roller shutter and protect light on  [Solved]
Hydci
Domoticz version: 4.10717
Post by Hydci »
Bonjour,
Je chercher a écrire mon dzvent pour l'ouverture et fermeture des volet selon le coucher ou lever du soleil mais je bloque sur la partie du script avec la lumière on
        on = { timer = { '30 minutes after sunset','30 minutes after sunrise' },
		 devices = {'Lightgarden'}
    execute = function(dz, item )
   if dz.time.matchesRule('30 minutes after sunset') and  then
   if dz.devices == 'Off'
	domoticz.openURL('https://maker.ifttt.com/trigger/Volet_salon_fermeture/with/key/xxxx) --closeblind
	domoticz.openURL('https://maker.ifttt.com/trigger/Volet_cuisine_fermeture/with/key/xxxxx) --closeblind
	elseif dz.time.matchesRule('30 minutes after sunrise') then
		domoticz.openURL('https://maker.ifttt.com/trigger/Volet_salon_ouverture/with/key/xxxx') --Openblind
		domoticz.openURL('https://maker.ifttt.com/trigger/Volet_cuisine_ouverture/with/key/xxxxx') --Openblind
	If dz.device('Lifgtgarden'] == 'On' then
	wait light garden off and close blind nightime
Hydci
Re: roller shutter and protect light on
Post by Hydci »
so i did this in the meantime but i would like to add an option with light if off shut the shutters if on the light wait for the off of the light
    execute = function(dz, time )
   if dz.time.matchesRule('30 minutes after sunset') then
	domoticz.openURL('https://maker.ifttt.com/trigger/Volet_salon_fermeture/with/key/xxxx') --closeblind
	domoticz.openURL('https://maker.ifttt.com/trigger/Volet_cuisine_fermeture/with/key/xxxx') --closeblind
	elseif dz.time.matchesRule('59 minutes after sunrise') then
		domoticz.openURL('https://maker.ifttt.com/trigger/Volet_cuisine_ouverture/with/key/xxxx') --Openblind
so i think something like that a help would be nice to corrected
        on = { timer = { '30 minutes after sunset','30 minutes after sunrise','NighTime' },
        if dz.devices == 'Off' then
	dz.openURL('https://maker.ifttt.com/trigger/Volet_salon_fermeture/with/key/xxxx') --closeblind
	dz.openURL('https://maker.ifttt.com/trigger/Volet_cuisine_fermeture/with/key/xxxxx') --closeblind
	dz.openURL('https://maker.ifttt.com/trigger/Volet_salon_ouverture/with/key/xxxx') --Openblind
    dz.openURL('https://maker.ifttt.com/trigger/Volet_cuisine_ouverture/with/key/xxxxx') --Openblind
	if item.state('Lifgtgarden') == 'Off' then
	if (timeofday['Nighttime']) then
Hydci wrote: Thursday 06 June 2019 15:34 so i did this in the meantime but i would like to add an option with light if off shut the shutters if on the light wait for the off of the light
Hope this can get you started. If something not clear do not hesitate to ask clarification
        on =
            devices = {'Lightgarden'},
        logging =
            level = domoticz.LOG_DEBUG,
            marker = 'Volets'
    execute = function( dz, item )
        local keyIFTTT = 'xxxxxxxx'
        local salon = 'salon'
        local cuisine = 'cuisine'
        local open = 'ouverture'
        local close = 'fermeture'
        -- domoticz.triggerIFTTT is a native dzVents method for version >= 2.4.18
        local function triggerIFTTT( action, ... ) -- ... accepts 1 - many parms
            for _, room in ipairs({...}) do -- walk through all ... parms
                dz.openURL('https://maker.ifttt.com/trigger/Volet_' .. room .. '_' .. action .. '/with/key/' .. keyIFTTT ) -- call IFTTT webhook
        if item.isDevice and item.state == 'Off' and dz.time.isNightTime then
            triggerIFTTT(close, salon, cuisine )
        elseif dz.time.matchesRule('30 minutes after sunset') then
            triggerIFTTT(open, salon, cuisine )
Hydci
Re: roller shutter and protect light on  [Solved]
Post by Hydci »
thanks for the answer actually script writing and very different from mine so I will have to learn to look at the script blocks to understand them
Hydci
Post by Hydci »
So your script works as you wrote it to me
        on =
            timer     = { '20 minutes after sunset','59 minutes after sunrise' },
            devices = {'Jardin'},
        logging =
            marker = 'Volets'
        if item.isDevice and item.state == 'Off' and dz.time.matchesRule('at nighttime') then
        elseif dz.time.matchesRule('20 minutes after sunset') then --coucher du soleil
        elseif dz.time.matchesRule('59 minutes after sunrise') then -- lever du soleil
so I change for school days and weekends and protect eat garden light on no close shutter after finish eat light off the shutter close Thank you again for your help
        on =
            timer     = { '20 minutes after sunset','at 7:30 on mon,tue,thu,fri','at 8:30 on wed,sat,sun'},
        logging =
            marker = 'Volets'
    execute = function( dz, item, devices )
        local keyIFTTT = 'xxxxx'
        elseif dz.time.matchesRule('20 minutes after sunset') and dz.devices('Jardin').state == 'Off' then
        elseif dz.time.matchesRule('at 7:30 on mon,tue,thu,fri') then
		elseif dz.time.matchesRule('at at 8:30 on wed,sat,sun') then
