Pass2PHP
poudenes
Domoticz version: 3.8993
Re: Pass2PHP
Post by poudenes »
Egregius wrote: Saturday 04 May 2019 11:59 That looks good. Nothing in the error log?
no nothing....
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
I don't understand...
Values in mysql table are updated, that means that pass2php is working.
If the lg function doesn't work it either doesn't have rights to the logfile or the parameters are wrong. In any way the apache or php logfile should show the errors.
poudenes
Re: Pass2PHP
Post by poudenes »
Egregius wrote: Saturday 04 May 2019 12:36 I don't understand...
all .php files have root:root
[code]127.0.1.1:80 127.0.0.1 - - [04/May/2019:12:59:38 +0200] "POST /secure/pass2php.php HTTP/1.1" 200 163 "-" "curl/7.52.1"
127.0.1.1:80 127.0.0.1 - - [04/May/2019:12:59:38 +0200] "POST /secure/pass2php.php HTTP/1.1" 200 149 "-" "curl/7.52.1"
[/code]
-rwxrwxrwx  1 root root 318951 mei  4 13:03 domoticz.log
fetch is working
php _fetchdomoticz.php
logging to dB is working, use phpmyadmin then I see last logs based on current time
When I switch for example Switch-Hall-MEEK I see that its updated in dB as well On states on and Off states off in dB
poudenes
Re: Pass2PHP
Post by poudenes »
im now goto my work... :( no testing for some hours... :geek: :roll:
Trigun
Domoticz version: 4.10717
Re: Pass2PHP
Post by Trigun »
He Guys,
since I am still a bit of php noob, perhaps you guys are willing to help me out with a fairly simple test setup.
I have a motion sensor called "PIR-Bijkeuken" that needs to switch a light called "Bijkeuken" on and off.
I created a php file called: "PIR-Bijkeuken.php"
I entered the following code:
<?php
if($status=='On'){
	sw('Bijkeuken','On');
as for now the switch is not working what am I doing wrong?
I would like the domoticz log file to show if the light is triggered(on and off) and I want the light to go out after 1 minute.
thanks in advance!
Egregius
Re: Pass2PHP
Post by Egregius »
Test that apache can write to the logfile, and that the path to the logfile is correct in the lg function.
Add a lg(‘test’); line at the end of pass2php.
If the test is logged (remember to use tail to watch the logfile, not the domoticz gui).
Move the lg test line inside the device script.
Once that is working move the lg test line inside the if status is on brackets.
Or add diferent lg lines so you can see in the logfile where the script gets.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote: Saturday 04 May 2019 13:57 Test that apache can write to the logfile, and that the path to the logfile is correct in the lg function.
ok, this sounds odd bu there is no domoticz.log in /var/log :shock:
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
Seems like a 'rights" issue. As _fetch is working just add an lg('test'); in there and look at Apache log as well.. tail -f ****Apache.log
Sent from my ONEPLUS A6003 using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Trigun
Re: Pass2PHP
Post by Trigun »
sincze wrote: Saturday 04 May 2019 21:08
ok, i did a full search with winscp but no apache.log or domoticz.log is found
i guess im doing something wrong?
Trigun
Re: Pass2PHP
Post by Trigun »
Trigun wrote: Saturday 04 May 2019 21:52
I added this to the pass2php.php file
is this correct?
2019-05-04 21_54_59-_var_www_html_secure_pass2php.php - Domoticz-NEW! - Editor - WinSCP.png
2019-05-04 21_54_59-_var_www_html_secure_pass2php.php - Domoticz-NEW! - Editor - WinSCP.png (4.03 KiB) Viewed 1365 times
Trigun
Re: Pass2PHP
Post by Trigun »
could it be that /etc/init.d/domoticz.txt is the correct logfile?
sincze
Re: Pass2PHP
Post by sincze »
Trigun wrote:could it be that /etc/init.d/domoticz.txt is the correct logfile?
Normally Apache should have some logging.
/var/log/apache2/access.log
/var/log/apache2/error.log
Is Apache running??
The lg command now in @egregiius code create a separate logfile. I modified it a bit so it shows up in the Domoticz log :)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Trigun
Re: Pass2PHP
Post by Trigun »
sincze wrote: Saturday 04 May 2019 22:20
Is Apache running??
yess I got something and it does show some errors
2019-05-04 22_20_00-_var_log_apache2_error.log - Domoticz-NEW! - Editor - WinSCP.png
2019-05-04 22_20_00-_var_log_apache2_error.log - Domoticz-NEW! - Editor - WinSCP.png (45.13 KiB) Viewed 1364 times
Trigun
Re: Pass2PHP
Post by Trigun »
Trigun wrote: Saturday 04 May 2019 22:22
Is Apache running??
ok, i did a chmod 777 on /var/log. now the error is gone.
i did a tail -f on the apache error log
since i set a lg (‘test’) on the pass2php.php file i can the test line in the apache log
Trigun
Re: Pass2PHP
Post by Trigun »
Trigun wrote: Saturday 04 May 2019 22:39
sincze wrote: Saturday 04 May 2019 22:20 Normally Apache should have some logging.
Is Apache running??
now when I trigger the motion sensor i get the following error.
2019-05-04 22_42_16-_var_www_html_secure_pass2php_PIR-Bijkeuken.php - Domoticz-NEW! - Editor - WinSC.png
2019-05-04 22_42_16-_var_www_html_secure_pass2php_PIR-Bijkeuken.php - Domoticz-NEW! - Editor - WinSC.png (1.66 KiB) Viewed 1361 times
apperantly something is wrong with the script :( but I dont know what?
Trigun
Re: Pass2PHP
Post by Trigun »
Trigun wrote: Saturday 04 May 2019 22:22 yess I got something and it does show some errors
now when I trigger the motion sensor i get the error that something is wrong in line 3
sincze
Re: Pass2PHP
Post by sincze »
You are missing a closing bracket } in your script
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
This website can check your php code and save you a lot of trouble
https://phpcodechecker.com
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Trigun
Re: Pass2PHP
Post by Trigun »
sincze wrote:This website can check your php code and save you a lot of trouble
Whaaaa great it works!!!
The light went onImage
Can you tell me it works to make the light go out automatically?
This was done via a cronjob?
Verzonden vanaf mijn iPad met Tapatalk
sincze
Re: Pass2PHP
Post by sincze »
please have a look on the example files e.g. _cron60.php
Look for an example with function past(60) in it.
And issue the sw function but now off. :)
Dit you implement cron.sh the Domoticz monitor and also used for pass2php crons??
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
