Good rain sensor solution
I just finished my automated irrigation system with Rain Bird valves and Z-Wave relays. One of the goal was to optimize water quantities depending on rain fall. And then, rain sensor from DarkSky just stopped working. Since WU also fully stopped working last year, I started to consider that online weather services are not a long-term reliable solution, and considered buying a water sensor.
But, reading the reviews of 433MHz rain meters, many users complain about the values being totally off when compared to a classical "vase" rain meter.
What do you think? Is there any device which provides reliable data, and that can be easily connected to Domoticz with network, RFX433 or even ZWave?
- emme
- Domoticz version: latest
Re: Good rain sensor solution
I'm using a orbit wired rain sensor... not rain meter... I just need to know it is raining or not
a simple NC contact that opens when special disks in it get wet.
Now I'm moving to claber sensor (same usage) because of the rain hole that is much wider....
claber uses a 433Mhz device (CLABER 90831 )
the only isse with those kind of devices is that they send rain switch until they get dry (which is not the same moment it stops raining, but most probably few hours later)
ciao
M
ciao
M
"We always done this way"
- elythomaslumber
- Domoticz version: 2023.1
@emme
I'm also thinking about a rain sensor which should immediately send a signal to close one specific blinds but also to open it soon if raining stops.
What I found is this ready made item: https://www.reichelt.de/rain-sensor-12- ... 8916.html?. It needs a of course a transmitter or directly connected to an RP or something. The good feature here is that it is heated!
Another idea is to combine a rain sensor and an Arduino compatible ESP8266 WiFi transmitter:
https://www.amazon.de/dp/B01D9JCK6K/ref ... -CbEH8N6JW
https://www.amazon.de/dp/B078J7LDLY/ref ... -CbKCTBMVP
...and a heating foil:
https://www.amazon.de/dp/B07HR9T8S2/ref ... -Cb85EXWRD
- emme
I've used tons of those devices and they all gets unusable after few months
The reichelt device is not only a rain sensor: it'a relay with a sensor and needs to be powered with a 12 or 24v Vcc.
I've seen somewhere in the internet an OPTIC rain sensor like this: http://www.pic-control.com/optical-rain-sensor/ but it still needs to be powered with 12v and they are extremely expensive.
Willing to build one by myself, but got no time for
- elythomaslumber
Thanks for your experience! This optical sensor seems to be just what I need but the price is unaceptable (116€).
However about the simple detector from China it could be a solution to gild them.
- emme
they are too much expensive too....
I'm wondering if a simple beam sensor under a transparent dome could be enough to understand if it's raining or not... (at least THIS is what an optic rain sensor is!
- elythomaslumber
Found a discussion in a german forum here: https://www.symcon.de/forum/threads/241 ... egensensor
...and a link...
...here for 59 US$: http://rainsensors.com/
http://rainsensors.com/how-it-works/
...and a link...
- emme
mmmh... looks great!!!!
- Domoticz version: V2022.1
Would it be an option to have that plate pcb design. But than not made from pcb with copper, which stops working after a few months. But make it from carbon plate?
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
This idea also looks nice, a little nork work to make it a nice functional part, but nothing that can't be done
https://youtu.be/zFDsYRGtoW8
It is that i am going to move i about a month, that i can't try to build it.
But it looks a possible solution to make it with espeasy and a photoresistor.
Will be on my wish list to make this. Looks like a fun project to make
OK, it doesn't measure how much rain-fall.
But those cheap chinese pcb plates also don't measure rain-fall
I still use an Oregon one
https://www.weatherspares.co.uk/oregon- ... -875-p.asp
They are pricey but they work. I have no way of knowing if the volume is correct but graphs look correct against local weather.
Are there people who are interested, to make a rain gauge, together?
I have some ideas. But doing it together may result in a better result.
The idea is to make a 3d printer rain gauge.
But keep the basic of the design that way, that it is stackable.
This way the idea is to have a radar reflector beneed it and maybe a wind-sensor.
People than can choose to make different setups. Like only wind and pressure sensors. Or the whole package (rain, wind, pressure).
For electonics i was thinking an esp8266/wemos with espeasy. Already a lot of information can be found on this hardware. Which would be no problem to connect it to domoticz.
The rain gauge would be something like this,
https://www.thingiverse.com/thing:2163969
Wind sensor would be something without moving parts. This will be a challenge, but could be done.
Search for Somfy Netatmo, to get an idea.
What do you guys/ladies think?
Are there people who want to start a project like this, together?
- Domoticz version: 4.9
The rain meter is identical to my Davis vantage rain meter. The davis is accurate compared to an ordinary rain meter.
Once the days are shorter I will get my 3D printer up and running and try the meter from thingiverse. I like the design and adding the signal to an rpi Zero together with temperature should make it work.
- rolandtwilt
I don't know if this forum is still read, I hope so. I bought a simple rain sensor at 433 mhz. Put batteries in and he was recognized.
it is recognized as an on/off switch and that is not the intention .... because it now remains on "on" for a very long time, until the switch has dried up and that sometimes takes hours. Then the rain has stopped for more than 3 hours. How do I do this, help?
Yes forum is pretty active.
The rain sensors operate on buckets as you probably know. Each time the bucket fills of rain, this equals a certain amount (mm) of rain. This triggers a pulse in the sensor, which is sent via 433mhz.
They all work this way, its just Domoticz knows about certain devices as being rain sensors. Do you know what type and model it has been found as ?
Ids
Ids
- rolandtwilt
it is part of a weather station;Emos Wireless Weather Station.
I have tried to link the station to Domoticz and despite the fact that this set is supported by the RFLink I am unable to link it. can you help me?
- Treve
- Domoticz version: v4.11474
Look at this.
https://www.reichelt.nl/nl/nl/regensens ... ensor&&r=1
In combination with a RF switch as Zigbee, Z-Wave or 433MHz you have a good rain sensor with heating.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Domoticz version: Latest β
And a 12 volt supply.Treve wrote: ↑Friday 09 July 2021 17:00 Look at this.
I have just started to use one of these, wired to a Raspberry Pi.
Seems to work well doesn’t suffer from corrosion (yet) as it has gold plated contacts and is fully encapsulated and has a zero volt relay. The heating is very ‘mild’ and only on when wet. It’s not adjustable but is pretty sensitive to moisture but the heater should prevent it getting affected by dew, frost etc.
I’ll report back after a while.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
- rolandtwilt
Thanks for your advice!!
Users browsing this forum: Google [Bot] and 0 guests
