Aeotec Z5 stick picky for frequencies nearby
Solderbro
Domoticz version: 2020.1
Post by Solderbro »
Found out that the Z-Stick dislike other frequency emitters nearby, it crumble the reach down.
1. My dualband wifi router although it look far away from 868Mhz.
2. Plastic covered switching psu, like the pi one
30cm seems to be the minimal keep out zone to avoid extreme crumbling. So my question for today is
Have someone played with a better antenna for z-wave? To open the stick and solder something better to the pins :lol:
Solderbro
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
lost
Re: Aeotec Z5 stick picky for frequencies nearby
Post by lost »
Solderbro wrote: Monday 22 July 2019 20:53 Found out that the Z-Stick dislike other frequency emitters nearby, it crumble the reach down.
My own gen5 stick is in the 10-20cm range from my wifi+wired router, because the PI3 is powered by the router USB port (using a short cable to avoid "low voltage" issues in the PI logs). No issues on my side.
I think this would be easier to use a 1m USB extension cable to be able to separate the stick from the radios of your router if they are not correctly filtered & you experience troubles out of their expected radio range.
Solderbro
Post by Solderbro »
Found out some emc hotspot that the pi fires into it's environment. So today i build it into a Icybox metal case for shielding, first experience is that the device collection after database backup is faster :D
You seem to have a really good router, my has no capability to serve 2.5 amps for the pi. So i use a copper shielded power supply.
Solderbro
