Values are not sent to influxdb [Solved]
- Domoticz version: 2022.1
I just discovered, maybe I'm overlooking something, that dummy sensors values that are set by a dzvents scripts are not send to influxdb whereas the corresponding sensor is activated in influxdb. If same device value is set with the straight http json command, it is sent to influxdb.
I'm currently running domoticz v3.9139, yes a rather old version. I'm waiting summertime to upgrade my system which is rather complex.
Any ideas on ths matter?
Thank you
Thank you
Debian buster on NUC and three RPi with buster.
- waaren
Re: Values are not sent to influxdb
In this this wiki topic you can see why it is not working as you expected.
For most devices dzVents use the ['UpdateDevice'] method as this give advantages. (speed, silent(), checkFirst() to name a few).Note to Virtual / Dummy sensors: If the HTTP link or MQTT is not sending any values to the database, check the update method of your virtual sensors in your scripts. If using the ['UpdateDevice'] method, you will directly write the value to the internal database without triggering an HTTPlink or MQTT update for this sensor. Better is to use the JSON API of Domoticz and update your virtual sensors this way.
If you want I can help you with a function to also use the JSON API if a virtual sensor update also need to be pushed to influxdb. I would share it here but the function is different for every sensor type. Maybe it's worthwhile to build a generic one if more forum members and many different sensor types encounter this issue.
Thanks for quick reply. In other works I falled into the trap! I think I can manage to write the JSON equivalent. Would be great to have it native, but in the meantime I'll do it.
- Domoticz version: 4.11474
I am facing the same problem for a number of virtual (dummy) devices and I am not familiar with writing JSON script. I noticed for the humidity of a temperature device, the status (wet, dry, etc) is not being send to the influxdb too. Can someone help me.
Cees
I have not yet wrote my own scripts. I don't have time to do it now.
Documentation is here: https://www.domoticz.com/wiki/DzVents:_ ... P_requests
It is pretty straightforward though.
Thanks for your advice. I was not able to code a push of the data using the domoticz.openUrl statement. This was causing a error statement in the log file. I have now replaced the statement using os.execute and the curl command to peform the data to be pushed to influxdb on another raspberryPI.
I am using the
local function DumpIn (pVar, pValue, pFormat)
local Prefix = "curl -i -XPOST 'http://000.000.000.00:8086/write?db=huis&precision=m' --data-binary "
local PostFix = "'" .. "Calculation,name=" .. pVar .. string.format (" value=" .. pFormat .."'", pValue)
os.execute(Prefix .. PostFix)
domoticz.log(Prefix .. PostFix, domoticz.LOG_INFO)
return 0
I am using the
return 0
Cees
Is it possile to query the InFluxDB transfer definition table for virtual devices? Using this query to develop a generic dzventz script to send the data (on a minute) from the virtual devices using a OpenUrl/JSON statement?
Advantage: users (like me) with little knowlegde can send data too from virtual device by adding them in the INFluxDB transfer definition table without any coding.
Cees
This instruction worked out of the box. Replace IDX by your own
domoticz.openURL('http://ipaddress:port/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=90;W;0;0;30;30')
Command reports an error:
2019-06-17 16:24:02.385 Error: Error opening url: http://000.000.000.00:8086/json.htm?typ ... ;0;0;30;30
Cees
On my side I have no issues. What is the exact instruction used?
Do you confirm that your port is 8086, default is 8080?
With thanks to Waaren,
Put this is your global data
Use examples:
pushToInfluxdb = function (domoticz, nValue, Device, ...)
local args = {...}
local sValue = ""
for _,value in ipairs(args) do
sValue = sValue .. tostring(value) .. ';'
if #sValue > 1 then
sValue = sValue:sub(1,-2)
local tempUrl = "http://192.xxx.x.xxx:8080/json.htm?type=command¶m=udevice&idx=" .. Device .. '&nvalue=' .. (nValue or 0) ..
'&svalue=' .. sValue
domoticz.openURL({
url = tempUrl,
method = 'GET',
Use examples:
domoticz.helpers.pushToInfluxdb(domoticz, nValue, 3617, tostring(winddirection), winddirectionstr, tostring(Speed*10), tostring(Gust*10), tostring(Temperature), tostring(gevoelsTemp))
domoticz.helpers.pushToInfluxdb(domoticz, nValue, 3665, tostring(Rain),tostring(Rain24h))
domoticz.helpers.pushToInfluxdb(domoticz, nValue, 3749, tostring(sunpower))
domoticz.helpers.pushToInfluxdb(domoticz, nValue, 3750, tostring(Zicht))
domoticz.helpers.pushToInfluxdb(domoticz, tostring(Humidity), 3751)
Many thanks for your quick response and your help. However I am getting a little lost in your advice. As I mention before the command:
return 0
With the example:
a = DumpIn ("Graaddagen", domoticz.devices('GraadDagen').counter, "%.1f")
works fine.
Question: In your statements I do not see to which database the data needs to be send. In my case the database is “huis”. How does the system know this in your statement?
I push the data via port 8086 from Domoticz to the InfluxDB (not retrieving data!!!).
However I want to program it neatly and remove de old fashioned way using de os.execute command.
Question: Why should I use the method=“GET” in the openURL statement, while I want to push the data (method=”POST”)???
return 0
With the example:
works fine.
Cees
- waaren
There seems to be a misunderstanding here. Your curl command pushes the data directly to the influxDB while the example from Maxx forces the update in such a way to domoticz that it will be seen by the domoticz push mechanism. From there on domoticz will handle the transfer to influxdb.
The example from Maxx for the global_data helper part can also be simplified to
pushToInfluxdb =
function (dz, nValue, idx, ...)
local url = dz.settings['Domoticz url'] .. '/json.htm?type=command¶m=udevice&idx=" ..idx ..
'&svalue=' .. table.concat({...},";")
dz.openURL(url)
From the architecture standpoint, IMHO the worst solution is to write directly to influxdb. It is far better to let domoticz do all it can do. Warren function is the most elegant approach, so I will change, again;) my code. Anyhow the solution I implemented is currently running without a glitch.
Performance wise what would be the best one?
- waaren
The direct approach you used will be the quickest but in comparable situations I have never measured a difference. So less then 0.001 seconds per call. Given that this code is without loops and without calls to other systems, I would not really think about performance twice.Number8 wrote: ↑Tuesday 18 June 2019 17:37 From the architecture standpoint, IMHO the worst solution is to write directly to influxdb. It is far better to let domoticz do all it can do. Warren function is the most elegant approach, so I will change, again;) my code. Anyhow the solution I implemented is currently running without a glitch.
Fair enough, thanks waaren
- Domoticz version: 4.10
I created this script in lua, and it does not send me data on influxdb running on a NAS, I would like to use the Maxx script to trigger Push on Domoticz, but I can't figure out how to use the function.waaren wrote: ↑Tuesday 18 June 2019 17:08 There seems to be a misunderstanding here. Your curl command pushes the data directly to the influxDB while the example from Maxx forces the update in such a way to domoticz that it will be seen by the domoticz push mechanism. From there on domoticz will handle the transfer to influxdb.
pushToInfluxdb = function (dz, nValue, idx, ...) local url = dz.settings['Domoticz url'] .. '/json.htm?type=command¶m=udevice&idx=" ..idx .. '&nvalue=' .. (nValue or 0) .. '&svalue=' .. table.concat({...},";") dz.openURL(url) end
Thank you
local dev_pzem1 ="PZEM" -- Nome device
local words = {}
local function updatenum(dev, value1)
local cmd = string.format("%d|0|%f", otherdevices_idx[dev], value1)
table.insert (commandArray, { ['UpdateDevice'] = cmd } )
local pzem_power = tostring(otherdevices_svalues[dev_pzem1])..';'
for w in string.gmatch(pzem_power, "([^;]*);") do
table.insert(words, w)
if (words[1] ~= '-1.00') then
updatenum('PZEM_Voltage', words[1])
--commandArray['UpdateDevice'] = '67|0|'..words[1]
[/quote]
- waaren
your script is classic domoticz Lua while the function you want to use is dzVents Lua. These two does mix very well as they use different data and functions in the background.
So you need to switch to dzVents or look elsewhere on the forum to see if you can implement a similar openURL in your script.
Have patience, I'm rewriting in DzVents, but I didn't understand much ...
devices = {
'PZEM'
local Domoticz_url ='192.168.2.10'
print('1 tensione: '..device.rawData[1])
print('2 corrente: '..device.rawData[2])
print('3 potenza: '..device.rawData[3])
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
domoticz.helpers.pushToInfluxdb(domoticz, 0, 67, device.rawData[1])
local url = dz.settings[Domoticz_url] .. '/json.htm?type=command¶m=udevice&idx=' .. idx ..
dz.openURL(url)
- waaren
Can you try this ?
I added something to prevent an endless loop if you want the script to be triggered by the same device as you want to have pushed to influx.
devices = {
'PZEM'
data = { lastExecutionTime = { initial = 0 }},
execute = function(dz, item)
dz.log('Device ' .. item.name .. ' was changed', dz.LOG_INFO)
local function pushToInfluxdb(idx , nValue, rawData )
local sValue = table.concat(rawData,';')
local nValue = nValue or 0
dz.log('idx: ' .. idx, dz.LOG_DEBUG)
dz.log('nValue: ' .. nValue, dz.LOG_DEBUG)
dz.log('sValue: ' .. sValue, dz.LOG_DEBUG)
local url = dz.settings['Domoticz url'] .. '/json.htm?type=command¶m=udevice&idx=' .. idx ..
'&nvalue=' .. nValue ..
dz.openURL(url)
if dz.data.lastExecutionTime < ( dz.time.dDate - 5 ) then
pushToInfluxdb( item.idx, 0, item.rawData )
dz.data.lastExecutionTime = dz.time.dDate
dz.log('Too soon after last update; we don\'t want an endless loop', dz.LOG_DEBUG)
