigger2: ------ Finished Script #2
Living 2 is a blind
Tapparalle is a group
djdevil wrote: Wednesday 07 August 2019 0:25 Living 2 is a blind
You should not give the name but the baseType (device, group or scene)
Try this.
return
    on =
    logging =
        local protectList = {   [42]    = 'device',
                                 [2]    = 'group', -- !! Replace /  Add your device, group , scene IDX numbers here !!
                    sceneType = 1
                    sceneType = 0
                    return
                        '&idx=' .. idx ..
                      '&idx=' .. idx
            dz.openURL(url)
djdevil
Post by djdevil »
now it works perfectly thank you very much for the time you gave me to solve the problem :)
Users browsing this forum: RonkA and 1 guest
