Expanding variables and arrays [Solved]
- Varazir
Hello again,
I'm not doing this right and don't know how to google for it
I could do it in bash but LUA it's a bit harder.
I like to use something like this $domoticz.globalData.$currentGroup[1]
This is what I have done so far.
Brightness.lua and ikeaSelect.lua works if I don't use arrays
I have hard set few values for testing
https://gist.github.com/varazir/f611418 ... cdaabee311
Basically I like a variable to be expanded and used as variable name.
But I should maybe work with a object s
globObjGroups = { initial = { "Hallway": [ 65 ], "BedRoom": [ 13 ], "TvBench": [ 42, 74, 45, 43 ] } },
Something like this (JSON)
https://jsoneditoronline.org/?id=37989d ... fa38988a66
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
- waaren
Re: Expanding variables and arrays
I don't understand this approach. Can you please explain in laymen's terms what you try to achieve and why ? Maybe this would help me understand better.Varazir wrote: Monday 01 July 2019 11:37 I like to use something like this $domoticz.globalData.$currentGroup[1]
Also please note that you can pass the complete device to a helper function. You don't have to limit yourself to pass the name only.
If you pass the name a string is passed to the function. If you pass the device (= Lua table) only a pointer is passed to the function so no disadvantage there in terms of performance or resource usage.
- Varazir
Okay, I think I'm doing it the wrong way.waaren wrote: Monday 01 July 2019 13:13I don't understand this approach. Can you please explain in laymen's terms what you try to achieve and why ? Maybe this would help me understand better.Varazir wrote: Monday 01 July 2019 11:37 I like to use something like this $domoticz.globalData.$currentGroup[1]
To start I have:
One "5 button" zigbee remote
5 groups with 1 - 4 devices per group
I like to control all groups with one remote.
Pressing the right or left button will switch to the next/previous group of devices
1 switch in the selected group should blink ones to indicate it's selected
Middle button should be able to toggle the current groups devices.
The button up and down should change the level for all devices in the group if it is supported.
- waaren
Are the groups and devices in these groups defined in a dzVents script or somewhere else ?Varazir wrote: Monday 01 July 2019 14:00 I like to control all groups with one remote.
Do you mean that one light in the group is switched on and off after a second ? And if it is already on switched Off and On again after a second ?1 switch in the selected group should blink ones to indicate it's selected
On -> Off / Off -> On ?Middle button should be able to toggle the current groups devices.
Should be doable. My approach would be to do this in one script without using global_data. Using a multi level table like this example.The button up and down should change the level for all devices in the group if it is supported.
control =
group1 = {
device1 = { toggle = true, dimmer = true, blink = true},
device2 = {toggle = true},
device3 = {dimmer = true},
group2 = {
device4 = {toggle = true},
device5 = { toggle = true, blink = true},
device6 = { dimmer = true}
for group, devices in pairs(control) do
for device, attributes in pairs(devices) do
for attribute, value in pairs(attributes) do
print (group .. '.' .. device .. '.' .. attribute)
endDebian buster, bullseye on RPI-4, Intel NUC.
- Varazir
Yes, but only the each idx for each device, you see it in the global lua filewaaren wrote: Monday 01 July 2019 15:07Are the groups and devices in these groups defined in a dzVents script or somewhere else ?Varazir wrote: Monday 01 July 2019 14:00 I like to control all groups with one remote.
Yeswaaren wrote: Monday 01 July 2019 15:07Do you mean that one light in the group is switched on and off after a second ? And if it is already on switched Off and On again after a second ?1 switch in the selected group should blink ones to indicate it's selected
Yeswaaren wrote: Monday 01 July 2019 15:07On -> Off / Off -> On ?Middle button should be able to toggle the current groups devices.
You gave me the solution in another post, I just moved it to the global_data file but I guess it could be in the samewaaren wrote: Monday 01 July 2019 15:07Should be doable. My approach would be to do this in one script without using global_data. Using a multi level table like this example.The button up and down should change the level for all devices in the group if it is supported.
I was looking for something like that kind of table.waaren wrote: Monday 01 July 2019 15:07
So test if the attribute is set using nested for loops.Code: Select all
control = { group1 = { device1 = { toggle = true, dimmer = true, blink = true}, device2 = {toggle = true}, device3 = {dimmer = true}, }, group2 = { device4 = {toggle = true}, device5 = { toggle = true, blink = true}, device6 = { dimmer = true} }, } for group, devices in pairs(control) do for device, attributes in pairs(devices) do for attribute, value in pairs(attributes) do print (group .. '.' .. device .. '.' .. attribute) end end end
But I need a way to select the group as well
- waaren
Re: Expanding variables and arrays [Solved]
Please have a look at this code. It should not be to difficult to translate the log statements into real actionsVarazir wrote: Monday 01 July 2019 17:10 I was looking for something like that kind of table.
-- OneRemoteToControlAll.lua
local scriptVar = 'remoteControl'
local groups = {'group1', 'group2', 'group3' }
return
on = { devices = { scriptVar }},
logging = { level = domoticz.LOG_DEBUG, marker = scriptVar },
data = { currentGroup = { initial = 1 }},
execute = function(dz, item)
control =
group1 =
device2 = { toggle = true},
device3 = { dimmer = true},
group2 =
device4 = { toggle = true},
group3 =
device7 = { toggle = true},
device8 = { toggle = true, blink = true},
device9 = { dimmer = true}
local selectedGroupNumber = dz.data.currentGroup
local maxGroup = #groups
local function doAction(action, direction)
selectedGroup = groups[selectedGroupNumber]
for device, attributes in pairs(control[selectedGroup]) do
if attribute == action then
dz.log(device .. " will " .. action)
if action == 'dimmer' then
dz.log(device .. " direction is " .. direction)
local action = 'blink'
local direction = 'up'
if item.state == 'left' then
selectedGroupNumber = selectedGroupNumber - 1
if selectedGroupNumber == 0 then selectedGroupNumber = maxGroup end
elseif item.state == 'right' then
selectedGroupNumber = selectedGroupNumber + 1
if selectedGroupNumber > maxGroup then selectedGroupNumber = 1 end
elseif item.state == 'push' then
action = 'toggle'
elseif item.state == 'up' then
action = 'dimmer'
elseif item.state == 'down' then
action = 'dimmer'
direction = 'down'
dz.log('Unknown action requested; ignored' )
return
dz.data.currentGroup = selectedGroupNumber
}Debian buster, bullseye on RPI-4, Intel NUC.
- Varazir
Looks like I can work with that.
Didn't say from the start that each button on remote is assigned it's own device.
That has the State Off, Click, Press and release.
I guess I can change
item.state == 'left'Code: Select all
item.state == "Click" and item.name == "IKEA Switch Left Arrow" It's the function I use to dim devices
local dimDevice = domoticz.devices(device)
local dimLevel = dimDevice.level
local delay = 0
if state == "Hold" then
repeat
delay = delay + 0.1
dimLevel = dimLevel - 1
domoticz.log('Set ' .. dimDevice.name .. ' to dimLevel '.. dimLevel .. '%, after ' .. delay .. ' seconds', domoticz.LOG_INFO)
dimDevice.dimTo(dimLevel).afterSec(delay)
until dimLevel <= 0
elseif state == "Release" then
domoticz.log('Stop dimming of ' .. dimDevice.name .. ' at ' .. dimLevel ..'%', domoticz.LOG_INFO)
dimDevice.cancelQueuedCommands()
if dimDevice.level == 0 then
dimDevice.switchOff()
endOr if you can check if there are a cue running I could do something like this
if item.state == "Click" and item.name == "IKEA Switch Brightness Down"
if item.QueuedCommands() then
item.cancelQueuedCommands()
repeat
delay = delay + 0.1
until dimLevel <= 0
endRaspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
- Varazir
I did this, but I guess numbers can't be used as variable names.
Tried to add the name of the device but it failed as well.
local scriptVar = 'IKEA Remote Down',
'IKEA Remote Up',
'IKEA Remote Left',
'IKEA Remote Right',
'IKEA Remote Toggle'
return
control =
group3 = --Hallway
40 = { toggle = true, dimmer = true, blink = true},
15 = { toggle = true, dimmer = true},
17 = { toggle = true, dimmer = true},
19 = { toggle = true, dimmer = true}
group1 = --Bedroom
13 = { toggle = true, blink = true, dimmer = true}
group4 = --Lilvingroom
21 = { toggle = true, dimmer = true},
23 = { toggle = true, dimmer = true, blink = true},
25 = { toggle = true, dimmer = true}
group6 = --Computeroom
73 = { toggle = true, blink = true},
group5 = --TvBench
OnkyoHW = { toggle = true},
42 = { toggle = true, blink = true},
45 = { toggle = true},
43 = { toggle = true}
group2 = --BedroomBlilnder
59 = { toggle = true, dimmer = true },
if action == 'blink' then
local blinkDevice = domoticz.devices(device)
if blinkDevice.state == "Off" then
blinkDevice.switchOn()
blinkDevice.switchOff()
local delay = 0
if dimDevice.QueuedCommands() then
repeat
delay = delay + 0.1
if direction == "down" then dimLevel = dimLevel - 1 else dimLevel = dimLevel + 1 end
dz.log('Set ' .. item.name .. ' to dimLevel '.. dimLevel .. '%, after ' .. delay .. ' seconds', dz.LOG_INFO)
item.dimTo(dimLevel).afterSec(delay)
until dimLevel <= 0
if item.state == 'Click' and item.name "IKEA Remote Left" then
elseif item.state == 'Click' and item.name "IKEA Remote Right" then
elseif item.name "IKEA Remote Toggle" then
action = 'toggle'
elseif item.state == 'Click' and item.name "IKEA Remote Up" then
action = 'dimmer'
elseif item.state == 'Click' and item.name "IKEA Remote Down" then
action = 'dimmer'
direction = 'down'
return
item.switchOff().silent()
}Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
- waaren
You guessed right. At least not like this. May I suggest that you have a look at some of the excellent pages on Lua.org ?Varazir wrote: Monday 01 July 2019 21:33 I did this, but I guess numbers can't be used as variable names.
It will save you a lot of frustration and time.
Try to use this as triggerTried to add the name of the device but it failed as well.
on = { devices = { 'IKEA Remote*' }},
- Varazir
I have been looking at that site but not sure what to look for or if I'm on the correct path.
Skickat från min EML-L29 via Tapatalk
- waaren
For most people who programmed before in other languages, the table type is not the easiest part of Lua but yet they present a very important part of the language and they are also frequently used in many areas in the dzVents API. If you understand the main aspects of Lua tables then you are more than halfway..Varazir wrote: Tuesday 02 July 2019 9:24 I have been looking at that site but not sure what to look for or if I'm on the correct path.
this is a good start
- Varazir
I think I have a workaround.waaren wrote: Tuesday 02 July 2019 9:43For most people who programmed before in other languages, the table type is not the easiest part of Lua but yet they present a very important part of the language and they are also frequently used in many areas in the dzVents API. If you understand the main aspects of Lua tables then you are more than halfway..Varazir wrote: Tuesday 02 July 2019 9:24 I have been looking at that site but not sure what to look for or if I'm on the correct path.
Back to the queued commands, can you test that?
If the device has any queued commands that is
- Varazir
I keep getting this and I don't understand whywaaren wrote: Tuesday 02 July 2019 9:43For most people who programmed before in other languages, the table type is not the easiest part of Lua but yet they present a very important part of the language and they are also frequently used in many areas in the dzVents API. If you understand the main aspects of Lua tables then you are more than halfway..Varazir wrote: Tuesday 02 July 2019 9:24 I have been looking at that site but not sure what to look for or if I'm on the correct path.
2019-07-02 11:41:40.333 Error: EventSystem: in test: [string "groups = {'group1', 'group2', 'group3', 'grou..."]:6: attempt to index global 'domoticz' (a nil value)Code: Select all
Error: EventSystem: Lua script test did not return a commandArray
groups = {'group1', 'group2', 'group3', 'group4', 'group5', 'group6' }
logging = { level = domoticz.LOG_DEBUG, marker = "IKEARemote" },
control =
group3 = --Hallway
lamp = { idx = 40, toggle = true, dimmer = true, blink = true},
spot1 = { idx = 15, toggle = true, dimmer = true},
spot2 = { idx = 17, toggle = true, dimmer = true},
spot3 = { idx = 19, toggle = true, dimmer = true}
group1 = --Bedroom
lamp = { idx = 13, toggle = true, blink = true, dimmer = true}
spot1 = { idx = 21, toggle = true, dimmer = true},
spot2 = { idx = 23, toggle = true, dimmer = true, blink = true},
spot3 = { idx = 25, toggle = true, dimmer = true}
lamp = { idx = 73, toggle = true, blink = true},
group5 = --TvBench
lamp = { idx = 42, toggle = true, blink = true},
onkyoHW = { idx = 19, toggle = true},
tv = { idx = 45, toggle = true},
onkyo = { idx = 43, toggle = true}
blinder = { idx = 59, toggle = true, dimmer = true },
if attribute == idx then local idx = attribute.idx end
local blinkDevice = dz.devices(idx)
local blinkLevel = dz.devices(idx)
blinkDevice.switchOn().dimTo(blinkLevel)
blinkDevice.switchOff().dimTo(blinkLevel)
local dimDevice = dz.devices(idx)
local delay = 0
repeat
delay = delay + 0.1
until dimLevel <= 0
action = 'toggle'
action = 'dimmer'
action = 'dimmer'
direction = 'down'
return
- waaren
If you see this message you saved your script as classic domoticz Lua and not as dzVents.Varazir wrote: Tuesday 02 July 2019 11:46 Error: EventSystem: Lua script test did not return a commandArray
- waaren
No need to test because the method QueuedCommands does not exist and there is no way to get that kind of information from domoticz in dzVents or any other event driven API. You don't need to test if there is a queue. The cancelQueuedCommands() method will not fail if there is no queue.Varazir wrote: Tuesday 02 July 2019 11:15 I think I have a workaround.
Your implementation of blink might not produce the desired effect. Better to code it like
blinkDevice.switchOff().afterSec(0.5)
blinkDevice.switchOn()..afterSec(0.5)
