IKEA Trådfri Remote control  [Solved]
Varazir
Post by Varazir »
This is my(and waaren and others ) solution on using 1 IKEA Trådfri Remote to control several groups/devices.
I guess you can scale this to have several remotes, example one for each room that has it's own set of groups
Hardware
ZigBee usb device with firmware https://github.com/Koenkk/Z-Stack-firmw ... _Home_1.2/
Software
Zigbee2MQTT
This is my IKEA Trådfri devices in Domoticz
Script
Using the dim action for Blinders isn't the best solution.
I have to look into another solution for it.
groups = {'group1', 'group2', 'group3', 'group4', 'group5', 'group6' }
return  {
    on = {  devices = { 'IKEA Remote*' }},
    logging = { level = domoticz.LOG_DEBUG,
                marker = "IKEARemote" },
    data = { currentGroup = { initial = 1 }},
    execute = function(dz, item)
        control =
            group3 = --Hallway
                lamp =  { idx = 40, toggle = true, dimmer = true, blink = true },
                --spot1 = { idx = 15, toggle = true, dimmer = true},
				--spot2 = { idx = 17, toggle = true, dimmer = true},
				--spot3 = { idx = 19, toggle = true, dimmer = true}
            group1 = --Bedroom
                lamp =  { idx = 13, toggle = true, blink = true, dimmer = true}
            group4 = --Lilvingroom
                --spot1 = { idx = 21, toggle = true, dimmer = true},
                spot2 = { idx = 36, toggle = true, dimmer = true, blink = true}
                --spot3 = { idx = 25, toggle = true, dimmer = true}
			group6 = --Computeroom
                lamp =  { idx = 73, toggle = true, blink = true, dimmer = true}
			group5 = --TvBench
                lamp =  { idx = 42, toggle = true, blink = true},
                onkyoHW = { idx = 74, toggle = true},
                tv =    { idx = 45, toggle = true},
				onkyo = { idx = 43, toggle = true}
			group2 = --BedroomBlilnder
                blinder = { idx = 59, toggle = true, dimmer = true },
        local selectedGroupNumber = dz.data.currentGroup
        local maxGroup = #groups
        local function doAction(action, direction)
            selectedGroup = groups[selectedGroupNumber]
            dz.log("Current selected group is." .. selectedGroup)
            dz.log("Current acction is........" .. action)
            for device, attributes in pairs(control[selectedGroup]) do
                dz.log("Current typ is............" .. device)
                currentIDx = attributes["idx"]
                currentDevice = dz.devices(currentIDx)
                dz.log("Current device is........." .. currentDevice.name)
                dz.log("Current device IDx is....." .. currentIDx)
                for attribute, value in pairs(attributes) do
                    dz.log("Current attribute is......" .. attribute)
                    if attribute == action then
                        dz.log("Current acction is " .. action)
                        -- Blinking
                        if action == 'blink' then
							local blinkDevice = dz.devices(currentDevice.name)
							local blinkLevel = currentDevice.level
							dz.log("Device " .. blinkDevice.name .. " will blink")
							if blinkDevice.state == "Off" then
								blinkDevice.switchOn()
								blinkDevice.switchOff().afterSec(0.5)
								blinkDevice.switchOn().afterSec(0.5)
				        elseif action == 'dimmer' then
							local dimDevice = dz.devices(currentDevice.name)
							local dimLevel = dimDevice.level
							local delay = 0
                            dz.log(dimDevice.name .. " direction is " .. direction)
							if direction == "stop" then
							    dimDevice.cancelQueuedCommands()
							    dz.log('Stop dimming of ' .. dimDevice.name .. ' at ' .. dimLevel ..'%')
							elseif direction == 'down' then
								repeat
									delay = delay + 0.1
									if direction == "down" then dimLevel = dimLevel - 1	else dimLevel = dimLevel + 1 end
									dz.log('Set ' .. dimDevice.name .. ' to dimLevel '.. dimLevel .. '%, after ' .. delay .. ' seconds', dz.LOG_INFO)
									dimDevice.dimTo(dimLevel).afterSec(delay)
								until dimLevel <= 0
						    elseif direction == 'up' then
                                repeat
                                    delay = delay + 0.1
                                until dimLevel >= 100
                        elseif action == 'toggle' then
                            local toggleDevice = dz.devices(currentDevice.name)
                            local toggleState = toggleDevice.state
                            if toggleState  == 'On' then toggleDevice.switchOff() else toggleDevice.switchOn() end
        local action = 'blink'
        local direction = 'up'
        if item.state == 'Click' and item.name == 'IKEA Remote Left' then
            selectedGroupNumber = selectedGroupNumber - 1
            if selectedGroupNumber == 0 then selectedGroupNumber = maxGroup end
        elseif item.state == 'Click' and item.name == 'IKEA Remote Right' then
            selectedGroupNumber = selectedGroupNumber + 1
            if selectedGroupNumber > maxGroup then selectedGroupNumber = 1 end
        elseif item.name == 'IKEA Remote' then
            action = 'toggle'
        elseif item.state == 'Hold' and item.name == "IKEA Remote Up"  then
            action = 'dimmer'
        elseif item.state == 'Hold' and item.name == 'IKEA Remote Down' then
            action = 'dimmer'
            direction = 'down'
        elseif item.state == 'Release' and item.name == 'IKEA Remote Down' or item.name == 'IKEA Remote Up' then
            action = 'dimmer'
            direction = 'stop'
            dz.log('Unknown action requested; ignored' )
            return
        if item.levelName ==  'Click' then
            dz.log('Turning off' .. item.name)
            dz.devices(item.name).switchOff().silent()
        dz.data.currentGroup = selectedGroupNumber
Added it to GitHub
https://github.com/varazir/Domoticz-Script
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Varazir
Re: IKEA Trådfri Remote control
Post by Varazir »
Maybe moved to another section in the forum
