Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee) Topic is solved
Thorgal789
- Target OS: -
Re: Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee)
What is yout line 37 ?
You have the same name "colorloop" ?
Can you show me your code, I m using it in a LUA file in LUA directory.
salopette
- Domoticz version: BETA
Now it is halfway, I have created a virtual switch (colorloop on / off) with on color change starts, with off the lamp turns to red and does not go out.
36:--color loop switch
37: if devicechanged['colorloop'] then
38: if devicechanged['colorloop'] == 'On' then
39: print('Start colorloop')
40: SendJson('http://192.168.178.93/api/D279EE0F45/li ... ,"on":true}\'')
41: else
42: print('Stop colorloop')
43: SendJson('http://192.168.178.93/api/D279EE0F45/li ... ,"on":true}\'')
44: end
45: end
41: else
44: end
45: end
Thorgal789
- Target OS: -
It's normal, my bad ^^
Use "on":false to turn off the bulb > {"effect":"none","on":false}
- Not sure for quote around none
- Not sure the "effect" part is usefull for off mode, but for me It disable it for next time you turn the bulb on.
salopette
Thanks, now colorloop goes on and off!
But one mistake still comes .:
That comes every minute
2019-07-27 21:58:00.553 Error: EventSystem: in Script #test: [string "--..."]:37: attempt to index global 'devicechanged' (a nil value)
Thorgal789
- Target OS: -
I think you have using internal LUA system (setting/more option/event) instead of external file, and you have set the trigger as "time" instead of "device" (or perhaps "all", I don't use this feature).
salopette
Yes that's right.
Thorgal789
- Target OS: -
I have something to ask you ^^, can I have the complete working script, to put it on the wiki ?
I m sure it will be more people who wanna use it.
salopette
I changed trigger on device and the error is gone!
-- Color loop test
function SendJson(url,json)
local curl = "/usr/bin/curl"
local cmd = curl .. ' -X PUT -d '..json..' '..url
local vac = os.execute(cmd)
if vac ~= true then
print('Send JSON Error')
--color loop switch
SendJson('http://192.168.178.93/api/D279EE0F45/lights/50/state','\'{"effect":"colorloop","on":true}\'')
SendJson('http://192.168.178.93/api/D279EE0F45/lights/50/state','\'{"effect":"15","on":false}\'')
return commandArray- Attachments
- sshot-2019-07-28-[1].jpg (201 KiB) Viewed 2088 times
Thorgal789
- Target OS: -
Nice, thx a lot.
Thorgal789
- Target OS: -
salopette
@ Thorgal789
Do you know why my Apikey changes on its own, without me restarting the Pi or something?
Can you handle this?
Thorgal789
- Target OS: -
Not normal !
Wich one way are you using to get your key ?
It change on domoticz or on deconz ?
The previous stil working or not ?
For information, when you use phoscon, if you are on the page that ask pass and user, never put this page on bookmark, else it will generate a new api key at each connection, I have make the error too, and had around 30/40 api key in config ^^. It's for that I have make the tool to clean the config.
Better to enter user and pass, and bookmark the next page with "gwid=" in url, this one remember you.
But even there is some way for deconz generate a new key (and the plugin don't use them), there is not for it disable one.
salopette
The Key changes at Deconz,
I always get the key in which f12 in Crome is on the Deconz page.
- sshot-2019-07-30-[1].jpg (188.2 KiB) Viewed 2058 times
Thorgal789
- Target OS: -
Ok, that was what I thought.
I think if you take a look on your config json > http://192.168.1.1/api/63E144295E/config you will see 20/30 api key with "Phoscon#B1920x1045" or "deCONZ WebApp" as name ?
Every time you use the explorer with an url without "gwid=" it will generate a new api key. But you still can use the old one, I don't think you need to change it in domoticz.
The better way to generate an API KEy is using this method https://dresden-elektronik.github.io/de ... uireapikey or using the tool in the plugin.
Go on the plugin folder and type
You will have help how to use it, and there is too a command to clean up your config, this tool make an api key for user called "domoticz" so you can't make mistake with another one.
python3 API_KEY.py-
salopette
I do not know and do not understand how I use the file python3 API_KEY.py
can activate?
on the pi where deconz is, can not i find that?
/ Home / pi / deconz-rest-plugin
http://192.168.178.93/api/6B98A2619A/config
can activate?
{"UTC":"2019-07-30T16:22:09","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF040801","datastoreversion":"60","devicename":"ConBee II","dhcp":true,"factorynew":false,"fwversion":"0x26490700","gateway":"192.168.178.1","internetservices":{"remoteaccess":"disconnected"},"ipaddress":"192.168.178.93","linkbutton":false,"localtime":"2019-07-30T18:22:09","mac":"b8:27:eb:80:48:4f","modelid":"deCONZ","name":"Phoscon-GW","netmask":"255.255.255.0","networkopenduration":600,"panid":4092,"portalconnection":"disconnected","portalservices":false,"portalstate":{"communication":"disconnected","incoming":false,"outgoing":false,"signedon":false},"proxyaddress":"none","proxyport":0,"replacesbridgeid":null,"rfconnected":true,"starterkitid":"","swupdate":{"checkforupdate":false,"devicetypes":{"bridge":false,"lights":[],"sensors":[]},"notify":false,"text":"","updatestate":0,"url":""},"swupdate2":{"autoinstall":{"on":false,"updatetime":""},"bridge":{"lastinstall":"2019-06-16T17:39:51","state":"allreadytoinstall"},"checkforupdate":false,"install":false,"lastchange":"","lastinstall":"","state":"allreadytoinstall"},"swversion":"2.5.66","timeformat":"24h","timezone":"Etc/GMT-2","uuid":"3cd1c13a-0097-4b8d-bf11-aa165a7c9fb9","websocketnotifyall":true,"websocketport":443,"whitelist":{"00233EEF1E":{"create date":"2019-07-09T18:18:17","last use date":"2019-07-09T18:18:38","name":"Phoscon#B1862x857"},"0187332681":{"create date":"2019-05-25T10:25:34","last use date":"2019-05-25T10:58:36","name":"Phoscon#B1746x804"},"0207399351":{"create date":"2019-04-30T19:03:35","last use date":"2019-04-30T19:06:56","name":"Phoscon#B1397x643"},"026CA2440E":{"create date":"2019-04-28T17:02:13","last use date":"2019-04-28T17:04:16","name":"Phoscon#B360x372"},"0433C21A12":{"create date":"2019-05-02T14:19:08","last use date":"2019-05-02T14:20:14","name":"Phoscon#B1552x715"},"045E7FAAA0":{"create date":"2019-04-29T19:26:05","last use date":"2019-07-30T13:18:42","name":"Echo"},"049C9719AC":{"create date":"2019-06-24T19:17:30","last use date":"2019-06-24T19:24:27","name":"Phoscon#B1746x804"},"049CEF3C3B":{"create date":"2019-07-25T09:27:16","last use date":"2019-07-25T09:31:13","name":"Phoscon#B1862x857"},"04B9C265AF":{"create date":"2019-06-04T18:24:29","last use date":"2019-06-04T18:25:03","name":"Phoscon#B1746x804"},"0567447A9E":{"create date":"2019-04-21T10:10:02","last use date":"2019-04-21T10:16:48","name":"Phoscon#B1397x643"},"0739B8A7E3":{"create date":"2019-04-16T18:34:02","last use date":"2019-05-15T14:10:21","name":"Phoscon#B1397x594"},"07E18C0518":{"create date":"2019-05-10T12:36:11","last use date":"2019-05-10T12:59:46","name":"Phoscon#B1746x804"},"089044C377":{"create date":"2019-06-21T12:27:28","last use date":"2019-06-21T12:27:48","name":"Phoscon#B1746x804"},"08FBE59D08":{"create date":"2019-07-07T08:22:54","last use date":"2019-07-07T08:43:53","name":"Phoscon#B360x380"},"0951D1C8A4":{"create date":"2019-05-17T17:47:39","last use date":"2019-05-17T18:00:45","name":"Phoscon#B1746x804"},"09F1064EBF":{"create date":"2019-05-24T12:39:28","last use date":"2019-05-24T12:41:28","name":"Phoscon#B1746x804"},"0A4BB4F275":{"create date":"2019-06-28T16:19:23","last use date":"2019-06-28T16:21:12","name":"Phoscon#B1862x857"},"0C1FEE9428":{"create date":"2019-05-10T15:12:05","last use date":"2019-05-10T15:12:28","name":"Phoscon#B1746x804"},"0C2A9CA96A":{"create date":"2019-05-08T18:48:37","last use date":"2019-05-08T18:52:08","name":"Phoscon#B1746x804"},"0D66461ED6":{"create date":"2019-05-17T19:38:11","last use date":"2019-05-17T19:38:17","name":"Phoscon#B360x428"},"0F98DCC18D":{"create date":"2019-05-04T19:36:27","last use date":"2019-05-04T19:39:13","name":"Phoscon#B1746x804"},"105A908C64":{"create date":"2019-05-22T13:22:51","last use date":"2019-05-22T13:28:59","name":"Phoscon#B1746x804"},"105E75FEE0":{"create date":"2019-07-24T15:40:53","last use date":"2019-07-24T15:41:09","name":"Phoscon#B1862x857"},"13691340C5":{"create date":"2019-05-03T15:34:10","last use date":"2019-05-03T15:43:09","name":"Phoscon#B1746x804"},"14112F7410":{"create date":"2019-07-07T12:24:27","last use date":"2019-07-07T12:24:44","name":"Phoscon#B1862x857"},"158ABCBBED":{"create date":"2019-05-29T15:41:32","last use date":"2019-05-29T15:54:41","name":"Phoscon#B1746x804"},"169ED5FD5D":{"create date":"2019-05-18T11:01:47","last use date":"2019-05-18T11:01:53","name":"Phoscon#B1746x804"},"16FAD4ECAC":{"create date":"2019-05-19T11:02:58","last use date":"2019-05-19T11:03:36","name":"Phoscon#B1746x804"},"175D20056C":{"create date":"2019-05-01T16:49:27","last use date":"2019-05-02T03:18:45","name":"Phoscon#B360x372"},"17AC4B34FF":{"create date":"2019-05-17T19:16:48","last use date":"2019-05-17T19:17:24","name":"Phoscon#B1746x804"},"18BC26AB04":{"create date":"2019-05-07T04:20:42","last use date":"2019-05-07T04:21:28","name":"Phoscon#B360x428"},"1A619D5E1D":{"create date":"2019-04-25T13:52:10","last use date":"2019-04-25T13:54:23","name":"Phoscon#B1397x643"},"1B29D027DF":{"create date":"2019-04-18T07:26:43","last use date":"2019-04-18T07:26:53","name":"Phoscon#B1397x643"},"1BB236AA2F":{"create date":"2019-07-23T06:47:43","last use date":"2019-07-23T06:49:03","name":"Phoscon#B1862x857"},"1C7FBBE7BB":{"create date":"2019-07-29T09:54:22","last use date":"2019-07-29T09:54:49","name":"Phoscon#B1862x857"},"1CC3381D3D":{"create date":"2019-05-04T16:05:50","last use date":"2019-05-04T16:05:56","name":"Phoscon#B360x428"},"1F11CBE872":{"create date":"2019-04-24T19:38:13","last use date":"2019-04-24T19:48:38","name":"Phoscon#B1397x643"},"1F4E94EF2D":{"create date":"2019-07-22T20:15:23","last use date":"2019-07-22T20:15:28","name":"Phoscon#B1862x857"},"1F8B375642":{"create date":"2019-05-14T15:55:34","last use date":"2019-05-14T15:58:00","name":"Phoscon#B1746x742"},"1FC124530C":{"create date":"2019-05-17T20:19:14","last use date":"2019-05-17T20:19:40","name":"Phoscon#B360x428"},"207C296AB1":{"create date":"2019-07-30T14:10:50","last use date":"2019-07-30T14:51:06","name":"Phoscon#B1862x857"},"21230DFC3B":{"create date":"2019-07-03T14:41:14","last use date":"2019-07-03T14:44:58","name":"Phoscon#B1862x857"},"219A57E996":{"create date":"2019-04-27T18:55:18","last use date":"2019-04-27T18:57:25","name":"Phoscon#B1397x643"},"22B42539EE":{"create date":"2019-07-04T17:46:04","last use date":"2019-07-04T17:46:20","name":"Phoscon#B1862x857"},"23558AB15E":{"create date":"2019-04-28T16:56:38","last use date":"2019-04-28T17:01:56","name":"Phoscon#B980x1013"},"2381F9C39C":{"create date":"2019-07-20T07:35:21","last use date":"2019-07-20T07:35:33","name":"Phoscon#B1862x857"},"249AAAA1FA":{"create date":"2019-05-22T18:56:59","last use date":"2019-05-22T18:57:43","name":"Phoscon#B1746x804"},"24DDF0DD7C":{"create date":"2019-05-29T17:33:59","last use date":"2019-05-29T17:34:44","name":"Phoscon#B1746x804"},"277A7ACE6C":{"create date":"2019-04-30T19:15:56","last use date":"2019-04-30T19:41:33","name":"Phoscon#B1397x643"},"288FA67608":{"create date":"2019-07-26T10:22:03","last use date":"2019-07-26T10:23:08","name":"Phoscon#B1862x857"},"29DD9B4EBC":{"create date":"2019-05-04T18:58:05","last use date":"2019-07-30T15:21:18","name":"Phoscon#B1746x804"},"2A537983AA":{"create date":"2019-04-24T19:49:54","last use date":"2019-04-24T19:49:57","name":"Phoscon#B1397x643"},"2A8A700A83":{"create date":"2019-06-04T14:06:33","last use date":"2019-06-04T14:13:16","name":"Phoscon#B1746x804"},"2AC8A4A2A8":{"create date":"2019-07-07T08:37:15","last use date":"2019-07-07T08:37:42","name":"Phoscon#B1862x857"},"2B92CA13B8":{"create date":"2019-05-30T18:24:29","last use date":"2019-06-07T22:01:03","name":"Phoscon#B1746x804"},"2D4DE09FE6":{"create date":"2019-04-18T16:27:49","last use date":"2019-04-18T16:27:58","name":"Phoscon#B1397x643"},"2E43F98702":{"create date":"2019-04-29T19:23:26","last use date":"2019-04-29T19:25:39","name":"Phoscon#B360x372"},"2F1C47ED67":{"create date":"2019-05-18T08:35:17","last use date":"2019-05-18T08:37:13","name":"Phoscon#B1746x804"},"2F53C407BF":{"create date":"2019-06-05T18:39:37","last use date":"2019-06-05T18:42:08","name":"Phoscon#B1746x804"},"30F43A91A6":{"create date":"2019-06-01T09:33:33","last use date":"2019-06-01T09:34:24","name":"Phoscon#B1746x804"},"31FA11BACE":{"create date":"2019-07-28T17:05:26","last use date":"2019-07-29T19:50:01","name":"Phoscon#B1862x857"},"32096F68EE":{"create date":"2019-04-17T20:11:45","last use date":"2019-04-17T20:11:59","name":"Phoscon#B1397x643"},"3212DC9A41":{"create date":"2019-05-11T16:02:06","last use date":"2019-05-11T16:06:55","name":"Phoscon#B1746x804"},"32159BAA25":{"create date":"2019-05-08T17:46:06","last use date":"2019-05-08T17:46:13","name":"Phoscon#B1746x804"},"3252D465A1":{"create date":"2019-05-02T13:38:07","last use date":"2019-05-02T13:41:19","name":"Phoscon#B775x698"},"32CD4B5D80":{"create date":"2019-05-27T13:32:50","last use date":"2019-05-27T13:33:54","name":"Phoscon#B1746x804"},"330F864C02":{"create date":"2019-06-17T11:04:29","last use date":"2019-06-17T11:04:56","name":"Phoscon#B360x428"},"3350F45ADD":{"create date":"2019-07-26T18:41:14","last use date":"2019-07-26T18:49:39","name":"Phoscon#B1862x857"},"3422712DDF":{"create date":"2019-06-03T19:09:51","last use date":"2019-06-03T19:12:32","name":"Phoscon#B1746x804"},"347350A639":{"create date":"2019-07-09T13:33:12","last use date":"2019-07-09T13:33:29","name":"Phoscon#B1862x857"},"38EC75BA1B":{"create date":"2019-05-18T16:50:58","last use date":"2019-05-18T16:52:02","name":"Phoscon#B1746x804"},"3953340C31":{"create date":"2019-07-22T10:09:29","last use date":"2019-07-22T10:17:03","name":"Phoscon#B1862x857"},"3C15A258B3":{"create date":"2019-07-27T08:13:59","last use date":"2019-07-27T08:14:19","name":"Phoscon#B1862x857"},"3C9CD05C21":{"create date":"2019-05-07T13:34:31","last use date":"2019-05-07T13:36:55","name":"Phoscon#B1746x804"},"3CB8CD2B61":{"create date":"2019-07-20T15:29:29","last use date":"2019-07-20T15:30:51","name":"Phoscon#B1862x857"},"3D09AD1ED7":{"create date":"2019-05-12T19:12:16","last use date":"2019-05-12T19:12:52","name":"Phoscon#B1746x804"},"3DCE9AFB54":{"create date":"2019-05-06T18:27:48","last use date":"2019-05-06T18:33:19","name":"Phoscon#B871x785"},"3F430DA686":{"create date":"2019-04-16T15:23:38","last use date":"2019-04-16T15:32:01","name":"Phoscon#B936x594"},"3FEC450EBD":{"create date":"2019-06-24T16:50:58","last use date":"2019-06-24T16:51:22","name":"Phoscon#B1746x804"},"401CABBF1E":{"create date":"2019-07-09T18:14:53","last use date":"2019-07-09T18:15:01","name":"Phoscon#B1862x857"},"4139F07FA4":{"create date":"2019-06-22T05:55:45","last use date":"2019-06-22T05:58:30","name":"Phoscon#B1746x804"},"42C46EBC58":{"create date":"2019-04-28T17:14:33","last use date":"2019-04-28T17:15:50","name":"Phoscon#B1397x643"},"42D0BDF7F1":{"create date":"2019-07-29T09:42:04","last use date":"2019-07-29T09:53:59","name":"Phoscon#B1862x857"},"42D29E67C6":{"create date":"2019-07-30T14:56:44","last use date":"2019-07-30T15:19:08","name":"Phoscon#B1862x857"},"434D87F6B8":{"create date":"2019-07-30T11:43:26","last use date":"2019-07-30T11:49:28","name":"Phoscon#B1862x792"},"43A778A231":{"create date":"2019-04-28T19:05:59","last use date":"2019-04-28T19:32:18","name":"Phoscon#B1397x643"},"44A4622B0D":{"create date":"2019-04-30T20:27:03","last use date":"2019-04-30T20:30:45","name":"Phoscon#B1746x804"},"44EA8256AB":{"create date":"2019-05-18T06:28:54","last use date":"2019-05-18T06:29:10","name":"Phoscon#B1746x804"},"450153BD86":{"create date":"2019-04-17T17:02:50","last use date":"2019-04-17T17:03:21","name":"Phoscon#B1397x643"},"45A9DF9EE2":{"create date":"2019-06-06T13:42:23","last use date":"2019-06-06T13:43:32","name":"Phoscon#B1746x804"},"46D2B2045D":{"create date":"2019-04-27T16:55:14","last use date":"2019-04-27T16:55:18","name":"Phoscon#B1397x643"},"485351F2C7":{"create date":"2019-05-21T18:22:32","last use date":"2019-05-21T18:23:41","name":"Phoscon#B1746x804"},"48F107519A":{"create date":"2019-04-19T12:24:08","last use date":"2019-04-19T12:24:11","name":"Phoscon#B1397x643"},"493A01F343":{"create date":"2019-04-29T03:14:56","last use date":"2019-04-29T03:14:56","name":"Phoscon#B1397x643"},"4B4E6B0216":{"create date":"2019-04-18T19:54:16","last use date":"2019-04-18T19:54:35","name":"Phoscon#B1397x643"},"4BA250C6F9":{"create date":"2019-05-03T14:01:27","last use date":"2019-05-03T14:09:09","name":"Phoscon#B1746x804"},"4BD7DB1624":{"create date":"2019-05-02T17:45:45","last use date":"2019-05-02T17:51:45","name":"Phoscon#B1552x715"},"4CA1096451":{"create date":"2019-04-29T18:51:23","last use date":"2019-07-25T09:29:44","name":"homebridge-hue#deconz"},"4D122B27CD":{"create date":"2019-06-20T16:30:46","last use date":"2019-06-20T16:31:17","name":"Phoscon#B1746x804"},"4DCEA6142F":{"create date":"2019-06-20T19:08:48","last use date":"2019-06-20T19:08:58","name":"Phoscon#B360x380"},"4E6A0ADF89":{"create date":"2019-04-28T19:56:10","last use date":"2019-04-28T20:02:27","name":"Phoscon#B1397x643"},"4F4FE360CE":{"create date":"2019-06-21T20:06:45","last use date":"2019-06-21T20:14:40","name":"Phoscon#B360x380"},"528E94A8B3":{"create date":"2019-07-25T18:40:56","last use date":"2019-07-25T18:41:23","name":"Phoscon#B1862x857"},"52B7F56399":{"create date":"2019-05-01T06:32:56","last use date":"2019-05-01T06:33:58","name":"Phoscon#B1746x804"},"52C84D3114":{"create date":"2019-05-11T12:37:17","last use date":"2019-05-11T12:37:27","name":"Phoscon#B1746x804"},"54080988EC":{"create date":"2019-06-17T18:47:26","last use date":"2019-06-17T18:48:45","name":"Phoscon#B1746x804"},"540CA0F528":{"create date":"2019-07-20T14:30:23","last use date":"2019-07-20T14:35:35","name":"Phoscon#B1862x857"},"5592D49B2E":{"create date":"2019-05-19T18:56:51","last use date":"2019-05-19T18:58:39","name":"Phoscon#B1746x804"},"5717D36895":{"create date":"2019-04-23T13:37:50","last use date":"2019-06-18T18:39:03","name":"homebridge-hue#phoscon"},"57F45E6BB4":{"create date":"2019-04-26T14:02:20","last use date":"2019-04-26T14:02:23","name":"Phoscon#B1397x643"},"5801A4CA31":{"create date":"2019-05-04T15:27:10","last use date":"2019-05-04T15:27:25","name":"Phoscon#B1746x804"},"58A9453F6B":{"create date":"2019-05-25T05:26:57","last use date":"2019-05-25T05:27:37","name":"Phoscon#B1746x804"},"590E50680F":{"create date":"2019-07-10T19:27:55","last use date":"2019-07-10T19:29:43","name":"Phoscon#B1862x857"},"5935A21680":{"create date":"2019-04-20T20:10:58","last use date":"2019-04-20T20:07:18","name":"Phoscon#B1397x643"},"5994D33A58":{"create date":"2019-07-09T17:49:42","last use date":"2019-07-09T17:57:07","name":"Phoscon#B360x380"},"5B20FA9D5E":{"create date":"2019-06-27T18:36:08","last use date":"2019-06-27T18:41:10","name":"Phoscon#B1862x857"},"5C0EBBAAF5":{"create date":"2019-07-26T06:11:38","last use date":"2019-07-26T06:41:44","name":"Phoscon#B1862x857"},"5C5C722321":{"create date":"2019-05-14T15:24:05","last use date":"2019-05-14T15:24:20","name":"Phoscon#B1746x804"},"5CCF8FFE49":{"create date":"2019-06-16T13:36:16","last use date":"2019-06-17T19:08:19","name":"Phoscon#B1746x804"},"5DD8BCC541":{"create date":"2019-05-19T15:57:49","last use date":"2019-05-19T15:58:39","name":"Phoscon#B360x428"},"5EC2A98D03":{"create date":"2019-04-20T10:30:02","last use date":"2019-04-20T10:30:28","name":"Phoscon#B1397x643"},"5FBBF5D0AB":{"create date":"2019-07-27T11:33:15","last use date":"2019-07-27T11:34:31","name":"Phoscon#B1862x857"},"5FE5B6B9EF":{"create date":"2019-05-04T15:51:28","last use date":"2019-05-04T15:52:24","name":"Phoscon#B1746x804"},"6013F55317":{"create date":"2019-05-25T20:39:44","last use date":"2019-05-25T20:40:02","name":"Phoscon#B1746x804"},"60C99FF048":{"create date":"2019-06-06T16:55:17","last use date":"2019-06-06T17:05:47","name":"Phoscon#B1746x804"},"62E353A94A":{"create date":"2019-06-19T19:21:03","last use date":"2019-06-19T19:23:18","name":"Phoscon#B1746x804"},"6401AEA0CD":{"create date":"2019-05-25T17:18:54","last use date":"2019-05-25T17:19:15","name":"Phoscon#B1746x804"},"64A55E34AC":{"create date":"2019-05-19T09:52:42","last use date":"2019-05-19T10:08:40","name":"Phoscon#B1746x804"},"658E6DB8C2":{"create date":"2019-05-13T17:46:37","last use date":"2019-05-13T17:46:52","name":"Phoscon#B1746x804"},"65DA1EFF94":{"create date":"2019-06-22T19:38:24","last use date":"2019-06-22T19:46:42","name":"Phoscon#B1746x804"},"660C5D562F":{"create date":"2019-04-30T19:09:36","last use date":"2019-04-30T20:48:45","name":"Phoscon#B360x372"},"660EA75E1C":{"create date":"2019-04-28T06:14:30","last use date":"2019-04-28T06:16:06","name":"Phoscon#B1397x643"},"666F8DEE98":{"create date":"2019-06-30T19:20:28","last use date":"2019-06-30T19:22:07","name":"Phoscon#B1862x857"},"682FD460EF":{"create date":"2019-05-23T13:23:59","last use date":"2019-05-23T13:24:20","name":"Phoscon#B1746x804"},"6914FE7937":{"create date":"2019-06-17T14:16:32","last use date":"2019-06-17T14:18:48","name":"Phoscon#B1746x804"},"6A11C25BBE":{"create date":"2019-07-26T15:19:50","last use date":"2019-07-26T15:21:55","name":"Phoscon#B1862x857"},"6AF79EFC58":{"create date":"2019-04-30T18:24:56","last use date":"2019-04-30T18:26:45","name":"Phoscon#B1397x643"},"6B98A2619A":{"create date":"2019-07-30T16:21:55","last use date":"2019-07-30T16:22:09","name":"Phoscon#B1862x857"},"6C0AAC0CF7":{"create date":"2019-07-22T08:59:53","last use date":"2019-07-22T08:59:54","name":"Phoscon#B1862x857"},"6CBA415E86":{"create date":"2019-05-03T03:15:46","last use date":"2019-05-03T03:17:12","name":"Phoscon#B1746x804"},"6CD7FAA014":{"create date":"2019-07-25T08:31:09","last use date":"2019-07-25T08:55:30","name":"Phoscon#B1862x857"},"6EF6566C0A":{"create date":"2019-06-15T16:28:55","last use date":"2019-06-15T16:29:09","name":"Phoscon#B1746x804"},"6F308BE12D":{"create date":"2019-06-14T13:02:28","last use date":"2019-06-14T13:02:46","name":"Phoscon#B1746x804"},"6FB7824FAE":{"create date":"2019-07-29T13:08:16","last use date":"2019-07-29T13:08:39","name":"Phoscon#B1862x857"},"70449462B6":{"create date":"2019-06-03T19:04:40","last use date":"2019-06-03T19:28:48","name":"Phoscon#B360x428"},"704CB68C1D":{"create date":"2019-06-07T21:56:39","last use date":"2019-06-07T22:00:21","name":"Phoscon#B1746x804"},"709D82B97B":{"create date":"2019-05-08T16:28:55","last use date":"2019-05-08T16:31:59","name":"Phoscon#B1746x804"},"70DD477A01":{"create date":"2019-05-09T17:36:05","last use date":"2019-05-09T17:37:44","name":"Phoscon#B360x428"},"713F667B10":{"create date":"2019-07-21T08:04:24","last use date":"2019-07-21T08:06:38","name":"Phoscon#B1862x857"},"7298290305":{"create date":"2019-05-02T19:32:46","last use date":"2019-05-02T19:33:10","name":"Phoscon#B360x428"},"73ACEA22E5":{"create date":"2019-04-28T17:04:21","last use date":"2019-04-28T20:27:18","name":"Phoscon#B360x372"},"75BEF7CE72":{"create date":"2019-07-23T18:44:30","last use date":"2019-07-23T18:49:21","name":"Phoscon#B1862x857"},"764EB43AA3":{"create date":"2019-05-31T20:10:54","last use date":"2019-05-31T20:11:32","name":"Phoscon#B1746x804"},"76F4CC7EC8":{"create date":"2019-05-18T12:06:22","last use date":"2019-05-18T12:08:45","name":"Phoscon#B1746x804"},"773CF0CFEC":{"create date":"2019-05-03T18:28:45","last use date":"2019-05-03T18:29:09","name":"Phoscon#B1746x804"},"7840646D53":{"create date":"2019-05-23T17:51:01","last use date":"2019-05-23T17:52:36","name":"Phoscon#B1746x804"},"7A01646EA5":{"create date":"2019-06-18T15:50:45","last use date":"2019-06-18T15:51:06","name":"Phoscon#B1746x804"},"7A208C0EE4":{"create date":"2019-06-01T12:22:57","last use date":"2019-06-01T12:23:19","name":"Phoscon#B1746x804"},"7A96E4F404":{"create date":"2019-05-07T16:35:53","last use date":"2019-05-07T16:41:14","name":"Phoscon#B1746x804"},"7AEACAEE47":{"create date":"2019-04-22T10:06:37","last use date":"2019-04-22T10:06:41","name":"Phoscon#B1397x643"},"7B58599D61":{"create date":"2019-04-16T16:23:06","last use date":"2019-05-06T18:43:25","name":"Phoscon#B1397x643"},"7B805F8F73":{"create date":"2019-05-04T10:47:01","last use date":"2019-05-04T11:02:42","name":"Phoscon#B1746x804"},"7B8DDB2B9F":{"create date":"2019-05-14T18:23:50","last use date":"2019-05-14T18:25:14","name":"Phoscon#B1746x804"},"7B9D700EC1":{"create date":"2019-05-20T18:16:10","last use date":"2019-05-20T18:17:12","name":"Phoscon#B1746x804"},"7C663BB6FD":{"create date":"2019-06-15T07:44:25","last use date":"2019-06-15T07:45:54","name":"Phoscon#B360x428"},"7D4F631425":{"create date":"2019-05-02T18:25:38","last use date":"2019-05-02T18:26:14","name":"Phoscon#B1552x715"},"7E3872E8CB":{"create date":"2019-05-19T16:03:59","last use date":"2019-05-19T16:16:04","name":"Phoscon#B360x428"},"7E7F44DAC9":{"create date":"2019-06-26T18:41:23","last use date":"2019-06-26T18:42:47","name":"Phoscon#B1862x857"},"819B676C99":{"create date":"2019-04-24T13:26:27","last use date":"2019-04-24T13:26:43","name":"Phoscon#B1397x643"},"81AAB3B7B2":{"create date":"2019-05-30T16:29:11","last use date":"2019-05-30T16:39:26","name":"Phoscon#B1746x804"},"81FB54DFE1":{"create date":"2019-05-07T17:27:58","last use date":"2019-05-07T17:34:08","name":"Phoscon#B1746x804"},"82F9408811":{"create date":"2019-07-23T19:49:29","last use date":"2019-07-23T19:49:33","name":"Phoscon#B1862x857"},"830366BCCE":{"create date":"2019-06-16T16:32:59","last use date":"2019-06-16T16:38:08","name":"Phoscon#B360x428"},"842B63BD42":{"create date":"2019-04-30T19:10:08","last use date":"2019-04-30T19:56:45","name":"Phoscon#B360x428"},"846468E7D1":{"create date":"2019-07-26T06:49:56","last use date":"2019-07-26T07:04:08","name":"Phoscon#B1862x857"},"85B42B619F":{"create date":"2019-05-07T19:06:28","last use date":"2019-05-07T19:07:39","name":"Phoscon#B1746x804"},"86FB4FB1C3":{"create date":"2019-06-11T07:49:50","last use date":"2019-06-11T07:51:22","name":"Phoscon#B1746x804"},"8706BFA48B":{"create date":"2019-05-01T18:56:16","last use date":"2019-05-01T18:56:48","name":"Phoscon#B1746x804"},"8777A5F922":{"create date":"2019-04-17T10:56:20","last use date":"2019-04-17T10:59:48","name":"Phoscon#B1397x643"},"88EA7BA154":{"create date":"2019-04-19T10:38:11","last use date":"2019-07-30T13:23:17","name":"homebridge-hue#phoscon"},"89E482F238":{"create date":"2019-06-29T15:52:32","last use date":"2019-06-29T15:52:57","name":"Phoscon#B1862x857"},"8A57F1E4A5":{"create date":"2019-07-05T13:25:51","last use date":"2019-07-05T13:26:07","name":"Phoscon#B1862x857"},"8BFE740AC3":{"create date":"2019-04-21T10:12:19","last use date":"2019-06-18T17:35:52","name":"homebridge-hue#phoscon"},"8CD0CC8152":{"create date":"2019-06-05T13:58:15","last use date":"2019-06-05T13:59:16","name":"Phoscon#B1746x804"},"8D9D7C9B0A":{"create date":"2019-07-11T15:04:16","last use date":"2019-07-11T15:16:26","name":"Phoscon#B1862x857"},"8E993F430D":{"create date":"2019-05-18T08:33:14","last use date":"2019-05-30T18:24:12","name":"Phoscon#B1746x804"},"8F4E4B66DA":{"create date":"2019-07-26T05:45:31","last use date":"2019-07-26T05:46:13","name":"Phoscon#B1862x857"},"8FD4E0709D":{"create date":"2019-04-29T14:21:50","last use date":"2019-04-29T14:26:44","name":"Phoscon#B1397x643"},"909F0FD8FA":{"create date":"2019-07-21T19:55:04","last use date":"2019-07-21T19:55:27","name":"Phoscon#B1862x857"},"90D3C43BB1":{"create date":"2019-07-07T18:56:48","last use date":"2019-07-07T18:57:37","name":"Phoscon#B1862x857"},"90E5278B8C":{"create date":"2019-05-26T19:04:23","last use date":"2019-05-26T19:04:49","name":"Phoscon#B1746x804"},"90F860E30B":{"create date":"2019-07-05T19:55:54","last use date":"2019-07-05T19:57:02","name":"Phoscon#B1862x857"},"92AE0D99EF":{"create date":"2019-07-28T20:00:32","last use date":"2019-07-28T20:01:45","name":"Phoscon#B1862x857"},"930A315171":{"create date":"2019-04-23T13:36:16","last use date":"2019-04-23T13:39:41","name":"Phoscon#B1397x643"},"95082F5CA9":{"create date":"2019-05-16T13:55:05","last use date":"2019-05-16T13:55:28","name":"Phoscon#B1746x804"},"961BC06555":{"create date":"2019-06-13T14:00:32","last use date":"2019-06-13T14:00:50","name":"Phoscon#B1746x804"},"9640315261":{"create date":"2019-04-30T17:06:37","last use date":"2019-04-30T17:25:55","name":"Phoscon#B1397x594"},"96581DC625":{"create date":"2019-06-07T15:11:26","last use date":"2019-06-07T15:13:12","name":"Phoscon#B1746x804"},"979DC2F8B0":{"create date":"2019-06-18T03:05:15","last use date":"2019-06-18T03:07:21","name":"Phoscon#B1746x804"},"97D9C4401C":{"create date":"2019-05-26T06:56:40","last use date":"2019-05-26T06:56:55","name":"Phoscon#B1746x804"},"982C8DAE35":{"create date":"2019-06-08T05:56:54","last use date":"2019-06-16T13:36:34","name":"Phoscon#B1746x804"},"98C188BB45":{"create date":"2019-04-17T07:36:10","last use date":"2019-04-17T07:36:23","name":"Phoscon#B360x372"},"9A5F042C80":{"create date":"2019-05-21T18:13:08","last use date":"2019-05-21T18:15:41","name":"Phoscon#B1746x804"},"9B5F91D92A":{"create date":"2019-07-28T07:51:10","last use date":"2019-07-28T07:51:38","name":"Phoscon#B360x380"},"9B8D87A5EA":{"create date":"2019-06-04T15:47:27","last use date":"2019-06-04T15:47:43","name":"Phoscon#B1746x804"},"9C42B5F778":{"create date":"2019-06-06T17:10:14","last use date":"2019-06-06T17:27:21","name":"Phoscon#B1746x804"},"9DEA81C920":{"create date":"2019-05-12T10:54:44","last use date":"2019-05-12T10:56:44","name":"Phoscon#B1746x804"},"9E9E4C470D":{"create date":"2019-05-28T13:19:28","last use date":"2019-05-28T13:35:43","name":"Phoscon#B1746x742"},"9EE69495B7":{"create date":"2019-04-16T15:24:19","last use date":"2019-07-29T09:44:04","name":"homebridge-hue#phoscon"},"9EEA712B17":{"create date":"2019-07-30T07:08:17","last use date":"2019-07-30T07:09:30","name":"Phoscon#B854x857"},"A0239A2487":{"create date":"2019-06-30T12:31:06","last use date":"2019-06-30T12:32:27","name":"Phoscon#B1862x857"},"A154375B79":{"create date":"2019-04-20T20:07:19","last use date":"2019-07-30T16:22:06","name":"homebridge-hue#phoscon"},"A1ED06D8EB":{"create date":"2019-07-20T18:50:18","last use date":"2019-07-20T18:50:39","name":"Phoscon#B1862x857"},"A227D9C773":{"create date":"2019-07-07T08:29:07","last use date":"2019-07-07T08:36:46","name":"Phoscon#B1862x857"},"A23D8B160F":{"create date":"2019-07-29T19:41:25","last use date":"2019-07-29T19:41:44","name":"Phoscon#B1862x857"},"A2870486C1":{"create date":"2019-05-09T17:09:13","last use date":"2019-05-09T17:14:16","name":"Phoscon#B1746x804"},"A438D21B31":{"create date":"2019-05-06T18:34:36","last use date":"2019-05-06T18:38:48","name":"Phoscon#B1746x804"},"A46EA539C3":{"create date":"2019-07-25T08:47:32","last use date":"2019-07-25T08:47:37","name":"Phoscon#B1862x857"},"A499C10EBA":{"create date":"2019-04-16T15:23:49","last use date":"2019-07-30T11:45:02","name":"homebridge-hue#phoscon"},"A6B1AF1CEE":{"create date":"2019-07-05T20:40:50","last use date":"2019-07-05T20:41:26","name":"Phoscon#B1862x857"},"A7DD2EDB92":{"create date":"2019-07-08T16:28:04","last use date":"2019-07-08T16:32:03","name":"Phoscon#B360x380"},"A7F0842CFA":{"create date":"2019-06-21T20:33:43","last use date":"2019-06-21T20:35:20","name":"Phoscon#B1746x804"},"A91C549DD0":{"create date":"2019-04-26T03:10:42","last use date":"2019-04-26T03:10:51","name":"Phoscon#B1397x643"},"AA46D107BF":{"create date":"2019-07-05T19:40:35","last use date":"2019-07-05T19:45:16","name":"Phoscon#B1862x857"},"AAF0A0048F":{"create date":"2019-04-18T13:34:06","last use date":"2019-04-18T13:35:19","name":"Phoscon#B1397x643"},"AAF266952D":{"create date":"2019-05-04T12:26:31","last use date":"2019-05-04T12:31:46","name":"Phoscon#B1746x804"},"AB7173D345":{"create date":"2019-06-27T16:37:09","last use date":"2019-06-27T16:39:37","name":"Phoscon#B1862x857"},"AC372E10A9":{"create date":"2019-05-01T08:19:32","last use date":"2019-05-01T08:23:06","name":"Phoscon#B1746x804"},"AE6EF36CD7":{"create date":"2019-06-30T16:44:56","last use date":"2019-06-30T16:45:24","name":"Phoscon#B1862x857"},"AF95F5DA83":{"create date":"2019-06-10T10:20:03","last use date":"2019-06-10T10:20:18","name":"Phoscon#B1746x804"},"AFBAD02B47":{"create date":"2019-05-25T10:09:55","last use date":"2019-05-25T10:22:03","name":"Phoscon#B1746x804"},"B081CB01B8":{"create date":"2019-05-10T18:46:23","last use date":"2019-05-10T18:48:51","name":"Phoscon#B1746x804"},"B0820275C7":{"create date":"2019-04-17T08:10:45","last use date":"2019-04-17T08:10:52","name":"Phoscon#B1397x643"},"B1E7F389D5":{"create date":"2019-06-06T16:21:52","last use date":"2019-06-06T16:25:40","name":"Phoscon#B1746x804"},"B2EADFEE79":{"create date":"2019-05-28T03:48:25","last use date":"2019-05-28T03:50:01","name":"Phoscon#B1746x804"},"B2F9DBDF9D":{"create date":"2019-05-18T17:23:43","last use date":"2019-05-18T17:24:19","name":"Phoscon#B1746x804"},"B39320C06A":{"create date":"2019-06-24T17:02:44","last use date":"2019-06-24T17:03:43","name":"Phoscon#B1746x804"},"B3CEA50892":{"create date":"2019-05-01T06:07:38","last use date":"2019-05-01T06:28:18","name":"Phoscon#B1746x804"},"B56F0C8EE1":{"create date":"2019-04-20T14:43:36","last use date":"2019-04-20T14:43:39","name":"Phoscon#B1397x643"},"B7B03DCBD2":{"create date":"2019-06-16T18:03:05","last use date":"2019-06-16T18:03:11","name":"Phoscon#B1746x804"},"B856320AC2":{"create date":"2019-05-03T16:14:07","last use date":"2019-05-03T16:14:32","name":"Phoscon#B1746x804"},"BC43981283":{"create date":"2019-05-25T19:59:05","last use date":"2019-05-25T19:59:30","name":"Phoscon#B1746x804"},"BD42F0CB5F":{"create date":"2019-04-23T13:56:18","last use date":"2019-04-23T13:57:11","name":"Phoscon#B360x372"},"BD6BCA8FB5":{"create date":"2019-04-30T13:25:58","last use date":"2019-04-30T16:34:34","name":"Phoscon#B1397x643"},"BD8BF42098":{"create date":"2019-06-03T18:45:44","last use date":"2019-06-03T19:04:26","name":"Phoscon#B360x428"},"BE0A68A114":{"create date":"2019-05-27T20:25:15","last use date":"2019-05-28T18:17:02","name":"Phoscon#B360x428"},"BE3C21DF40":{"create date":"2019-05-09T19:02:14","last use date":"2019-05-09T19:02:52","name":"Phoscon#B1746x804"},"C08BDB3ABF":{"create date":"2019-07-25T19:55:49","last use date":"2019-07-25T19:56:50","name":"Phoscon#B1862x857"},"C1290573D7":{"create date":"2019-04-27T06:23:54","last use date":"2019-04-27T06:26:47","name":"Phoscon#B1397x643"},"C30E7DE1EF":{"create date":"2019-06-09T20:54:22","last use date":"2019-06-09T20:54:57","name":"Phoscon#B1746x804"},"C37B5938E5":{"create date":"2019-05-29T15:28:14","last use date":"2019-05-29T15:40:53","name":"Phoscon#B1746x804"},"C52799C325":{"create date":"2019-05-06T18:16:29","last use date":"2019-05-06T18:16:50","name":"Phoscon#B1746x804"},"C5C34B4E01":{"create date":"2019-07-06T18:20:44","last use date":"2019-07-06T18:27:58","name":"Phoscon#B1862x857"},"C5EFBAFC2E":{"create date":"2019-05-08T17:54:15","last use date":"2019-05-08T17:57:07","name":"Phoscon#B1746x804"},"C821C4E5EA":{"create date":"2019-05-21T13:12:35","last use date":"2019-05-21T13:14:55","name":"Phoscon#B1746x804"},"C82AB30478":{"create date":"2019-07-11T09:45:38","last use date":"2019-07-11T09:46:03","name":"Phoscon#B1862x857"},"C9B43FC0E0":{"create date":"2019-06-02T16:09:13","last use date":"2019-06-02T16:09:29","name":"Phoscon#B1746x804"},"CA127044A4":{"create date":"2019-05-30T19:06:27","last use date":"2019-05-30T19:54:50","name":"Phoscon#B360x372"},"CAAC9A823B":{"create date":"2019-04-23T16:43:15","last use date":"2019-04-23T16:43:19","name":"Phoscon#B1397x643"},"CAB607051E":{"create date":"2019-04-29T18:12:43","last use date":"2019-07-26T19:53:07","name":"Phoscon#B1397x643"},"CCEB426714":{"create date":"2019-06-07T21:28:46","last use date":"2019-06-07T21:36:37","name":"Phoscon#B360x428"},"CD25549246":{"create date":"2019-07-12T00:14:11","last use date":"2019-07-12T00:20:46","name":"Phoscon#B1862x857"},"CDA93402B2":{"create date":"2019-07-05T15:09:01","last use date":"2019-07-05T15:15:09","name":"Phoscon#B360x380"},"CEAA643316":{"create date":"2019-05-25T11:39:20","last use date":"2019-05-25T11:43:24","name":"Phoscon#B1746x804"},"CEBBAAE346":{"create date":"2019-07-19T23:18:08","last use date":"2019-07-19T23:21:16","name":"Phoscon#B1862x857"},"D0FEF1DC18":{"create date":"2019-05-13T14:32:59","last use date":"2019-05-13T14:33:06","name":"Phoscon#B1746x804"},"D178D0E1FB":{"create date":"2019-04-22T07:47:34","last use date":"2019-04-22T07:47:44","name":"Phoscon#B1397x643"},"D279EE0F45":{"create date":"2019-07-22T12:22:48","last use date":"2019-07-30T15:15:48","name":"Phoscon#B1862x857"},"D471D45099":{"create date":"2019-04-24T18:11:07","last use date":"2019-04-24T18:11:17","name":"Phoscon#B1397x643"},"D547DE5857":{"create date":"2019-05-02T16:43:58","last use date":"2019-05-02T16:44:40","name":"Phoscon#B1552x715"},"D57F9B1F3E":{"create date":"2019-06-22T05:36:04","last use date":"2019-06-22T05:38:19","name":"Phoscon#B1746x804"},"D5E97A7288":{"create date":"2019-06-03T14:23:34","last use date":"2019-06-03T16:28:56","name":"Phoscon#B360x372"},"D725AAB0D3":{"create date":"2019-05-25T15:34:54","last use date":"2019-05-25T15:35:36","name":"Phoscon#B1746x804"},"D7AD2A6B98":{"create date":"2019-04-28T12:06:04","last use date":"2019-04-28T17:09:43","name":"Phoscon#B1397x643"},"D80F2D0680":{"create date":"2019-07-29T20:07:10","last use date":"2019-07-30T03:42:01","name":"Phoscon#B1862x857"},"D9404EA9EE":{"create date":"2019-05-02T13:34:20","last use date":"2019-05-02T13:34:51","name":"Phoscon#B1552x715"},"D9ED485B8E":{"create date":"2019-04-29T15:31:32","last use date":"2019-04-29T15:35:35","name":"Phoscon#B1397x643"},"DA1DB6D58A":{"create date":"2019-04-25T17:45:45","last use date":"2019-04-25T17:45:48","name":"Phoscon#B1397x643"},"DA63AA2BA9":{"create date":"2019-06-25T13:18:06","last use date":"2019-06-25T13:19:39","name":"Phoscon#B1746x804"},"DAD9528D9C":{"create date":"2019-04-19T11:06:25","last use date":"2019-04-19T11:08:16","name":"Phoscon#B1397x643"},"DB6250B365":{"create date":"2019-05-29T13:29:39","last use date":"2019-05-29T13:31:39","name":"Phoscon#B1746x804"},"DCC6E6DBC0":{"create date":"2019-04-23T19:11:00","last use date":"2019-04-23T19:11:55","name":"Phoscon#B1397x643"},"DDE91ECAA8":{"create date":"2019-07-21T11:21:13","last use date":"2019-07-21T11:22:05","name":"Phoscon#B1862x857"},"DE9F60B8C3":{"create date":"2019-06-27T13:39:37","last use date":"2019-06-":{"create date":"2019-05-17T18:03:35","last use date":"2019-05-17T18:17:49","name":"Phoscon#B1746x804"}},"zigbeechannel":11}-
Thorgal789
- Target OS: -
You have it in domoticz deconz plugin folder, on my configuration "~/domoticz/plugins/deCONZ"
To have all exemples
To generate your api key (don't forget authenticate else no pannic, you will just have error message)
You can use it too to list all your api keys, but, you can clean them, not possible to delete them one by one, like for me, it's too late, you have too much of them ^^.
python3 API_KEY.pyCode: Select all
python3 API_KEY.py 127.0.0.1:80 create-
salopette
Is it correct that way?
pi@raspberrypi:~/domoticz/plugins/Domoticz-deCONZ $ python3 API_KEY.py 127.0.0.1:80 create
File "/usr/lib/python3.5/urllib/request.py", line 1254, in do_open
h.request(req.get_method(), req.selector, req.data, headers)
File "/usr/lib/python3.5/http/client.py", line 1107, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
self.endheaders(body)
File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
self.send(msg)
File "/usr/lib/python3.5/http/client.py", line 877, in send
self.connect()
File "/usr/lib/python3.5/http/client.py", line 849, in connect
(self.host,self.port), self.timeout, self.source_address)
File "/usr/lib/python3.5/socket.py", line 712, in create_connection
raise err
File "/usr/lib/python3.5/socket.py", line 703, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File "API_KEY.py", line 25, in <module>
response = request.urlopen(req).read()
File "/usr/lib/python3.5/urllib/request.py", line 163, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.5/urllib/request.py", line 466, in open
response = self._open(req, data)
File "/usr/lib/python3.5/urllib/request.py", line 484, in _open
'_open', req)
File "/usr/lib/python3.5/urllib/request.py", line 444, in _call_chain
result = func(*args)
File "/usr/lib/python3.5/urllib/request.py", line 1282, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.5/urllib/request.py", line 1256, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 111] Connection refused>
File "API_KEY.py", line 31, in <module>
if e.code == 403:
AttributeError: 'URLError' object has no attribute 'code'
salopette
or so? Then there is no message.
python3 API_KEY.py 192.168.178.37:8089 create
Thorgal789
- Target OS: -
I think port is 80 too,it's the port you are using in the deconz plugin too on domoticz, on the previous link you acess to config with "192.168.178.93/api/6B98A2619A/config" so, I think you are using http port : 80
Have you deconz on the same raspberry ? I m using 127.0 0.1 because on my side domoticz and deconz are on the same raspberry.
python3 API_KEY.py 192.168.178.93:80 create ?
salopette
I have 2 Pi's, on 192.168.178.37:8089 is domoticz with your plugin and on 192.168.178.93 is only Deconz with the ConBee II stick!
