Anyone willing to create a plugin for Ziggo Mediabox Next?
For inspiration:
https://github.com/basst85/NextRemoteJs ... r/index.js
Ziggo Mediabox Next
- pgielen
- Domoticz version: 2020.2
Re: Ziggo Mediabox Next
It's a start. This is a node.js app that uses the express server, so it will probably use up a lot of resources on your Raspberry Pi (if your Domoticz server, like mine, is running on RPi).
Anyway, I installed it (which failed the first time, so I had to manually install the 'request' module (npm --save install request). I noticed that the only functions this app has is turn the Mediabox on/off and show/change the channels (edit index.html to see more than 10 channels). But there is already a Home Assistant plugin that can do more: https://github.com/IIStevowII/ziggo-mediabox-next.
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
Is there any development on a domoticz plugin for this box?
Would be nice!
Would be nice!
Hope some one with skills can create a plugin.
I want to say “He Siri, turn on the tv”
Like pgielen I tried the nodejs solution as well. Ran into the same problem, but works nice. Now I'am trying to create a curl command to send to the webserver. In order to create backgrounds commands. I'am used to do some programming, but new to nodejs. Can some one help me to create a curl command (for exanple for the power-key command) based on the code in index.js en index.html?
I've created a python package for communication with the next. It's created for Home Assistant but since it is a generic package you can use it for domoticz too i presume...
https://pypi.org/project/ziggonext/#history
- Domoticz version: 2020.1
how is it possible to add the Ziggo Next box into a group or scene with this package. I have Google home mini assistent for all my devices in home except and have homebridge installed for my iPhone and siri that works, but I want it to for google assistant on my Sonos. can anybody help me with this cool feature?
