I have connected Sensair S8 sensor to my Raspberry Pi on /dev/serial0 and have run test Python script:
#rpi serial connections
#Python app to run a S8 Sensor
import serial
import time
#RPi pin connections:
#pin 6 GND
#pin 4 5v
#pin 8 TXD: UART data to S8
#pin 10 RXD: UART data from S8
ser = serial.Serial("/dev/serial0",baudrate =9600,timeout = .5)
print " AN-168: Raspberry Pi3 to S8 Via UART\n"
ser.flushInput()
time.sleep(1)
for i in range(1,21): # Print 20 readings from sensor
ser.flushInput()
ser.write("\xFE\x44\x00\x08\x02\x9F\x25")
time.sleep(.5)
resp = ser.read(7)
high = ord(resp[3])
low = ord(resp[4])
co2 = (high*256) + low
print "i = ",i, " CO2 = " +str(co2)
time.sleep(.1)
But how to create Air sensor device in Domoticz? I suppose I need to add new hardware to my domoticz, but which one I should use? How to connect my Sensair S8 that runs on serial to my Domoticz?
