Derik wrote: ↑Friday 07 June 2019 13:58
Thanks for the help!!!
Only 1 problem.
I cannot find the root of the apache
There is no /var/www
And i can not find the apache www place
If I remember correctly the Apache configuration is stored in /etc/apache2
There should be a configuration file in that folder containing the default settings including the directory path for the default web site.
Fallback:
I'm preparing a new Docker file. With Docker we can setup a default configuration which should work on most systems
Thanks there is a file... [ give it a try ]
I will test that Docker if you want...
Only tell me then how i must use that docker...
The default document root for Apache is /var/www/ (before Ubuntu 14.04) or /var/www/html/ (Ubuntu 14.04 and later). See the file /usr/share/doc/apache2/README.Debian.gz for some explanation on how the Apache configuration on Ubuntu is done.
Only 1 problem.
Fallback:
HansieNL wrote: ↑Friday 07 June 2019 16:53
Thanks..
I read the config..
The place should be /var/www/html/
only when i look in var there is no map www should ik make this map with ftp en then a map html and place in that map dashticz?
