I have been searching but can not find anything, nor in the wiki, nor on the forum how this must be setup, or how it should work.
Could someone explain me how this discomode works for yeelights? Please.
I saw in an old post from 2017 an url like: http://<domoticz>host:8080/json.htm?type=command¶m=discomodenum1&idx=6
when i do this i see the answer from the light discomode 1 is active and ok.
But I have no clue what to do, or how it should work? The light just stays on.
Does anyone have a link for me where i can read what to do?
Also i read in the wiki the following: "Added support for Lighting Limitless/Applamp RGBW devices. You can now set Kelvin and RGB values, NightMode, WhiteMode and increase and decrease the brightness and discoMode. See the documentation."
But what documentation, where can i find this?
Thanks in advance.
Discomode
poudenes
- Domoticz version: 3.8993
Re: Discomode
You can set everything you want. I use dzvents script. Check wiki of dzvents.
Verzonden vanaf mijn iPhone met Tapatalk Pro
- Thuis
Re: Discomode
I can set everything i want, but what does it mean, discomode 1, 2 ,3 ,4 etc. is it a pre defined mode, or do i have to define the modes ?
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
poudenes
Re: Discomode
They pre defined in the Bulb (hardware by manufacturer). Try all of them to see what pattern you see.Thuis wrote: Thursday 04 July 2019 9:21 I can set everything i want, but what does it mean, discomode 1, 2 ,3 ,4 etc. is it a pre defined mode, or do i have to define the modes ?
- EdwinK
- Domoticz version: BETA
Re: Discomode
poudenes wrote: Thursday 04 July 2019 11:01They pre defined in the Bulb (hardware by manufacturer). Try all of them to see what pattern you see.Thuis wrote: Thursday 04 July 2019 9:21 I can set everything i want, but what does it mean, discomode 1, 2 ,3 ,4 etc. is it a pre defined mode, or do i have to define the modes ?
Tried them also, but nothing happens
- Thuis
Re: Discomode
ok thanks, i just think i do not understand how it works, so was asking if some one does know how it works, but it seems no one knows. Ha
