Wow, I thought, this is nice.
The output of the installation script was:
Nothing more. What the heck? I tried again. The script just stopped. So I downloaded the installer and debugged it. It turned out that it writes the error messages to dev/null? why?::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for libcurl3..
The error message was:
In Ubuntu 18 and 19 there is no libcurl3, only libcurl4 and it is not possible to install libcurl3. Very strange. I googled the problem and people said: compile Domoticz from source. Uhh!? Ok, I'l try it. I cloned the git and startet "cmake".Package libcurl3 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
libcurl4:i386 libcurl4
E: Package 'libcurl3' has no installation candidate
Don't laught now. Googling again what this means. Result: domoticz wiki says I have to download cmake from the project site and compile it by myself? This is not true. What comes next? Compiling the linux kernels from scratch? I cannot believe this...CMake Error at CMakeLists.txt:2 (cmake_minimum_required):
CMake 3.14.0 or higher is required. You are running version 3.13.4
