Variable as trigger OR .checkFirst() in json?
leby
Post by leby »
Hi, I cant get around how to solve my need. I want to update a dummy switch in domoticz from a shelly device and vice versa.
I have to find a way to avoid loop. I have two options that I have tried.
1: A variable that is changed from the shelly
/json.htm?type=command&param=updateuservariable&vname=Shelly_kallaren&vtype=integer&vvalue=0
this works just fine.
Then to update the switch I tried this event but cant get it to update the switch (or I think it is the trigger that never happen)
 variables = {
 	'Shelly_kallaren'
execute = function(domoticz, item, triggerInfo)
if uservariables['Shelly_kallaren'] == '1' then
   domoticz.devices(451).switchOn().checkFirst()
elseif uservariables['Shelly_kallaren'] == '0' then
device.Shelly_kallaren.switchOff().checkFirst()
2: the second way is probably better, less complex and that is to update the dummy switch directly with json. The problem I have here is that I have not fund any equvivilent to the dzvent .checkFirst() in json and without it the looping starts.
I have used
http://192.168.3.10:8080/json.htm?type=command&param=switchlight&idx=451&switchcmd=Off
and that works but I run in to loop. Is there anything like
http://192.168.3.10:8080/json.htm?type=command&param=switchlight&idx=451&switchcmd=Off.checkFirst()
I know that I can use MQTT but I wolud like to use the shelly cloud as well but the memory in the shelly only allows one of them.
Please you all clever people out there, point me in the right direction!
/lennart
Re: Variable as trigger OR .checkFirst() in json?
leby wrote: Friday 24 May 2019 13:34 Hi, I cant get around how to solve my need. I want to update a dummy switch in domoticz from a shelly device and vice versa.
One way of solving this is to have shelly update a domoticz text sensor. That can trigger a dzVents script and have that interpret the text in the sensor and act accordingley.
some questions / remarks.
This url does trigger the attached script. Maybe you are on a very (too) old version ?
You set the var to integer but check against a string
http://pi-3:8080/json.htm?type=command& ... 0&vvalue=1
local scriptVar = "test Variable trigger"
    on = { variables = { 'ff'} } ,
    logging = {
                    level = domoticz.LOG_INFO,
                    marker = scriptVar
    execute = function(dz, item )
        if dz.variables('ff').value == 1 then
            dz.log('============ variable ' .. item.name .. ' triggered to 1',dz.LOG_FORCE)
            dz.log('============ variable ' .. item.name .. ' triggered to 0',dz.LOG_FORCE)
leby
Post by leby »
@warren
Hmm, I run Version: 4.10548 on rpi but perhaps its just that I check it as a string? The variable get set so far it works..
/lennart
leby
Post by leby »
No, it did not help :-( I have changed the url to
http://192.168.3.10:8080/json.htm?type=command&param=updateuservariable&vname=Shelly_kallaren&vtype=2&vvalue=Off
and the script to
	on = { variables = { 'Shelly_kallaren' }
	if uservariables['Shelly_kallaren'] == 'On' then
	elseif uservariables['Shelly_kallaren'] == 'Off' then
The url update the variable as it should so still no problem there but the script does not trigger, I will try to run it on time but then i will get lag in the update.. More suggestions?
/lennart
leby wrote: Friday 24 May 2019 15:32 More suggestions?
A couple...
  • Look in the domoticz logfile
  • Check the syntax of your script. You are using code that is not valid after dzVents 1.1. 2
  • Have a look at the wiki
  • Update to latest stable.
leby
Post by leby »
Cant get my head around this. The script works so far that the variable change and the script runs and wright to the log but no switch change??
		variables = {
			'Shelly*'
	execute = function(dz, variable)
	    local Var_Tvatt = dz.variables(6)
	    local Tvatt = dz.devices(312)
	if Var_Tvatt == 'On' then
	   Tvatt.switchOn()
	   domoticz.log('Tvatt on!')
	elseif  Var_Tvatt == 'Off' then
	        Tvatt.switchOff()
			domoticz.log('Tvatt off!')
Anyone?
/lennart
leby wrote: Friday 24 May 2019 18:06 Cant get my head around this. The script works so far that the variable change and the script runs and wright to the log but no switch change??
Anyone?
Try it with this ?
		variables = {
			'Shelly*'
		local Var_Tvatt = variable.value
		Tvatt.switchOn()
		Tvatt.switchOff()
		domoticz.log('Funny value in Var_Tvatt')
leby
Post by leby »
@warren even if I don't see why it work, it does :-) Many thx!!
/lennart
leby wrote: Friday 24 May 2019 21:45 @warren even if I don't see why it work, it does :-) Many thx!!
What I changed to get it working is that the script now uses the value of the variable (.value); in your last version you tried to compare the variable (which is a table in Lua) with a string.
kimot
Domoticz version: v3.8153
Post by kimot »
I am using ESPeasy on Shelly or Sonoff ( it is ESP8266 based )
Solution is simply.
To switch Shelly from Domoticz dummy switch, I write to switch edit page "On action":
http://192.168.1.102/control?cmd=GPIO,12,1
Off action:
http://192.168.1.102/control?cmd=GPIO,12,0
To report switch state from Shelly to Domoticz simply write "Rules":
SendToHTTP 192.168.1.253,8080,/json.htm?type=command&param=switchlight&idx=19&switchcmd=On
for switch On.
This command switched dummy switch to ON in Domoticz.
It is fact, that Domoticz immediately sends command for switching Shelly on, but it is switched, so it is no problem and gpio setting command not send nothing else from Shelly.
( You must check mark off "Send to Controller" box in relay ESPEASYs device tab, of course )
If you need some complex action when dummy switch switched, you can send custom command from dummy switch instead of GPIO.
This is example for Rules, which toggles Sonoff relay ( and LED ) with each Sonoff button press and report actual state to Domoticz.
From Domoticz you can switch on or off relay by clicking on dashboard and thus sending commands "lamp_on" or "lamp_off".
From other ESPs or other devices you can send "lamp_change" command to change relay state and this new state will be reported to Domoticz too.
No Domoticz variables and scripting needed.
on lamp_on do
    gpio,12,1   //  relay on
    gpio,13,0  //    LED on
endon
on lamp_off do
    gpio,12,0
    gpio,13,1
endon
on lamp_change do
  if [rele#Switch]=1        // if relay is on
    event,lamp_off           // switch it off !
    SendToHTTP 192.168.1.253,8080,/json.htm?type=command&param=switchlight&idx=19&switchcmd=Off        // and send actual state to Domoticz
    event,lamp_on
  endif
endon
on SW01#Switch do          // if button is pressed
  event,lamp_change        // call "lamp_change" event = toggle relay and report to Domoticz
endon
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
