dzVents for-loop doesn't trigger  [Solved]
imdos
Domoticz version: 2023.2
Post by imdos »
I'm trying to get this function to work; but it doesn't trigger due to some logic problem or other error. Someone who could help me out with this.
When I change the timer to every minute and turn on debug I only get the following information.
Status: dzVents: Info:  Nintendo: ------ Start external script: Nintendo.lua:, trigger: every minute
Status: dzVents: Debug: Nintendo: Processing device-adapter for $blink_blauw: Switch device adapter
Status: dzVents: Debug: Nintendo: Processing device-adapter for $blink_geel: Switch device adapter
Status: dzVents: Debug: Nintendo: Processing device-adapter for $Vloer-LED-B: Switch device adapter
Status: dzVents: Debug: Nintendo: Processing device-adapter for $Vloer-LED-Y: Switch device adapter
Status: dzVents: Info:  Nintendo: ------ Finished Nintendo.lua
All LEDs are off.
The actual script
 Nintendo
als de switch of wii langer dan 35 minuten aanstaat, dan de blauwe LED laten knipperen. Als dat apparaat uit is dan LED weer uitzetten.
        active = true,
				devices = { 'Wii', 'N_Switch' },
                timer = { 'every 5 minutes' },
logging = {
        level = domoticz.LOG_ERROR,		-- change to LOG_ERROR when script executes OK
	-- domoticz.LOG_DEBUG
        marker = 'Nintendo',
-- dzVents 2.4 functie:
        execute = function(domoticz,item)
        local blauwblink = domoticz.devices('$blink_blauw')
        local geelblink = domoticz.devices('$blink_geel')
        local blauw = domoticz.devices('$Vloer-LED-B')
        local geel = domoticz.devices('$Vloer-LED-Y')
        -- local deviceToCheck = domoticz.devices().forEach(function(devicesToCheck)
        local devicesToCheck = { 'Wii', 'N_Switch' }
        local thresholdx = 35
	local Time = require('Time')
	-- setup
        if ( item.isTimer ) then
		for i, deviceToCheck in pairs(devicesToCheck) do
                -- local minuten = domoticz.devices(deviceToCheck).lastUpdate.minutesAgo
			local minuten = Time(deviceToCheck.lastUpdate)
				-- Actual check!
		-- if ( deviceToCheck.active and minuten.minutesAgo > thresholdx ) then
                        if ( blauw.active ) then
                                domoticz.log('De blauwe LED staat al aan!')
                                blauwblink.switchOn()
                                domoticz.log('De blauwe LED knippert...')
                                domoticz.notify("Domoticz", "De " .. domoticz.devices(deviceToCheck) .. "staat al meer dan 35 minuten aan", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , "telegram")
		if ( item.isDevice and not item.active ) then
			blauwblink.switchOff().checkFirst()
			-- blauw.switchOff().checkFirst()
            domoticz.log('De blauwe LED knippert niet meer!')
The previous checks are commented right now and I have adjusted my code to resemble the example from the wiki.
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
Re: dzVents for-loop doesn't trigger  [Solved]
imdos wrote: Tuesday 16 July 2019 13:18 I'm trying to get this function to work; but it doesn't trigger due to some logic problem or other error. Someone who could help me out with this.
Could well be I do not completely understand your requirements but can you test this and revert with your findings ?
 Nintendo
local allDevices = {'Wii', 'N_Switch'}
return
    on = { devices = allDevices },
    logging = { level = domoticz.LOG_DEBUG, marker = 'Nintendo' },
    execute = function(dz, item)
        local blauwblink = dz.devices('$blink_blauw')
        local maxOnTime = 35
        local allWithinLimits = true
        for _, name in ipairs(allDevices) do
            if dz.devices(name).active then
                blauwblink.switchOn().afterMin(maxOnTime).checkFirst()
                allWithinLimits = false
        if allWithinLimits then
            blauwblink.cancelQueuedCommands()
