Beware of Raspberry Pi SSH hijacks
ben53252642
Re: Beware of Raspberry Pi SSH hijacks
Post by ben53252642 »
Actually it is relevant to SSH Hijacks because many attacks are successful because of leveraged kernel or application vulnerabilities, now were even starting to see CPU vulnerabilities eg Spectre for which there are now kernel patches.
I combine it with "unattended upgrades" to cover the system packages.
https://help.ubuntu.com/lts/serverguide ... dates.html
Obviously put SSH on a non-default port with either certificate auth or a very long complex password.
If you want to go the extra mile use port knocking. 8-)
EddyG
Post by EddyG »
poudenes
Domoticz version: 3.8993
Post by poudenes »
I always change port to above 5000 and make use of SSH_KEY.
And change some settings in sshd_config to
Port I-DONT-TELL
PermitRootLogin no
PasswordAuthentication no
UsePAM no
Thunderbolt
Domoticz version: 4.11665
Post by Thunderbolt »
I'm a little confused, but did I got that right, that you left your ssh port of your pi accessible from the internet?
In my opinion, that port shouldn't be open at all. If I want to access the pi from outside, I would use a secured VPN connection.
