I am getting frequent error messages in Domoticz, such as the following:
2023-06-05 08:35:12.064 Error: SQL Query("UPDATE UserSessions set AuthToken = '1518e7f3279398e62ccff3f3e1babed0', ExpirationDate = '2023-06-05 08:45:12', RemoteHost = '192.168.0.55', LastUpdate = datetime('now', 'localtime') WHERE SessionID = 'f286a97cbe825ce9a2ce73e0f26056b9'") : UNIQUE constraint failed: UserSessions.AuthToken
I am running Domoticz 2022.2 on an RPi 4B under Buster. The RemoteHost (consistently) referred to in these messages is an Apple iMac, used to access the Domoticz webserver.
I understood that this had previously been fixed, in v4.10620:
waaren wrote: Wednesday 24 April 2019 14:12
schumi2004 wrote: Monday 22 April 2019 0:59
zicht wrote: Sunday 07 April 2019 20:18Can anyone point me to the cause of an sql error that i see once or twice a day :
This was caused by the function that creates the SessionID token and the AuthToken when a new session (or API call) enters domoticz. If called in the same second it generated the same values. It's solved in V4.10620 where the same random seed is not generated again when called in the same second.
If not please revert.
