Hello I installed my raspberry pi3+ using this manual domoticz https://www.domoticz.com/wiki/Raspberry_Pi. but I have a sonoff basic with tasmota and I cannot get it connected to domoticz is there a step by step manual from start to end that is updated and working
thanks
newbie on domoticz and sonoff
- Didi
- Domoticz version: 2024.4
Re: newbie on domoticz and sonoff
I'm running a Pi with many Sonoff's. I use the mqtt broker (Mosquitto) to get the status info of the Sonoff's.
Inside the wiki of Tasmota you can find more info about that
Main: RPI-5 / Zigbee / Sonoff / RFLink433 / Camera's / Wifi / Custom Interface / Alarm / GPS / MQTT / MiLight
hjlopes
I done everything that is in the video but there should be missing the something in the raspberry I cannot connect it the raspberry , using a brower it works fine. Yes I will try to install the mosquito then I will get back
Thanks to all
Thanks to all
kimot
- Domoticz version: v3.8153
Try ESPEASY ...
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
QSKONE
1) Mosquitto is instaled and running?
raspberry@pi:~$ mosquitto
If not
https://www.sigmdel.ca/michel/ha/rpi/add_mqtt_en.html
If not
hjlopes
Thanks alot Mosquitto was not working properly I reinstalled my raspberry now I got it working
