Re: Domoticz app 2.0
I just installed latest domoticz beta, now the Web portal works again (didn't work with last stable update, somehow I always have new problems with stable updates... ), but now the app doesn't work anymore. Tried to clear cache and reinstall, but when I try to connect it tells me handshake failed.
Same problem as george
Hi , It is possible clickable notification. Example: when front door has been opened domoticz send me notification with clickable url to my local camera?
Camera are not available weeks ago. It was working fine before.
Cameras work without problem using web UI.
I'm using SSL with a true certificate.
Hello
I bought the app and it works ok
I wanted the same application for a second phone but google wants to pay again.
Do I have to pay for every phone call?
- jvdz
- Domoticz version: 4.107
Phone call or just each phone?
Yes, unless you put it in the Family library and the person of the other phone is part of the Family group.
Jos
Hello
Your info helped thank you very much
As Orsa, I got no more camera view working within domoticz app. Issue appears after a domoticz upgrade to V4.10717.
I also confirm it's now working after a few months of unavailability, thanks to the team.
- galadril
- Domoticz version: latest
Sorry, didn't knew that Domoticz changed they way they handle cookie security..
So it wasn;'t due to a change on the app, but due to a change on the base system ....
But it's fixed now
- galadril
See other comments.. should be fixed
- galadril
Good suggestion, but then I would need more information send from the Domoticz base system to the app in the notification payload..
Let see if someone of the domoticz team could assist on this
- Domoticz version: 12467
Hi app developer(s), Great app. I'm using it daily.
But I do have a problem with the security panel.
Security panel
As you can see it is not clear where to type the passcode. So on my phone, the keyboard does not show, to type the code.
And is there a widget for this panel? I thought I have read something about that here in the forum.
It would be better, for the time being, to have this button linked to the domoticz webpage with the security panel.
Security panel
- Domoticz version: v2020.2
I got a new server adres for my domoticz and wanted to change adres today but it cannot connect.
"Time-out of geen verbinding.
Cleartext HTTP traffic to ### not permitted."
Got the problem of today. Got a update of the app today.
User of the beta app.
Already cleared the cache and reinstalled nothing works.
The light app works fine.
- LouiS22
Same issue: Cleartext HTTP traffic to (IP ADDRESS) not permitted.Rene001 wrote: ↑Thursday 01 August 2019 20:28 I got a new server adres for my domoticz and wanted to change adres today but it cannot connect.
- LouiS22
Fixed!LouiS22 wrote: ↑Thursday 01 August 2019 21:13Same issue: Cleartext HTTP traffic to (IP ADDRESS) not permitted.Rene001 wrote: ↑Thursday 01 August 2019 20:28 I got a new server adres for my domoticz and wanted to change adres today but it cannot connect.
How did you do it ? Fixed update appLouiS22 wrote: ↑Thursday 01 August 2019 21:34Fixed!LouiS22 wrote: ↑Thursday 01 August 2019 21:13Same issue: Cleartext HTTP traffic to (IP ADDRESS) not permitted.Rene001 wrote: ↑Thursday 01 August 2019 20:28 I got a new server adres for my domoticz and wanted to change adres today but it cannot connect.
- LouiS22
I'm on beta, there was an update yesterday evening which seem fixed the issue.
Hi guys,
I've changed the DomoticZ servers and the IP and credentials are different.
I'm also in this case: I can't see the menù. As soon as I open the app it says that it can't reach the server. I've created a nat to reach the server with the old IP, but now it says that the credentials are wrong (I don't remember the old credentials).
Is there a way to get to the settings without crearing the cache (I have to do this to all my colleagues!)
- Domoticz version: 4.10717
Andrex, I too had this problem and the quickest way I could find to re-enter the server details was to uninstall and re-install the app.
I have found though that the App doesn't appear to be connecting to my server, either from within my network or from outside of the network - the error shown in the App is that the credentials are invalid however there is no entry in the Domoticz log to suggest a login has been attempted, the App does show me the correct SSL certificate though! Does anyone have any suggestions of what to try - I have already confirmed the server is available locally and remotely through IPv4 & IPv6.
Fred Boniface
- Dell Optiplex 390 - Ubuntu Linux 18.04.01 LTS - Aeotec Z-Wave USB - RFXtrx433 - Hue Hub 2 - LGTV Plugin -
Hue Bulbs in every room, Temp Sensors on each floor, Temp-Monitoring Fridge, LightWaveRF 'Mood Switches'
Fred Boniface
