I have alot of no files in my logs after Ive reinstalled and started off fresh.
My install was a few years old from a Rasp B+ that I migated over to a Rasp 3B+ last summer.
I had the same error on my old rasp but figured it was from the migation.
Here are my logs:
2019-05-14 21:24:24.852 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Borta.lua
2019-05-14 21:24:24.852 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/# Devices.lua
2019-05-14 21:24:24.852 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Eye.lua
2019-05-14 21:24:24.852 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Hall.lua
2019-05-14 21:24:24.853 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Hall .Home.lua
2019-05-14 21:24:24.853 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Storarum .Home.lua
2019-05-14 21:24:24.853 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Storarum.lua
2019-05-14 21:24:24.853 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Nicole.lua
2019-05-14 21:24:24.853 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Morning.lua
2019-05-14 21:24:24.854 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Night Light.lua
2019-05-14 21:24:24.854 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Sleep.lua
2019-05-14 21:24:24.854 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Sleep Nicole.lua
2019-05-14 21:24:24.854 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dz Window Lamps.lua
2019-05-14 21:25:00.150 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:00.150 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:00.150 no file './dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/scripts/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/dzVents/runtime/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.150 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.so'
2019-05-14 21:25:00.150 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:00.150 no file './dz Env Storarum /Home.so'
2019-05-14 21:25:00.150 no file '/usr/local/lib/lua/5.2/dz Env Storarum .so'
2019-05-14 21:25:00.150 no file './dz Env Storarum .so'
2019-05-14 21:25:00.157 Status: dzVents: Info: ------ Start internal script: dz Env Hall:, trigger: every 1 minutes
2019-05-14 21:25:00.208 Status: dzVents: Info: ------ Finished dz Env Hall
2019-05-14 21:25:00.208 Status: dzVents: Info: ------ Start internal script: dz Env Nicole:, trigger: every 1 minutes
2019-05-14 21:25:00.211 Status: dzVents: Info: ------ Finished dz Env Nicole
2019-05-14 21:25:00.211 Status: dzVents: Info: ------ Start internal script: dz Env Storarum:, trigger: every 1 minutes
2019-05-14 21:25:00.211 Status: dzVents: Lux 0 to 600
2019-05-14 21:25:00.221 Status: dzVents: Info: ------ Finished dz Env Storarum
2019-05-14 21:25:00.227 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-05-14 21:25:00.921 Status: dzVents: Error (2.4.19): module 'dz Env Hall .Home' not found:
2019-05-14 21:25:00.921 no field package.preload['dz Env Hall .Home']
2019-05-14 21:25:00.921 no file '/usr/local/share/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/usr/local/share/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:00.921 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:00.921 no file './dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/scripts/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/dzVents/runtime/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:00.921 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.so'
2019-05-14 21:25:00.921 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:00.921 no file './dz Env Hall /Home.so'
2019-05-14 21:25:00.921 no file '/usr/local/lib/lua/5.2/dz Env Hall .so'
2019-05-14 21:25:00.921 no file './dz Env Hall .so'
2019-05-14 21:25:00.924 Status: dzVents: Error (2.4.19): module 'dz Env Storarum .Home' not found:
2019-05-14 21:25:00.924 no field package.preload['dz Env Storarum .Home']
2019-05-14 21:25:00.924 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:00.924 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:00.924 no file './dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/scripts/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/dzVents/runtime/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:00.924 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.so'
2019-05-14 21:25:00.924 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:00.924 no file './dz Env Storarum /Home.so'
2019-05-14 21:25:00.924 no file '/usr/local/lib/lua/5.2/dz Env Storarum .so'
2019-05-14 21:25:00.924 no file './dz Env Storarum .so'
2019-05-14 21:25:01.216 (iBox2_1) Color Switch (Hall: Led MI)
2019-05-14 21:25:01.228 (RFXCOM) Lighting 2 (Storarum: Golv)
2019-05-14 21:25:01.306 (RFXCOM) Lighting 2 (Storarum: Tak)
2019-05-14 21:25:01.513 (iDetect) Using password instead of ssh public key authentication for 192.168.1.1 (less secure!)
2019-05-14 21:25:01.720 (iBox2_2) Color Switch (Storarum: Sido RGBCCT)
2019-05-14 21:25:01.336 Status: dzVents: Error (2.4.19): module 'dz Env Hall .Home' not found:
2019-05-14 21:25:01.336 no field package.preload['dz Env Hall .Home']
2019-05-14 21:25:01.336 no file '/usr/local/share/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/usr/local/share/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:01.336 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:01.336 no file './dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/scripts/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/dzVents/runtime/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:01.336 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.so'
2019-05-14 21:25:01.336 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:01.336 no file './dz Env Hall /Home.so'
2019-05-14 21:25:01.336 no file '/usr/local/lib/lua/5.2/dz Env Hall .so'
2019-05-14 21:25:01.336 no file './dz Env Hall .so'
2019-05-14 21:25:01.338 Status: dzVents: Error (2.4.19): module 'dz Env Storarum .Home' not found:
2019-05-14 21:25:01.338 no field package.preload['dz Env Storarum .Home']
2019-05-14 21:25:01.338 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:01.338 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:01.338 no file './dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/scripts/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/dzVents/runtime/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.338 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.so'
2019-05-14 21:25:01.338 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:01.338 no file './dz Env Storarum /Home.so'
2019-05-14 21:25:01.338 no file '/usr/local/lib/lua/5.2/dz Env Storarum .so'
2019-05-14 21:25:01.338 no file './dz Env Storarum .so'
2019-05-14 21:25:01.508 Status: dzVents: Error (2.4.19): module 'dz Env Hall .Home' not found:
2019-05-14 21:25:01.508 no field package.preload['dz Env Hall .Home']
2019-05-14 21:25:01.508 no file '/usr/local/share/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/usr/local/share/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:01.508 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:01.508 no file './dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/scripts/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/dzVents/runtime/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:01.508 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.so'
2019-05-14 21:25:01.508 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:01.508 no file './dz Env Hall /Home.so'
2019-05-14 21:25:01.508 no file '/usr/local/lib/lua/5.2/dz Env Hall .so'
2019-05-14 21:25:01.508 no file './dz Env Hall .so'
2019-05-14 21:25:01.510 Status: dzVents: Error (2.4.19): module 'dz Env Storarum .Home' not found:
2019-05-14 21:25:01.510 no field package.preload['dz Env Storarum .Home']
2019-05-14 21:25:01.510 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:01.510 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:01.510 no file './dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/scripts/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/dzVents/runtime/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.510 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.so'
2019-05-14 21:25:01.510 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:01.510 no file './dz Env Storarum /Home.so'
2019-05-14 21:25:01.510 no file '/usr/local/lib/lua/5.2/dz Env Storarum .so'
2019-05-14 21:25:01.510 no file './dz Env Storarum .so'
2019-05-14 21:25:01.840 Status: dzVents: Error (2.4.19): module 'dz Env Hall .Home' not found:
2019-05-14 21:25:01.840 no field package.preload['dz Env Hall .Home']
2019-05-14 21:25:01.840 no file '/usr/local/share/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/usr/local/share/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:01.840 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:01.840 no file './dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/scripts/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/dzVents/runtime/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:01.840 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.so'
2019-05-14 21:25:01.840 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:01.840 no file './dz Env Hall /Home.so'
2019-05-14 21:25:01.840 no file '/usr/local/lib/lua/5.2/dz Env Hall .so'
2019-05-14 21:25:01.840 no file './dz Env Hall .so'
2019-05-14 21:25:01.843 Status: dzVents: Error (2.4.19): module 'dz Env Storarum .Home' not found:
2019-05-14 21:25:01.843 no field package.preload['dz Env Storarum .Home']
2019-05-14 21:25:01.843 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:01.843 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:01.843 no file './dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/scripts/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/dzVents/runtime/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:01.843 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.so'
2019-05-14 21:25:01.843 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:01.843 no file './dz Env Storarum /Home.so'
2019-05-14 21:25:01.843 no file '/usr/local/lib/lua/5.2/dz Env Storarum .so'
2019-05-14 21:25:01.843 no file './dz Env Storarum .so'
2019-05-14 21:25:02.452 Status: dzVents: Error (2.4.19): module 'dz Env Hall .Home' not found:
2019-05-14 21:25:02.452 no field package.preload['dz Env Hall .Home']
2019-05-14 21:25:02.452 no file '/usr/local/share/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/usr/local/share/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:02.452 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home/init.lua'
2019-05-14 21:25:02.452 no file './dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/scripts/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/dzVents/runtime/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Hall /Home.lua'
2019-05-14 21:25:02.452 no file '/usr/local/lib/lua/5.2/dz Env Hall /Home.so'
2019-05-14 21:25:02.452 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:02.452 no file './dz Env Hall /Home.so'
2019-05-14 21:25:02.452 no file '/usr/local/lib/lua/5.2/dz Env Hall .so'
2019-05-14 21:25:02.452 no file './dz Env Hall .so'
2019-05-14 21:25:02.454 Status: dzVents: Error (2.4.19): module 'dz Env Storarum .Home' not found:
2019-05-14 21:25:02.454 no field package.preload['dz Env Storarum .Home']
2019-05-14 21:25:02.454 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/usr/local/share/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:02.454 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home/init.lua'
2019-05-14 21:25:02.454 no file './dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/scripts/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/dzVents/runtime/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/dzVents/runtime/device-adapters/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/scripts/dzVents/dzVents/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/scripts/dzVents/scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/scripts/dzVents/../lua/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/scripts/dzVents/scripts/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/scripts/dzVents/generated_scripts/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/scripts/dzVents/data/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/home/pi/domoticz/scripts/dzVents/modules/dz Env Storarum /Home.lua'
2019-05-14 21:25:02.454 no file '/usr/local/lib/lua/5.2/dz Env Storarum /Home.so'
2019-05-14 21:25:02.454 no file '/usr/local/lib/lua/5.2/loadall.so'
2019-05-14 21:25:02.454 no file './dz Env Storarum /Home.so'
2019-05-14 21:25:02.454 no file '/usr/local/lib/lua/5.2/dz Env Storarum .so'
2019-05-14 21:25:02.454 no file './dz Env Storarum .so'
But then are all saved in the database and not as files.
All my scripts are working, but its alot of spam to my logfile and its drowning all the info I want to get out of it.
Im no expert at dzVent, should I copy them to the right folders after I modify the scrips?
//Magnus Svensson
