Python Plugin - Deal with cookies?
sincze
Domoticz version: 2024.4
Post by sincze »
After creating https://github.com/sincze/Domoticz-Omni ... Web-Plugin I was inspired to see if I could build some more. :lol:
Everything I use is currently running with Pass2PHP, so it is just a plugin contributing thing to spend time on and learn something (python).
In the new cases I need to store a cookie, that should be included with the future web-requests.
My first web style plugin used the example http.py however I can't determine if this can deal with cookies as well or if I should change to things I found in the Spotify plugin and use:
import urllib.request
import urllib.error
import urllib.parse
import base64
import json
import time
I scanned all the plugins https://www.domoticz.com/wiki/Plugins, but still not sure what would be the best way to continue.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Delta78
Re: Python Plugin - Deal with cookies?
Post by Delta78 »
It's something "easy".
When you receive a response to a request, take a look in the header, you will see a filed called "set-cookie", just extract the cookie here.
When you make the next request add a field in the header called "cookie" and add the cookie.
You don't need special encoding (just escape classic forbidden character), it can be plain text like
"cookie" : "phpbb3=4111; _ga=GA1.2.191810458;pk_id.1.93f1=4f959c5d364730"
sincze
Post by sincze »
Tnx for this great tip :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
