EU localisation option (replace . with ,)
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
is there a localisation option for domoticz?
it seems that nowadays this should be standard instead of hard coded.
there are a lot of people in the EU who would like to read meters, counters with the EU standard(. thousand seperator and , for decimal seperator)
while not an option this was coded in the main.js file
var _THOUSAND_SEPARATOR = '.';
var _DECIMAL_POINT = ',';
i checked but i can not find these variables anywhere.
is there a way to get this done, for now a simple manual change in a file would do but i really think there should be a NON US option
thanks
Gravityz
Re: EU localisation option (replace . with ,)
Post by Gravityz »
ok, can people who want this please reply with a simple I WANT THIS
otherwise we are getting nowhere
i rest my case if i am the only one
leecollings
Post by leecollings »
Just my input, in the UK the two symbols you have quoted are round the wrong way.
Thousand separator should be a comma (,) and the decimal point should be a full stop (.)
Gravityz
Post by Gravityz »
Exactly my problem
The EU is using this
Noe you know why the UK is leaving te EU.
They are part of the rest of the world
lazaruss72
Post by lazaruss72 »
I WANT THIS
Delfuego
Post by Delfuego »
I WANT THIS!
EddyG
Post by EddyG »
I don't care. Over the years I am used to the way it is.
Kangooroo42
Post by Kangooroo42 »
I WANT THIS! in 2022!
SimonW
Post by SimonW »
I WANT THIS TOO! in 2022!
MRabozee
Target OS: OS X
Post by MRabozee »
Hello, the possibility to modify the decimal separator and the thousand separator is a must have !
I even tried even to change the js code in www.app/app.js
(in that part:
//decimalPoint: decimalPoint,
//thousandsSep: thousandsSep,
decimalPoint: ',',
thousandsSep: ' ',
but it does change only in the graphs (tooltips for instance), not in the dashboard display of the sensors. '.' as decimal separator and ',' as thousand separator seem just to be hardwired somewhere :-) )
athoopen
Domoticz version: 2025.2
Post by athoopen »
I really love Domoticz, however, one thing which is annoying me is the lack of localization :oops: . I do understand that it is Open Source and there is no "business" behind it. But we are in 2024, it’s not 2012. Many non-technical user use Domoticz, it's not techie only system (anymore).
I would (urgently) ask the developers of this great open source product to start discussing localization. Does it make sense (I think it does), and if it makes sense what will be localized (you could start with the decimal point and thousand separator .. just my 2 cents).
To all users who support this request, please let the developers know that you find this important!
Thanks for Domoticz!!
Cheers,
Arjan
Rp3 Using : RFXCom, LaCrosse, KNMI, Remeha, TinyTuya, zigbee and a few others
thaui
Domoticz version: 2023.2
Post by thaui »
Would be nice to have the choice between UK / EU decimal seperator.
Users browsing this forum: Doler and 1 guest
