As far as I have seen (also going by posts on this very forum) it is by design that only admins can change user variables (over the JSON API)... This is a serious risk if you want to - for instance - set one or more user variables using input from IFTTT, as you'll have to hard-code an admin-account in to the URL used...
What is the reasoning behind this restriction, and would it be possible to review this and make it a configurable item (similar to devices)?
Admin rights required for changing variables?
- FearNaBoinne
- Domoticz version: 2021.1
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
ben53252642
Re: Admin rights required for changing variables?
If your really worried, you could use a script to communicate with IFTTT and then have that script update Domoticz via JSON.
Why do you want to use IFTTT?
