Local variable not recognized?  [Solved]
straatm
Domoticz version: Stable
Post by straatm »
All I try to use the within_min() command and use a local variable at the beginning of the script.
But there is always this log that the Value is "a nil value" it seems the local variable is not recognized.
Someone any idea how to solve this? See script and log below.
local RANDOM_DELAY_MINS = 20
       on = { timer = { 'at nighttime at 07:00 on mon, tue, wed, thu, fri',
                     'at nighttime at 08:20 on sat, sun',
                     'at sunrise',
                     'at sunset',
                     'at 15 minutes before sunset',
                     'at 22:00 at nighttime on mon, tue, wed, thu, fri, sat, sun',
                     'at 23:15' }
          -- timer = { 'at sunrise' },
          -- timer = { 'at 23:00 at nighttime on mon, tue, wed, thu, fri, sat, sun'}
	execute = function(domoticz, timer)
	    domoticz.log(timer.trigger)
	    if (domoticz.time.matchesRule('at 07:00')) then
	       domoticz.log('Dit werkt om 7:00 uur')
	       domoticz.groups('Binnen-Lampen').switchOn().repeatAfterSec(1,3)
	    elseif (domoticz.time.matchesRule('at 08:20')) then
	       domoticz.log('Dit werkt om 8:20 uur op Zaterdag en Zondag')
	    elseif (domoticz.time.matchesRule('at sunrise')) then
	       domoticz.log('Zonsopkomst')
	       domoticz.groups('Binnen-Lampen').switchOff().repeatAfterSec(1,3)
	    elseif (domoticz.time.matchesRule('at 15 minutes before sunset') and domoticz.time.matchesRule('at 00:00-23:00')) then
	       domoticz.log('15 minuten voor Zonsondergang')
	    elseif (domoticz.time.matchesRule('at 23:15') and domoticz.devices('$Hulp-Laat-Thuis').state == 'Off') then
	       domoticz.log('Slaaplekker')
	       domoticz.groups('Binnen-Lampen').switchOff().within_min(RANDOM_DELAY_MINS)
	       domoticz.groups('Binnen-Lampen').switchOff().aftermin('30')
	       domoticz.log('Slaaplekkerrrrrr binnen')
2019-06-14 23:15:00.611 Status: dzVents: Error (2.4.19): An error occured when calling event handler DZ_SfeerVerlichtingBinnen
2019-06-14 23:15:00.611 Status: dzVents: Error (2.4.19): .../dzVents/generated_scripts/DZ_SfeerVerlichtingBinnen.lua:30: attempt to call field 'within_min' (a nil value)
2019-06-14 23:15:00.611 Status: dzVents: Info: ------ Finished DZ_SfeerVerlichtingBinnen
2019-06-14 23:15:00.612 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Re: Local variable not recognized?
straatm wrote: Saturday 15 June 2019 8:30 All I try to use the within_min() command and use a local variable at the beginning of the script.
The right way to call this method is withinMin(xxxx). You tried it with within_min(xxxx) which was the syntax for dzVents < 2.0
Also be aware that case matters. aftermin is not the same as afterMin
straatm
Re: Local variable not recognized?  [Solved]
Post by straatm »
Waaren,
Thanks that was the solution...
I used an old example taken from the internet
BR,
Marc
