Hello all ,
I have a RPi and connected a DHT11 sensor, in the beginning all looks fine but after a day and you check the "lines" its goes all up and down
Im a bit of a noob still and i dont see where it can go wrong....
its the "only" sensor i got hooked up to the pi,
Powersupply is official for the Pi 3b+
It worked oke for a a while
DHT11 goes nuts :)
TankySpanky
DHT11 goes nuts :)
Raspberry Pi 3 B+ & Domoticz Beta & Dashticz Beta = Headache :)
But it keeps you van the straat
TankySpanky
Re: DHT11 goes nuts :)
No one ?
freijn
- Domoticz version: Stable
Apperantly zero values are transmitted or..... connection is lost and values are not received ?
First Question, how long is the cable between sensor and RPI ? Did you apply the resistor as well at the end of the cable ?
TankySpanky
The cable are about 15cm from breadboard, and the DHT11 is mounted on a small print and no extra restistor is needed ( according the informaton of the item ) Its not "really" this item but it looks like this, with a red led.
Sometimes it works great for hours and otherwise it behaves like the first picture. Maybe i just need to buy a DHT22, they seems to be a lot better
ty in advance
ty in advance
Toulon7559
- Domoticz version: <2025
Looks like somewhere an 'intermittent'' contact:
checking of the cabling may be the solution.
If you want real improvement relative to DHT11, take BME280 as sensor:
provides temperature, humidity and pressure of much better quality.
Last edited by Toulon7559 on Saturday 17 August 2019 12:24, edited 1 time in total.
TankySpanky
Oke thanx for the answer i go and look for that
greetings
Aad
greetings
Aad
