I have a script running in DzVents, de scripts runs every time on changes from de P1 device.
I have a switch with a delay time of 120 seconds, the script runs every 10 seconds. On every (10sec) "run" de script restarts the 120 seconds.
is their a possibility get the state of remaining time or an other option?
domoticz.devices (Addition) .switchOn ().checkFirst().afterMin(2)
Switch delay Topic is solved
- waaren
Re: Switch delay
I only understand part of your requirement but from what I understand you should look for a solution with either dzVents persistent data or a domoticz uservariable.StefanWouters wrote: ↑Saturday 22 June 2019 14:44 I have a script running in DzVents, de scripts runs every time on changes from de P1 device.
Is their a possibility get the state of remaining time or an other option?
If you can elaborate a bit on what you intend to do and share the scripts you already have, I might be able to help.
Re: Switch delay
I run a script wich is triggerd by f
execute = function(domoticz, triggerItem)
if (triggerItem.isDevice) then
the script wil run every 10 seconds, in the last part of the script (after some calculations) some of the switches needs to be changed
for example 1:
if ((domoticz.data.Huidigverbruik >= 0) and (domoticz.devices (Vrijgave).state == 'On')) then
domoticz.devices (Vrijgave) .switchOff ().checkFirst().afterMin(2)
With the time delay i want to preventthat the siwtches change every 10 seconds from on to off
Some switches have a delay of 30 second other have 2 minutes
Because the (example 1) is every 10 seconds true, the 2 minutes delay will restart every 10 seconds....
mamybe their is a way to get the remaining time of is their a state, that de delay time is started.
for example 1:
- waaren
Re: Switch delay
Again still guessing what you exactly mean because you only share part of your script but it just might work if you code it like.StefanWouters wrote: ↑Saturday 22 June 2019 16:18 With the time delay i want to prevent that the switches change every 10 seconds
if domoticz.data.Huidigverbruik >= 0 and domoticz.devices(Vrijgave).lastUpdate.secondsAgo > 120 then
domoticz.devices(Vrijgave).switchOff().checkFirst()
Re: Switch delay
Problem solved with your solution
