I have a P1 Smart Meter connected to my Domoticz. Works great, the newest smart meters even send their info every second. But that results in a log line every second, which is not needed (used DB space, keeps HDDs out of sleep, etc.) and pushing back real log entries.
Is there a way to disable logging for 1 device?
Disable log for 1 device
- solidum90
- Domoticz version: Debian
Re: Disable log for 1 device
I'm interested too..!
- emme
- Domoticz version: latest
+1
would be nice the possibility to limit to n-days also
"We always done this way"
- Louk
- Domoticz version: 2022.2 β
Since some weeks I'm using Domoticz on my Synology NAS as alternative for a bricked VERA (by connecting a powered USB hub, but that's a complete different story).
After a lot of struggling while configuring the setup, that includes an intelligent energy meter (P1), it run's quite smoothly. Except for one nasty issue: The Domoticz server stops or hangs at least once a week. After some investigation, I found that there was a HUGE log file, mostly filled with useless messages about receiving data from the P1 interface.
Now I want to disable this (useless) logging, for this device, all devices, or even all logging at once. I understand from this forum that the first option is not supported. I found a configuration file (/usr/local/domoticz/var/scripts/domoticz.conf. This file contains lines (commented out) to enable logging, selecting the log file, and options to log. However changing this file does not seem to make any difference.
I also found (guided by this forum
) the start script for the Domoticz service that contains the following line:
Now I wonder what happens when I remove the log file spec, or even better, if I could add an option to include the config, so I can reduce the log file to error messages only?
PS.: I know this is a reply on an older post, but it's about the same issue (too much logging, caused by the P1 interface) and there is still no solution for this.
su ${USER} -c "${DOMOTICZ} -www ${PORT} -wwwroot ${WWWROOT} -sslwww ${RSSLPORT} -sslcert ${RSSLCERT} -approot ${INSTALL_DIR}/ -userdata ${INSTALL_DIR}/var/ -dbase ${DB_FILE} -log ${LOGFILE} & echo \$! > ${PID_FILE} "
Have fun,
Louk
Louk
- gizmocuz
Why do you need to store a log file ?
This could only be useful while debugging, after just do not do this
There are command line options to specify to only log warnings/errors
- Louk
Normally I don't need log files at all, but because Domoticz crashes or just stops every 5 to 7 days, I want to see what is going on.
Where do I find these command line options to customize the logging options? Or how do I force Domoticz to use this option file (which isn't there for nothing, I suppose)?
Have fun,
Louk
Louk
- waaren
Please have a look at this crosspost
