virtual switch of type lighting 1 and subtype impulse Topic is solved
akamming
Post by akamming »
For testing purposes i need to have a switch of the type "Lighting 1" and the subtype "Impulse". Since i do not own any hardware of this type, i've tried to create a virtual switch. But i noticed the type is always Light/Switch and the subtype is "Switch".
So does anyone know how i can create virtual switch of the type "lighting 1" and the subtype "impulse"?
akamming
Re: virtual switch of type lighting 1 and subtype impulse
Post by akamming »
never mind. This topic can be closed. .. I found the anwser myself…
by adding a virtual switch using the settings/hardware screen i cannot specify the type. however by adding a virtual switch using the "manual light/switch" button on the switches tab i can specify everything i need...
