Blockly script not reacting to Hue dimmer switch
hscholing
Domoticz version: 4.10717
Post by hscholing »
I have in my living room a mixed setup of 3 Philips Hue bulbs and 3 IKEA bulbs. I'm now trying to let the IKEA bulbs react on a HUE bulb so my lights all can go on at the same time.
To do so I created 2 Blockly scripts and I grouped the IKEA bulbs in one group. My blockly states that when one of the Philips bulbs gets turned on the group of IKEA bulbs will also be turned on. Same way the other way around. When clicking in my Domoticz on the switch the Blockly scripts reacts and turns my IKEA group on or off. Great! But the problem is now the following:
I also use a Philips Hue dimmer and when using this remote to turn my lights on (so including the one that triggers the Blockly script) the Blockly script is not activated. I can see that the switch for this light is on in my dashboard, but no Blockly response. This is the same when turning the specific HUE light off. Can somebody telling my if I'm doing something wrong and how to fix this? My livingroom is now partly dark :)
Re: Blockly script not reacting to Hue dimmer switch
hscholing wrote: Monday 29 July 2019 20:59 ..when using this remote to turn my lights on (so including the one that triggers the Blockly script) the Blockly script is not activated. I can see that the switch for this light is on in my dashboard, but no Blockly response. This is the same when turning the specific HUE light off. Can somebody telling my if I'm doing something wrong and how to fix this?
You don't do anything wrong but the way the Hue light state change is send to domoticz is not picked up by Blockly. If you do want this functionality you will have to switch to dzVents or classic domoticz Lua.
in dzVents it could look like
local lights = { 'IKEA-1','IKEA-2','IKEA-3', 'Hue-1', 'Hue-2', 'Hue-3' }
return
    on =
        devices = lights,
    execute = function(dz, item)
        local IKEA_group = { 'IKEA-1','IKEA-2','IKEA-3' }
        local Hue_group = {'Hue-1', 'Hue-2', 'Hue-3' }
        dz.log('Device ' .. item.name .. ' was switched ' .. item.state , dz.LOG_INFO)
        local function inTable (table, key)
            for _, name in ipairs(table) do
                if name == key then return true end
        if item.active then
            if inTable(IKEA_group, item.name) then
                for _, name in ipairs(Hue_group) do
                    dz.devices(name).switchOn().silent()
                for _, name in ipairs(IKEA_group) do
When not yet familiar with dzVents please start with reading Get started Before implementing. Special attention please for
"In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
