looping through data AND doing a lookup  [Solved]
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
i have been able to do a lookup based on a trigger.
now i want to loop through all these items everytime instead of doing a trigger lookup.
can anybody point me in the right direction because i can not comprehent the foreach stuff
local lookup = {
    Bamboelampklok = "100" ,
    Dressoirlamp = "101" ,
    Dressoirlamptoog = "102" ,
    LampachterTV = "103",
    Bamboelamphoek = "104" ,
    Plafondspots = "105" ,
    Vitrinekast = "106" ,
    Tuinlampen = "107" ,
    Tuinsproeier = "108" ,
    Woonkamerlampen = "109" ,
    WoonkamerlampenSfeervol = "114" ,
    SceneNormaal = "110" ,
    SceneRyan = "111" ,
    SceneSfeervol = "113" ,
    SceneLezen = "112" ,
    execute = function(domoticz, trigger)
     local habridgeid = lookup[trigger.name]
so basically i want a variable to hold the name of the device
second variable to hold the id of that device (the number behind the name)
and that part looping until i have gotten through all the devices specified under lookup.
can this be done with one lookup table or do i need 2 seperate tables
Re: looping through data AND doing a lookup
Gravityz wrote: Sunday 30 June 2019 17:42 now i want to loop through all these items everytime instead of doing a trigger lookup.
Not sure if I understand exactly what you try to achieve but have a look at this to see if that helps.
return
    on = { devices = {'trigger'}},
    execute = function(dz, item)
        local lookup =
            SceneRyan = "111" ,
        local rpad = function(str, len, char)
            if char == nil then char = ' ' end
            return string.rep(char, len - #str) .. str
        local lpad = function(str, len, char)
            return str .. string.rep(char, len - #str)
        for name, id in pairs(lookup) do
            dz.log('device name: ' .. lpad(name,27) .. '; ID ==>> ' .. id )
Gravityz
Post by Gravityz »
wow, that looks very promising.
i can however not use the lpad(name,27) as a device name
i tried dz.devices((lpad(name,27)). state but that did not work
also
local device = (lpad(name,27) and then
local state = dz.devices(device) or
local state = device.state
does not work
Gravityz wrote: Sunday 30 June 2019 18:53 i can however not use the lpad(name,27) as a device name
Try
dz.devices(name)
the lpad() and rpad() functions are only there to make the lay-out easier to read by padding the name with spaces so all names have the same width on the screen.
Gravityz
Re: looping through data AND doing a lookup  [Solved]
Post by Gravityz »
damned, thought i tried that one but noticed i did it with the lpad, not the name only.
working perfectly now
the other pitfall i discovered i was mixing devices with scenes/groups and not al commands work correctly then
the previous script was working perfectly also but i noticed that when turning on a scene, multiple lights go on and the scripts gets flooded(you can not capture all the lights triggering the script)
when the new script gets triggered it just updates all the light/scenes, triggered or not.
a lot of work just to fix functionality which should be implemented in habridge in the first place
anyway, truly thanks, you probably think and dream dzvents
