active = {
true -- either true or false, or you can specify a function
devices = {
'Eettafel switch'
data = {
Scene_number = { initial = 0 }
execute = function(domoticz, triggeredItem, info)
local Device = domoticz.devices('Group Eettafel')
local Device1 = domoticz.devices('Eettafel voor')
local Device2 = domoticz.devices('Eettafel mid voor')
local Device3 = domoticz.devices('Eettafel mid achter')
local Device4 = domoticz.devices('Eettafel achter')
-- domoticz.log('Current Scene is '..Scene_number, domoticz.LOG_INFO)
if (triggeredItem.state == 'Off') then
domoticz.log('I am seeing this Off command...', domoticz.LOG_INFO)
Device.switchOff()
Scene_number = 0
elseif (triggeredItem.state == 'On') then
domoticz.log('I am seeing this On command...', domoticz.LOG_INFO)
if (Scene_number == 0) then -- starting from Off, going Scene_Normal
domoticz.log('Off to Normal', domoticz.LOG_INFO)
Device.dimTo(50)
Device.setKelvin(68)
Scene_number = 1
elseif (Scene_number == 1) then -- starting from Scene_Normal, going Scene_Daglicht
domoticz.log('Normal to Daglicht', domoticz.LOG_INFO)
Device.dimTo(100)
Device.setKelvin(8)
Scene_number = 2
elseif (Scene_number == 2) then -- starting from Scene_Daglicht, going Scene_Avondlichtje
domoticz.log('Daglicht to Avond', domoticz.LOG_INFO)
Device4.dimTo(10)
Device4.setKelvin(75)
Device3.dimTo(10)
Device3.setKelvin(75)
Device2.switchOff()
Device1.switchOff()
Scene_number = 3
elseif (Scene_number == 3) then -- starting from Scene_Avondlichtje, going Scene_Eetlichtje
domoticz.log('Avond to Eet', domoticz.LOG_INFO)
Device.dimTo(5)
Device.setKelvin(90)
Scene_number = 4
elseif (Scene_number == 4) then -- starting from Scene_Eetlichtje, going Scene_Normal
domoticz.log('Eet to Normal', domoticz.LOG_INFO)
Device.dimTo(50)
Scene_number = 1
domoticz.log('The light ' .. Device.name .. ' is switched to Scene number '..Scene_number, domoticz.LOG_INFO)
dzVents: Error (2.4.19): .../domoticz/scripts/dzVents/generated_scripts/Eettafel.lua:62: attempt to concatenate global 'Scene_number' (a nil value)
If I uncomment the first log command, the error changed slightly: The number 62 changed to 22 (the line number of the first log command)
It also doesn't hit any of the Scene_number based [else]if statements.
All this shows me that Scene_number is not initialized nor persistent... What am I missing?..
