device attribute water  [Solved]
roblom
Post by roblom »
I have a counter that counts my water usage. It indicates the usage in m3.
Is it correct that there isn't an attribute for yet? I see Waterflow in the list but this is for devices that has a L/m unit.
Re: device attribute water
roblom wrote: Sunday 19 May 2019 23:01 I have a counter that counts my water usage. It indicates the usage in m3.
If you defined it as a counter then you will have to use the methods / attributes from this devicetype
roblom
Post by roblom »
Thanks, that did work.
