Global arrays  [Solved]
Varazir
Global arrays
Post by Varazir »
I'm trying to setup a array in the global_data.lua file
	data = {
		globHallway = { initial = 65 },
		globBedRoom = { initial = 13 },
		globLivingRoom = { initial = 36 },
		globComputerRoom = { initial = 73 },
		globTvBench = { initial = 42, 74, 45, 43 },
		globGroups = { initial = "globHallway", "globBedRoom", "globLivingRoom", "globTvBench" },
		globCurrentGroup = { initial = "globComputerRoom" },
then call it like this
domoticz.globalData.globGroups[1]
But I get a nil value, so I'm doing something wrong.
So I need some help please.
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Re: Global arrays
Varazir wrote: Sunday 30 June 2019 21:15 I'm trying to setup a array in the global_data.lua file
	data = {
You wil have to initialize it as a table. Try this
data =
        myGlobalVar = { initial = 12 },
	globGroups = { initial = { "globHallway", "globBedRoom", "globLivingRoom", "globTvBench" } },
[/quote]
Varazir
Re: Global arrays
Post by Varazir »
Still getting Nil
	-- global persistent data
	data = {
		devices =   {
		                'IKEA Switch Right Arrow'
	    data =      {
	                    loop  = { initial = 0 }
	    logger =    {
	                    level            =  domoticz.LOG_DEBUG,
                        marker           =  "ikeaSelect"
        if (device.state == "Click" )
            then
                if domoticz.data.loop <= 4
                    then
                        domoticz.data.loop = domoticz.data.loop + 1
                        domoticz.data.loop = 1
            currentGroup = domoticz.globalData.globGroups[domoticz.data.loop]
            domoticz.log(domoticz.data.loop, domoticz.LOG_INFO)
            domoticz.log(currentGroup, domoticz.LOG_INFO)
            domoticz.log(device.state, domoticz.LOG_INFO)
            domoticz.log(device.name, domoticz.LOG_INFO)
            domoticz.log(domoticz.globalData.globGroups[2], domoticz.LOG_INFO)
            device.switchOff().silent()
Varazir
Re: Global arrays
Post by Varazir »
I added the array in the triggerd lua file
		devices =   {
	    data =      {
	                    loop  = { initial = 0 },
	    logger =    {
            then
                    then
            -- currentGroup = domoticz.globalData.globGroups[domoticz.data.loop]
            -- domoticz.log(currentGroup, domoticz.LOG_INFO)
            -- domoticz.log(domoticz.globalData.globGroups[2], domoticz.LOG_INFO)
            domoticz.log(domoticz.data.Groups[2], domoticz.LOG_INFO)
The ones I have commented out failed but domoticz.data.Groups[2] works.
Re: Global arrays  [Solved]
Varazir wrote: Sunday 30 June 2019 23:50 Still getting Nil
When you modify something in the initial area of the data declaration. You need to remove the corresponding data file in <domoticz dir>/scripts/dzVents/data
So if your scriptname is "test.lua" then remove "__data_test.lua ". This persistent data file will be rebuild on the next execution of the script.
Same is true for global_data.lua (remove "__data_global_data.lua")
