Problème state switch  [Solved]
Hydci
Domoticz version: 4.10717
Post by Hydci »
My script works by cons when I add a condition this one does not work anymore and and I can not understand the mistake I made
elseif dz.time.matchesRule('25 minutes after sunset') and dz.devices('Jardin').state == 'Off' then MY SCRIPT WORK
elseif dz.time.matchesRule('25 minutes after sunset') and dz.devices('Jardin').state == 'Off' and dz.devices('Volet cuisine').state == 'On' then MY SCRIPT NO WORK
        on =
            timer     = { '25 minutes after sunset','at 7:30 on mon,tue,thu,fri','at 8:30 on wed,sat,sun'},
            devices = {'Jardin'},
        logging =
            level = domoticz.LOG_DEBUG,
            marker = 'Volets'
    execute = function( dz, item, devices )
        Cuisine = dz.devices('Volet cuisine')  -- racourci des devices
        Salon = dz.devices('Volet salon')
        if item.isDevice and item.state == 'Off' and dz.time.matchesRule('at nighttime') then  -- ferme les volets si le jardin pass en off
            Cuisine.switchOff().silent()
            Salon.switchOff().silent()
        elseif dz.time.matchesRule('25 minutes after sunset') and dz.devices('Jardin').state == 'Off' then --coucher du soleil protection lumière on attend le off pour fermer les volets
        elseif dz.time.matchesRule('at 7:30 on mon,tue,thu,fri') then -- lever du soleil
            Cuisine.switchOn().silent()
            Salon.switchOn().silent()
		elseif dz.time.matchesRule('at at 8:30 on wed,sat,sun') then -- lever du soleil
Re: Problème state switch
Hydci wrote: Sunday 30 June 2019 17:47
elseif dz.time.matchesRule('25 minutes after sunset') and dz.devices('Jardin').state == 'Off' and dz.devices('Volet cuisine').state == 'Off' then
I don't see this line in the script but should work
You entered the keyword at twice.
Hydci
Post by Hydci »
I paste my script that works because when I add that and dz.devices ('Kitchen pane'). state == 'On' the script works more
That's how I write it when I make the condition
        on =
        logging =
            marker = 'Volets'
        elseif dz.time.matchesRule('25 minutes after sunset') and dz.devices('Jardin').state == 'Off' and dz.devices('Volet cuisine').state == 'On' then --coucher du soleil protection lumière on attend le off pour fermer les volets
		elseif dz.time.matchesRule('at 8:30 on wed,sat,sun') then -- lever du soleil
Hydci wrote: Sunday 30 June 2019 18:06 I paste my script that works because when I add that and dz.devices ('Kitchen pane'). state == 'On' the script works more
what do you see in the log when you run this ?
        on =
        logging =
            marker = 'Volets'
    execute = function( dz, item)
        dz.log("Cuisine.state: " .. Cuisine.state,dz.LOG_DEBUG)
        dz.log("Salon.state: " .. Salon.state,dz.LOG_DEBUG)
        elseif dz.time.matchesRule('25 minutes after sunset') and dz.devices('Jardin').state == 'Off' and Cuisine.state == 'On' then --coucher du soleil protection lumière on attend le off pour fermer les volets
Hydci
Post by Hydci »
Just
2019-06-30 18:18:00.492 Status: dzVents: Info: Volets: ------ Start internal script: Volet:, trigger: at 18:18
2019-06-30 18:18:00.509 Status: dzVents: Debug: Volets: Processing device-adapter for Jardin: Switch device adapter
2019-06-30 18:18:00.510 Status: dzVents: Debug: Volets: Processing device-adapter for Volet cuisine: Switch device adapter
2019-06-30 18:18:00.510 Status: dzVents: Info: Volets: ------ Finished Volet
And no condition and dz.devices('Volet cuisine').state == 'On'
2019-06-30 18:37:00.200 Status: dzVents: Info: Volets: ------ Start internal script: Volet:, trigger: at 18:37
2019-06-30 18:37:00.218 Status: dzVents: Debug: Volets: Processing device-adapter for Volet cuisine: Switch device adapter
2019-06-30 18:37:00.219 Status: dzVents: Debug: Volets: Processing device-adapter for Volet salon: Switch device adapter
2019-06-30 18:37:00.220 Status: dzVents: Debug: Volets: Processing device-adapter for Jardin: Switch device adapter
2019-06-30 18:37:00.220 Status: dzVents: Debug: Volets: Constructed timed-command: Off
2019-06-30 18:37:00.220 Status: dzVents: Debug: Volets: Constructed timed-command: Off NOTRIGGER
2019-06-30 18:37:00.220 Status: dzVents: Info: Volets: ------ Finished Volet
with your script
2019-06-30 18:46:00.265 Status: dzVents: Info: Volets: ------ Start internal script: Volet:, trigger: at 18:46
2019-06-30 18:46:00.282 Status: dzVents: Debug: Volets: Processing device-adapter for Volet cuisine: Switch device adapter
2019-06-30 18:46:00.283 Status: dzVents: Debug: Volets: Processing device-adapter for Volet salon: Switch device adapter
2019-06-30 18:46:00.283 Status: dzVents: Debug: Volets: Cuisine.state: Open
2019-06-30 18:46:00.283 Status: dzVents: Debug: Volets: Salon.state: Open
2019-06-30 18:46:00.284 Status: dzVents: Debug: Volets: Processing device-adapter for Jardin: Switch device adapter
2019-06-30 18:46:00.284 Status: dzVents: Info: Volets: ------ Finished Volet
Re: Problème state switch  [Solved]
Hydci wrote: Sunday 30 June 2019 18:37 with your script
Is this not why it's not working ?
You check for 'On' and 'Off' but states are 'Open' and 'Closed'
Hydci
Post by Hydci »
thanks to the log I understood when domoticz checked the state of the shutter it takes not on but open while in the logs it is on or off
I rely on the logs that I saw on the device
Hydci
Post by Hydci »
Thank's for help
