Simple plus and minus  [Solved]
Varazir
Post by Varazir »
Hello I can't see why this isn't working.
		devices =   {
		                'IKEA Switch Right Arrow'
	    data =      {
	                    loop  = { initial = 0 }
	    logger =    {
	                    level            =  domoticz.LOG_DEBUG,
                        marker           =  "ikeaSelect"
        if (device.state == "Click" )
            then
                if domoticz.data.loop < 5
                    then
                        domoticz.data.loop = domoticz.data.loop + l
                        domoticz.data.loop = l
            currentGroup = domoticz.globalData.globGroups[domoticz.data.loop]
            domoticz.log(domoticz.data.loop, domoticz.LOG_INFO)
            domoticz.log(currentGroup, domoticz.LOG_INFO)
            domoticz.log(device.state, domoticz.LOG_INFO)
            domoticz.log(device.name, domoticz.LOG_INFO)
            domoticz.log(domoticz.globalData.globGroups[2], domoticz.LOG_INFO)
            device.switchOff().silent()
I keep getting
2019-06-30 20:56:24.234 Error: dzVents: Error: (2.4.24) ...omoticz/scripts/dzVents/generated_scripts/ikeaSelect.lua:23: attempt to perform arithmetic on global 'l' (a nil value)
Something is wrong but I can't see it
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
jake
Re: Simple plus and minus  [Solved]
Post by jake »
Did your accidentally use a capital 'i' instead of the number 1?
Varazir wrote: Sunday 30 June 2019 21:19 Hello I can't see why this isn't working.
You used the letter l where you probably intended to use the digit 1
Varazir
Post by Varazir »
waaren wrote: Sunday 30 June 2019 23:16
yes, it was it DAMN log10 autocomplete
Varazir
Post by Varazir »
jake wrote: Sunday 30 June 2019 22:59 Did your accidentally use a capital 'i' instead of the number 1?
