Turning on Alarm autoomatically - help needed
FrancescoS
- Target OS: -
I am looking for a simple way using dzvents to turn on my alarm system when no presence is detected.
I have found in the forum few examples but they are based on blocky.
Basically I have a couple of motion sensors, + systemalivechecker script to detect if mobile phones are connected to the router, or the TV is switched on.
I would like to switch the alarm on when after i.e. 20 minutes of pinger off and motion sensors no activity.
Can somebody help on this ?
Thanks in advance
Francesco
Thanks in advance
Francesco
- waaren
Re: Turning on Alarm autoomatically - help needed
What does the systemalivechecker steer ? Does it set a uservariable or a virtual switch /sensor ?FrancescoS wrote: Sunday 19 May 2019 21:28 I am looking for a simple way using dzvents to turn on my alarm system when no presence is detected.
And what is domoticz version are you on ?
FrancescoS
- Target OS: -
Systemlivechecker switch on and off a virtual switch.
I am on dzvents 2.4.0
hestia
- Domoticz version: 2022.1
I have a similar use case to put my heater on low when there is nobody at home and reverse.
And I have very poor info if somebody is home, so I need a lag before triggering the heater.
I have one script to set a evaluate if somebody with 4 values: nobody / perhaps nobody (during your 20 min) / somebody / somebody just arrived
Those 4 values allow to trigger other scripts
Note: I started something about a manual mode, but didn't go the end
and another script to pilot my heater
Maybe you could use those scripts for your use case
a dz dzVents Script to evaluate if anybody is at home to trigger something (heater for instance...)
local DOMAIN = 'YaQuelquUn' -- For logging, as you like!
local SBDY_MANUAL = 425 -- Dummy device to force the presence
local SBDY_RESULT= 451 -- Dummy device to store the result
local SBDY_SENSORS = {395, 385, 369} -- All the SENSORS to detect people
local DEVICES = {395, 385, 369, 203} -- All the devices to trigger the script
local l_maxAuto = 3600*2 -- seconds ; time keep on light on when switch on by SENSORS
local l_maxManual = 3600*4 -- seconds ; time keep on light on when switch on by switch / bigger than l_max_SENSORS
local TIME_INTERVAL = 'every 10 minutes' -- Period to check if nobody, l_maxAuto and l_maxManual to take into accoutn
active = true,
logging = {
level = domoticz.LOG_ERROR, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
marker = DOMAIN
devices = DEVICES,
timer = {TIME_INTERVAL},
execute = function(dz, the_device, triggerInfo)
local LOG_LEVEL = dz.LOG_INFO -- LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE
dz.log('*** start ' .. triggerInfo.type , dz.LOG_FORCE)
local l_sensorsOn = false
local l_maxOn = l_maxAuto + l_maxManual -- to be sure it is >
for i, f_sensors in pairs(SBDY_SENSORS) do
if dz.devices(f_sensors).active then
l_sensorsOn = true
-- print('active: ' .. dz.devices(f_sensors).name)
-- print ('lastupdate.secondsAgo: ' .. dz.devices(f_sensors).lastUpdate.secondsAgo)
if l_maxOn > dz.devices(f_sensors).lastUpdate.secondsAgo then
l_maxOn = dz.devices(f_sensors).lastUpdate.secondsAgo
-- print (' < ' .. dz.devices(f_sensors).name)
local l_sbdy = 0
if l_sensorsOn == true then
dz.log('Somebody there!', LOG_LEVEL)
l_sbdy = 20
if l_maxOn < l_maxAuto then
dz.log('Somebody there?', LOG_LEVEL)
l_sbdy = 10
dz.log('Nobody', LOG_LEVEL)
if l_sbdy == 20 then -- Somebody there!
if dz.devices(SBDY_RESULT).level == 0 then -- nobody to somebodymbody
dz.devices(SBDY_RESULT).switchSelector(30)
dz.log('Nobody to somebody there', LOG_LEVEL)
else -- somebody is confirmed
dz.devices(SBDY_RESULT).switchSelector(20) -- other cases to smbody
dz.log('Somebody still there now', LOG_LEVEL)
elseif l_sbdy == 10 then -- Somebody there perhaps!
if dz.devices(SBDY_RESULT).level ~= 10 then
dz.devices(SBDY_RESULT).switchSelector(10)
dz.log('Somebody there perhaps!', LOG_LEVEL)
elseif l_sbdy == 0 then -- Nobody
if dz.devices(SBDY_RESULT).level ~= 0 then
dz.devices(SBDY_RESULT).switchSelector(0)
dz.log('Nobody now', LOG_LEVEL)
end}
-- Pilotage Chaudière
local SBDY_RESULT = 451 -- dummy which knows if anyone at home
local PILOT = 427 -- dummy which knows the boiler mode
local TRIGGER = {451, 427, 346} -- {SBDY_RESULT, PILOT, MODE}
local DEVICE = 347 -- device to pilot -- "Saving" Chaudière ECO
local MODE = 346 -- Off 0 ECS 10 Prog. 20 Vac. 30 On 40
local DOMAIN = 'ChaudièreP' -- For logging, as you like!
local TIME_INTERVAL = 'every 1 hours'
active = true,
logging = {
marker = DOMAIN
devices = TRIGGER,
timer = { TIME_INTERVAL },
local LOG_LEVEL = dz.LOG_FORCE -- LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE
local l_status = 'xx' -- status
dz.log('*** start ' .. triggerInfo.type , dz.LOG_LEVEL)
if dz.devices(SBDY_RESULT).level ~= 0 then -- somebody at home
dz.log('Somebody at home' , dz.LOG_LEVEL)
if dz.devices(PILOT).level == 10 and dz.devices(PILOT).level == 20 then -- Normal / Prog.
dz.devices(DEVICE).switchOff().checkFirst() -- suppression du mode saving
l_status = 'Off'
dz.log('ECO to Off' , dz.LOG_LEVEL)
else -- nobody at home
dz.log('Nobody at home' , dz.LOG_LEVEL)
dz.devices(DEVICE).switchOn().checkFirst() -- mode saving
l_status = 'On'
dz.log('ECO to On' , dz.LOG_LEVEL)
dz.log(dz.devices(DEVICE).name .. ' ' .. dz.devices(DEVICE).state .. ' to ' .. l_status, dz.LOG_FORCE)
- waaren
Could be something likeFrancescoS wrote: Sunday 19 May 2019 23:28 Systemlivechecker switch on and off a virtual switch.
local scriptVar = 'setAlarm'
return
on =
timer = {'every 20 minutes'}
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when script runs OK
marker = scriptVar
execute = function(dz, item)
securityPanelDevice = dz.devices('Domoticz Security Panel') -- change name to reflect your system setup
systemLive = dz.devices('systemLive').active -- change name to your systemLivechecker device
securityIdleMinutes = 20
motionSensors =
'XMotion-2',
'XButton-1',
'Trap bewegingsmelder'
local function noMotion()
for _, name in ipairs(motionSensors) do
if dz.devices(name).lastUpdate.minutesAgo < securityIdleMinutes then
dz.log("Alarm will not be set because device " .. name .. " detected motion ", dz.LOG_DEBUG)
return false
return true
if ( securityPanelDevice.state == dz.SECURITY_DISARMED ) and ( not systemLive ) and noMotion() then
securityPanelDevice.armAway()
dz.log("Security State set to armAway", dz.LOG_DEBUG)
dz.log("No action needed. Security State: " ..securityPanelDevice.state .. "; systemLive switch active: " .. tostring(systemLive), dz.LOG_DEBUG)
}Debian buster, bullseye on RPI-4, Intel NUC.
FrancescoS
- Target OS: -
thank you ! both work like a charm.
Now I have to improve the presence detection algorithm as systemlivechecker is not very reliable.
But this but works pretty fine.
Thanks and regards
Thanks and regards
Gravityz
- Domoticz version: 2025.1
if you have a asus router there might be an easier way to do presence detection
i have a routine running on my router which checks connected mac id's. if none of them are connected i flip a domoticz virtual switch by using a curl command.
so basically if al my devices are off, my girlfriends devices are off and my tv is off i am not at home
FrancescoS
- Target OS: -
Hi thanks,
I am now using this one >
https://easydomoticz.com/forum/viewtopic.php?t=7176
and it works perfectly with both iphone and android
Thx
Thx
snellejellep
- Domoticz version: 2020.2
i have this:
but it does not change the security panel state for me. if i check with the scripts above it matches and should work?
anybody an idea on what i am doing wrong?
devices = {
'is someone home',
'nachtmodus'
execute = function(dz, device)
local home = dz.devices("is someone home")
local nacht = dz.devices("nachtmodus")
local security = dz.devices("Domoticz Security Panel")
if home == "Off" then
security.armAway()
elseif home == "On" and nacht == "Off" then
security.disarm()
elseif home == "On" and nacht == "On" then
security.armHome().afterMin(10)
}anybody an idea on what i am doing wrong?
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
- waaren
Did you check the log ?snellejellep wrote: Monday 03 June 2019 16:55 ... it does not change the security panel state for me. if i check with the scripts above it matches and should work?
You declared home and nacht both as devices (which are tables for Lua) What you need are states (one entry in the device table)
Declare them using
local home = dz.devices("is someone home").state
local nacht = dz.devices("nachtmodus").state
snellejellep
that was the fix, many thanks!!waaren wrote: Monday 03 June 2019 17:09snellejellep wrote: Monday 03 June 2019 16:55 ... it does not change the security panel state for me. if i check with the scripts above it matches and should work?
anybody an idea on what i am doing wrong?Code: Select all
local home = dz.devices("is someone home").state local nacht = dz.devices("nachtmodus").state
