Domoticz status widget  [Solved]
Hydci
Domoticz version: 4.10717
Post by Hydci »
I would like to know if it was possible in Dzvent to have a check of the widget domoticz and applied to the light the command corresponding to the status of the widget domoticz because of times a light and lit following a breakdown of electricity and I would like that domoticz turn off the light if this one and I use a lua script that I found but I would like a Dzvent
Any help to write the Dzvent would be welcome thank you
Dzvent
Every 2 mins
Check domoticz status (off)
check light bulb (on)
Command off
--recupere les minutes
time=os.time()
minutes=tonumber(os.date('%M',time))
hours=tonumber(os.date('%H',time))
print('!*!*!*!*!*!*!*!*!Lancement du check à '..hours..'h'..minutes)
-------Toutes les 15 minutes
if( (minutes==5) or (minutes==10) or (minutes==15) or (minutes==20) or (minutes==25) or (minutes==30) or (minutes==35) or (minutes==40) or (minutes==45) or (minutes==50) or (minutes==55) ) then
	-- Put your script code here that shall run every 5 minutes
 --------Renforcement des envois de signal-------------------------------------
   print('check de tous les materiels rfxcom (sans retour d\'etat)');
   local check={}
   --Chauffage
   check['0']='SAM'
   --Parcours le Tableau
   for key, valeur in pairs(check) do
      print ('CHECK : '..valeur.. ' -> ' ..otherdevices[valeur])
      commandArray[valeur]=otherdevices[valeur]
 --------FIN Renforcement des envois de signal-------------------------------------
Re: Domoticz status widget
Hydci wrote: Friday 19 July 2019 19:40 Dzvent
Every 2 mins
Command off
My understanding from your Lua script is that you want to resend the current state of all switch devices.
so if a device.state == "On" , you want to send device.switchOn() and vice versa.
Is my understanding correct ?
Hydci
Post by Hydci »
Hello, that's fine you understand my request unfortunately I do not know how to take it I would like to do that if the widget says off and the light on and then turn it off if possible
Re: Domoticz status widget  [Solved]
Hydci wrote: Sunday 21 July 2019 11:31 Hello, that's fine you understand my request unfortunately I do not know how to take it I would like to do that if the widget says off and the light on and then turn it off if possible
I don't know how to do that either. Below script just resends the current state of switch like devices.
return
    on  = { timer = { 'every 2 minutes' }},
    execute = function(dz)
        dz.devices().
            filter(function(dv)
                    return (dv.switchType == 'On/Off' and dv.deviceType == 'Light/Switch' )
            end).
            forEach(function(dv)
                if dv.active then
                    dv.switchOn().silent()
                    dz.log('Resending On command to ' .. dv.name )
                    dv.switchOff().silent()
                    dz.log('Resending Off command to ' .. dv.name )
            end)
