Is anybody able to help in connecting a purifier Pro to my Domoticz setup? I would mainly like to see the history of the temperature and the humidity (and of course the settings of the purifier; on/off, fan speed etc). Later I will control it via Domoticz.
I’m using my current setup mainly to monitor the temperature in and out the house and control multiple air conditioners (via Harmony Hub) based on the temperature. (I’m a Dutch guy living in Dubai)
Currently I run Domoticz just on my windows laptop for the last 4 months. (I will buy a raspberry pi once I know everything will be running fine)
For my current setup all the hardware/devices where just added easily as they are available in the selection while adding new products to Domoticz. The purifier is not available, so how to add that?
(I’m not afraid to do some programming, but I don’t know where to start)
Xiaomi Air Purifier Pro; how to connect to Domoticz
truffel
- Domoticz version: 4.9700
Re: Xiaomi Air Purifier Pro; how to connect to Domoticz
I managed to get the plugin of kofec working, so I did select the hardware in domoticz (With the token, retrieved via an older android mi home app).
I guess, the below link resolved the issue of adding devices to domoticz by commenting out # import miio.airpurifier:
https://www.domoticz.com/forum/viewtopi ... ec#p202478
Now i can add 3 devices, but they all give an error. What to do?
I also cannot see the temperature or humidity in domoticz yet.
2019-04-17 19:14:46.245 (XiaomiAir) onCommand called for Unit 10: Parameter 'On', Level: 0
2019-04-17 19:14:46.209 Status: User: Admin initiated a switch command (97/XiaomiAir - Power/On)
2019-04-17 19:14:46.248 Error: (XiaomiAir) 'onCommand' failed 'FileNotFoundError'.
2019-04-17 19:14:46.248 Error: (XiaomiAir) ----> Line 581 in C:\Program Files (x86)\Domoticz\plugins\domoticz-AirPurifier-master\plugin.py, function onCommand
2019-04-17 19:14:46.248 Error: (XiaomiAir) ----> Line 329 in C:\Program Files (x86)\Domoticz\plugins\domoticz-AirPurifier-master\plugin.py, function onCommand
2019-04-17 19:14:46.248 Error: (XiaomiAir) ----> Line 626 in C:\Program Files (x86)\Python35-32\Lib\subprocess.py, function check_output
2019-04-17 19:14:46.248 Error: (XiaomiAir) ----> Line 693 in C:\Program Files (x86)\Python35-32\Lib\subprocess.py, function run
2019-04-17 19:14:46.248 Error: (XiaomiAir) ----> Line 972 in C:\Program Files (x86)\Python35-32\Lib\subprocess.py, function __init__
2019-04-17 19:14:46.248 Error: (XiaomiAir) ----> Line 1239 in C:\Program Files (x86)\Python35-32\Lib\subprocess.py, function _execute_child
RohitIdrigasko
- Target OS: -
Nice Post Please Keep Posting Like This On Regular Basis. Here are some use full links.
Best Vegetable Purifier
Best Flour Mills In India
Best Refrigerators In India
Best Double Door Refrigerators In India
