I wonder if this can be done:
1) Sensor only controls a sensor-switch in Domoticz, making Domoticz doing the logic work?
Don't want the sensor to control the bulbs directly
2) 5 button control: pressing the arrow right or left shifts the control between groups
When the next group is selected one bulb/spotlight blinks ones to confirm the room selected.
3) Sett the brightness without turning the bulb/spotlight on?
My hallway don't have any windows, doors from other rooms the lets in the light.
Due to that I want the brightness to be low during the day but around sun going down I want it to be higher.
This one goes hand in hand with the first as the sensor are in the hallway
Can this be done with Ikea devices and Zigbee usb stick?
- Varazir
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Thorgal789
- Target OS: -
Re: Can this be done with Ikea devices and Zigbee usb stick?
Hello
1 - Yep, I thing all plugins works like this
2 - you need to code it yourself, but I don't see why it could not be possible, as like I have said in 1, you are controlling all the actions
3 - Yes and no, you can't send brightness value to an off bulb, you will have an error message, but you can set a luminosity setting according to a time setting.
An exemple of lua code I m using, to show what you can do (with more explanations here > https://github.com/Smanar/Domoticz-deCO ... us-sensors )
-- Detecteur couloir
if devicechanged['deCONZ - Motion Sensor'] then
if devicechanged['deCONZ - Motion Sensor'] == 'On' then
print("Detecteur active")
if (otherdevices['working day]== 'On') then
commandArray['Scene:working day light]='On'
if ((_time >= '23:00') or (_time < '07:00')) then
commandArray['Scene:night light']='On'
commandArray['Scene:normal light']='On'
if ((_time >= '12:00') and (_time < '21:00')) then
print("Detecteur Desactive")
if (otherdevices['deCONZ - lampe ikea']== 'On') then
commandArray['deCONZ - lampe ikea']='Off'
if (otherdevices['deCONZ - Couloir']== 'On') then
commandArray['deCONZ - Couloir']='Off'
