hi I am currently woring on a plugin, which gets information from the internet (api.luchtmeetnet.nl). The sensors are updated on that service every hour and sometimes they are an hour behind or of the hook because of calibration.
I got the information in JSON layout and I am able to get the closest station based on lat,lon, but I would like to take over the timestamp in the json in domoticz. I checked the wiki, but it can find it over there. Is it correct that it need to be added or changed on sqlite level?
Any directions would be appreciated.
set timestamp on update
- Domoticz version: mixed
Re: set timestamp on update
(IMHO) Time validity is 'under-developed' in Domoticz.
In JSON-responses you always get ActTime and ServerTime (which are message-related), and sometimes LastUpdate (wnich may be content-related), but that's all ......
Luchtmeetnet.nl also has Timestamp_measured
The last one probably is the timetag you mean.
But also have no idea how to transfer that timevalidity-info into Domoticz' Database, except as a dedicated, separate field for a Customer Sensor.
At least, that is my conclusion after this brainstorm.
And further application is DIY .......
