dzvent to dialog with telegram
megamarco83
Hi, is it possible to create a dzvent that using notification HTTP (set as telegram bot) can show the status of a light, or switch on/off a light?
- waaren
Re: dzvent to dialog with telegram
To show the status of a light is no problem. But I would not know how telegram could steer a domoticz light. Maybe I don't understand ?megamarco83 wrote: Tuesday 04 June 2019 0:31 Hi, is it possible to create a dzvent that using notification HTTP (set as telegram bot) can show the status of a light, or switch on/off a light?
freijn
- Domoticz version: Stable
THis one works PERFECT !!
https://github.com/squandor/dynamicTele ... 3t2C1Aex3Q
- Query all devices on their status, if you forgot the correct name you can type "light" or "living" and it will generate a list with all
devices containing that string.
- Set all devices like lights or switches.
Great alternative if you do not like to open ports to your domoticz. ( given you "trust" Telegram for the security outbound)
megamarco83
hey ciao, happy to see youwaaren wrote: Tuesday 04 June 2019 1:45To show the status of a light is no problem. But I would not know how telegram could steer a domoticz light. Maybe I don't understand ?megamarco83 wrote: Tuesday 04 June 2019 0:31 Hi, is it possible to create a dzvent that using notification HTTP (set as telegram bot) can show the status of a light, or switch on/off a light?
i hope all doing well.
mmm, my idea was that sending a command to a telegram bot, it could send to domoticz using a json, or it could send a command using dzvents.
how you can see the status of a light using telegram? in the same way we can not switch a light? or set a blind to a decided percentage?
thanks
megamarco83
interesting, thanks.freijn wrote: Tuesday 04 June 2019 8:10 THis one works PERFECT !!
i need to understan better how to set it. i need to create a specific bot in telegram?
p.s.
i try to intsall on my RPI2 with raspian jessie, but not succeed.
pi@raspberrypi:~ $ sudo apt-get install telepot ConfigParser
reading packet....done
creating dependence
reading info...done
E: impossibile find telepot
E: Impossibile find ConfigParser-
megamarco83
pi@raspberrypi:~ $ pip install telepot
-bash: pip: command not found
pi@raspberrypi:~ $- waaren
apt install python3-pipmegamarco83 wrote: Tuesday 04 June 2019 17:06is not working on RPI2 with raspbian stretchCode: Select all
pi@raspberrypi:~ $ pip install telepot -bash: pip: command not found pi@raspberrypi:~ $
apt install python-pip
