Python errors with both BuienRadar and ToonApiLib plugins
RduPre
Post by RduPre »
See the error I get in the error log.
Buienradar was working but after I installed the ToonApiLib plugin these error started.
Any help is more than welcome.
2019-07-29 22:35:10.182 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz-buienradar/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-07-29 22:35:10.182 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2019-07-29 22:35:10.182 Error: (Buienradar) Module Import failed: ' Name: requests'
2019-07-29 22:35:10.182 Error: (Buienradar) Error Line details not available.
2019-07-29 22:35:10.422 Error: (ToonApiLib) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/toonapilib4domoticz/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload:/usr/local/lib/python3.5/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.5/dist-packages'.
2019-07-29 22:35:10.422 Error: (Toon Thermostaat) Module Import failed, exception: 'ImportError'
2019-07-29 22:35:10.422 Error: (Toon Thermostaat) Module Import failed: ' Name: toonapilib'
2019-07-29 22:35:10.422 Error: (Toon Thermostaat) Error Line details not available.
2019-07-29 22:36:13.300 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
2019-07-29 22:36:13.300 Error: Toon Thermostaat hardware (18) thread seems to have ended unexpectedly
2019-07-29 22:36:27.308 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
2019-07-29 22:36:27.309 Error: Toon Thermostaat hardware (18) thread seems to have ended unexpectedly
2019-07-29 22:36:41.313 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
2019-07-29 22:36:41.313 Error: Toon Thermostaat hardware (18) thread seems to have ended unexpectedly
2019-07-29 22:36:55.315 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
2019-07-29 22:36:55.316 Error: Toon Thermostaat hardware (18) thread seems to have ended unexpectedly
2019-07-29 22:37:09.318 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
2019-07-29 22:37:09.319 Error: Toon Thermostaat hardware (18) thread seems to have ended unexpectedly
2019-07-29 22:37:23.322 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
2019-07-29 22:37:23.322 Error: Toon Thermostaat hardware (18) thread seems to have ended unexpectedly
2019-07-29 22:37:37.325 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
Dnpwwo
Re: Python errors with both BuienRadar and ToonApiLib plugins
Post by Dnpwwo »
@RduPre,
The Buienradar plugin now has an issue with the 'requests' library which means that when you installed 'toonapilib' pip may have updated 'requests' to a version that is incompatible.
Have you tried going into Python at the command line and importing requests to check it is valid?
RduPre
Post by RduPre »
Dnpwwo wrote: Monday 29 July 2019 23:25 @RduPre,
I don't know how to do this, I have the feeling that there is sometime wrong with Python or Pip itself
Snowtiger
Domoticz version: 4.10915
Post by Snowtiger »
Go into a Linux Terminal
- type python
- a >> prompt will appear
- type import requests
Now check if it does not throw you an error.
- type exit() or <ctrl> D = this exits the Python session
RduPre
Post by RduPre »
I get these errors when I type phyton
:~ $ python
Could not find platform independent libraries <prefix>
Could not find platform dependent libraries <exec_prefix>
Consider setting $PYTHONHOME to <prefix>[:<exec_prefix>]
ImportError: No module named site
Dnpwwo
Post by Dnpwwo »
@RduPre,
Doesn't look good :(
Can you try 'python3' '? That might work
RduPre
Post by RduPre »
Dnpwwo wrote: Tuesday 30 July 2019 23:16 @RduPre,
Python 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import requests
File "<stdin>", line 1, in <module>
ImportError: No module named 'requests'
Dnpwwo
Post by Dnpwwo »
@RduPre,
You could try
sudo pip3 install requests
RduPre
Post by RduPre »
Dnpwwo wrote: Tuesday 30 July 2019 23:50 @RduPre,
You could try
I did that, but error remains the same.
eenernl
Post by eenernl »
It looks like the last update to beta 4.11062 causes the problem. Since last July the 29th I have the same problems with ToonApiLib and Buienradar.
[attachment=0]2E055CDB-CCAF-45C7-A076-FDB3C37EA4FA.jpeg[/attachment]
Electric usage last 3 days
* Raspberry Pi B rev2 (with latest Beta of Domoticz)
* 1x RFXtrx433E
* 4x TX320 Temperature/humidity sensors
* 6x KaKu ACD-3500 | Kaku ALED-2709 | KaKu ACM-100 | 2x KaKu AMU-500 | KaKu AWMR-300
* 1x Toon Thermostat (via ToonApiLib)
Users browsing this forum: eddieb, willemd and 1 guest
