Varazir
Posts: 484 Joined: Friday 20 February 2015 22:23
Post
by Varazir » Saturday 29 June 2019 10:57
I created this test script to dim a light bulb, but it loops to quick.
IKEA Switch Brightness Down is a selector switch device so it has 4 states, Off, Click, Hold, Release
devices = {
'IKEA Switch Brightness Down'
local dimDevice = domoticz.devices(73)
local dimLevel = 100
if ( device.state == "Hold" )
then
repeat
dimLevel = dimLevel - 5
domoticz.log('Device ' .. dimLevel .. ' %', domoticz.LOG_INFO)
dimDevice.dimTo(dimLevel)
until ( device.state == "Release" or dimLevel < 5 )
if ( device.state == "Release" )
then
if (dimLevel == 0 )
then
dimDevice.switchOff()
domoticz.log('Device ' .. device.name .. ' Release', domoticz.LOG_INFO)
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
poudenes
Posts: 667 Joined: Wednesday 08 March 2017 9:42
Domoticz version: 3.8993
Post
by poudenes » Saturday 29 June 2019 11:17
You can't use this line?:
Will dim device 73 to 50%
devices = {
if ( device.state == "Hold" ) then
domoticz.devices(73).dimTo(5)
elseif ( device.state == "Release" ) then
domoticz.devices(73).switchOff()
RPi3 B+ , Debain Stretch , Domoticz , Homebridge , Dashticz , RFLink , Milight , Z-Wave, Fibaro , Nanoleaf , Nest , Harmony Hub , Now try to understand pass2php
Posts: 6028 Joined: Tuesday 03 January 2017 14:18
Post
by waaren » Saturday 29 June 2019 11:35
Varazir wrote: Saturday 29 June 2019 10:57
As dzVents does not change the devices by itself but hands over that action to domoticz after the script has finished you cannot use the new state of a device inside a dzVents script that changed that state. The state simply had not changed yet. Same is true for classic domoticz Lua and Blockly
dzVents wiki
Varazir
Post
by Varazir » Sunday 30 June 2019 11:17
waaren wrote: Saturday 29 June 2019 11:35
Okay, I have goten this far now and the diming works but I cant get it to stop
devices = { 'IKEA Switch Brightness Down' },
logging = {
level = domoticz.LOG_DEBUG,
marker = "IKEADown"
data = {
buttonState = { initial },
function sleep(s)
local ntime = os.clock() + s
repeat until os.clock() > ntime
then
repeat
domoticz.log('Hold Button State ' .. domoticz.data.buttonState .. ' ', domoticz.LOG_INFO)
sleep(1)
until ( domoticz.data.buttonState == "Release" or dimLevel < 5 )
then
domoticz.data.buttonState = "Release"
if (dimLevel == 0 )
then
domoticz.log('Release Button State ' .. domoticz.data.buttonState .. ' ', domoticz.LOG_INFO)
Post
by waaren » Sunday 30 June 2019 13:17
Varazir wrote: Sunday 30 June 2019 11:17
Please have a look at this.
return
on =
logging =
level = domoticz.LOG_INFO,
marker = "IKEADown"
local delay = 0
if device.state == "Hold" then
repeat
delay = delay + 0.15
dimLevel = dimLevel - 1
domoticz.log('Set ' .. dimDevice.name .. ' to dimLevel '.. dimLevel .. '%, after ' .. delay .. ' seconds', domoticz.LOG_INFO)
dimDevice.dimTo(dimLevel).afterSec(delay)
until dimLevel <= 0
elseif device.state == "Release" then
domoticz.log('Stop dimming of ' .. dimDevice.name, domoticz.LOG_INFO)
dimDevice.cancelQueuedCommands()
if dimDevice.level == 0 then
dzVents wiki
Varazir
Post
by Varazir » Sunday 30 June 2019 20:01
waaren wrote: Sunday 30 June 2019 13:17
return
on =
logging =
marker = "IKEADown"
local delay = 0
repeat
until dimLevel <= 0
Thanks, it worked.
Then to the next step to make it dynamic.
But that is another thread
Diplo95
Posts: 15 Joined: Friday 26 July 2019 10:21
Domoticz version: 2021.1
Post
by Diplo95 » Monday 15 February 2021 19:47
I join the thread because I try to find a way to dim a light with my Xiaomi Round 1 button switch.
Just to be sure, this script dim the light once the button is released ?
Varazir : have you found a way to dim the light when pushing the switch ?
Domoticz v2021.1 on Raspberry Pi 3B+
Raspbian Buster
ConBee II + Xiaomi devices
Zwave
