Showing energy costs for double tarrif meter  [Solved]
DaanV
Post by DaanV »
First of all, thank you for this great piece of software. I have been enjoying it a lot already.
At the moment I am trying to get a custom sensor to show my daily gas and energy costs. the complicating factor is that I have a double tariff meter and fixed daily costs.
I have used a script which I found at:
https://ehoco.nl/stroom-gas-en-waterkos ... -domoticz/
The standard script is for a single tariff meter, which is why I played around with the other script found in the comment section of the page.
The thing is, I don't get it to work. I don't get any errors, but I don't see any energy costs either. So, I have the following questions:
1. As Domoticz uses the T1 and T2 tariffs correctly, would it be possible to write a script that reads out the kwh usage of the usage1 and usage2 (i.e., T1 and T2), multiply it with the Costs from the Domoticz 'Meters/Counters' settings and show it in a Custom Sensor?
2. Given the script I have below, how could I add a rule that states that the 'khwPrijs' = 0.21 between 7.00 and 23.00 hours and that the KwhPrijs = 0.19 between 23.00 and 07.00 hours. Using the code from the website I mentioned, doesn't work.
I have spend a full day searching for solutions, but can't seem to find the answer. Your help is appreciated :)
    -- on = { timer   = { "every 5 minutes" }},                    -- script draait iedere 5 minuten
    on = { devices = { "Stroom","Gas","Waterverbruik" }},    -- Verwijder -- aan het begin van deze regel en plaats -- voor bovenstaande regel als
        -- je het script wilt draaien zodra er een nieuw verbruik aan Domoticz is doorgegeven
    execute = function(dz)
        -- Devices
        local vandaagKwh    = dz.devices('Stroom').counterToday         -- Stroommeter device
        local vandaagM3Gas  = dz.devices('Gas').counterToday            -- Gasmeter device
        local StroomKosten  = dz.devices('Stroomkosten')                -- Stroomkosten device
        local GasKosten     = dz.devices('Gaskosten')                   -- Gaskosten device
        -- Eenheidsprijs in Euro's / Kwh - M3
        local kwhPrijs      = 0.21
        local gasM3Prijs    = 0.5836
        -- Vaste kosten in Euro's per dag (zoals vastrecht)
        local kwhPrijsVast      = 0.89000
        local gasM3PrijsVast    = 0.79000
        -- Kosten berekenen
        local kwhKosten      = tonumber(dz.utils.round( (kwhPrijs * vandaagKwh),2) + kwhPrijsVast)--)--:gsub("%.",",")   -- rounded to two decimals and replace dot by comma
        local GasM3Kosten    = tonumber(dz.utils.round( (gasM3Prijs * vandaagM3Gas),2) + gasM3PrijsVast)--)--:gsub("%.",",")
        -- Kosten updaten
          StroomKosten.updateCustomSensor(kwhKosten)
          GasKosten.updateCustomSensor(GasM3Kosten)
Re: Showing energy costs for double tarrif meter
DaanV wrote: Thursday 02 May 2019 11:45 At the moment I am trying to get a custom sensor to show my daily gas and energy costs. the complicating factor is that I have a double tariff meter and fixed daily costs.
Can you try this one ? If something is not clear please feel free to ask for clarification
            put today's electricity and / or today's Gas / and or todays Water usage costs in custom virtual sensor
            Collect information from a P1 device and /or a Gas and /or water meter device
            electricity takes different tariffs and returns (from solarpanels or the likes) into account.
local scriptVar = "dailyEnergyCost"
return  {
            on = { timer = { "every 6 minutes" },           -- using 6 minutes because Stroom and Gas are updated very frequently
                   httpResponses = { scriptVar .. "*" },
        logging = { level   =   domoticz.LOG_DEBUG,    -- change to LOG_ERROR when script executes OK
                    marker  =   sciptVar},
        data =  { energyCosts = { initial = {} }
    execute = function(dz, item)
        --  ********************************************************************* Your changes below this line *************
        -- input Devices
        local electricity = dz.devices("Power") -- P1 device or comment this line
        local gas = dz.devices("Gas") -- Gas meter or comment this line
        local water = dz.devices("Water") -- Water meter or comment this line
        -- outPut Devices
        local electricityCost = dz.devices("electricityCost today") -- define this virtual sensor as Custom sensor or comment this line when not used
        local gasCost = dz.devices("gasCost today")   -- define this virtual sensor as Custom sensor or comment this line when not used
        local waterCost = dz.devices("waterCost today")   -- define this virtual sensor as Custom sensor or comment this line when not used
        -- fixed Transport + contract costs per month in Euro's
        local electricityFixedMonth = 6.31
        local gasFixedMonth = 6.31
        local waterFixedMonth = 6.36
        --      ********************************************************************** No changes below this line **************
        local function getDaysForMonth(month, year)       -- Returns number of days in given or current month
            if month == nil then month = dz.time.month end
            if year == nil then year = dz.time.year end
            return os.date('*t',os.time{year=year,month=month+1,day=0}).day
        local function triggerJSON(url, response, delay)
            local delay = delay or 0
            dz.openURL({    url = url,
                            method = "GET",
                            callback = response}).afterSec(delay)
        local function getCosts(id) -- these costs should be set in domoticz settings
            if next(dz.data.energyCosts) == nil  or dz.data.energyCosts.creationTime < ( dz.time.dDate - dz.time.secondsSinceMidnight ) then
                local costURL = dz.settings['Domoticz url'] .. "/json.htm?param=getcosts&type=command&idx=" .. id
                triggerJSON(costURL, scriptVar .. "_cost")
            return ( next(dz.data.energyCosts) ~= nil )
        local function makeCostTable(t) -- (re)Create costTable if not existing yet; Refreshed at least once a day
            if next( dz.data.energyCosts ) == nil or dz.data.energyCosts.creationTime < ( dz.time.dDate - dz.time.secondsSinceMidnight ) then
                dz.data.energyCosts = t
                local daysThisMonth = getDaysForMonth()
                dz.data.energyCosts.electricityFixedDay  = (electricityFixedMonth or 0 ) / daysThisMonth
                dz.data.energyCosts.gasFixedDay  = (gasFixedMonth or 0 ) / daysThisMonth
                dz.data.energyCosts.waterFixedDay  = (waterFixedMonth or 0 ) / daysThisMonth
                dz.data.energyCosts.creationTime = dz.time.dDate
                dz.data.energyCosts.humanReadableCreationTime = dz.time.raw
        local function updateCustomSensor(device, value)
            local currentValue = device.rawData[1]
            if value ~= tonumber(currentValue) then              -- Update only needed when new value is different fom previous one
                dz.log(device.name .. " ==>> previous value: " .. currentValue .. " ; new value " .. value,dz.LOG_DEBUG)
                device.updateCustomSensor(value)
        local function getEnergy(id)
            local energyURL = dz.settings['Domoticz url'] .. "/json.htm?range=month&sensor=counter&type=graph" ..
                                "&actmonth=" .. dz.time.month ..
                                "&idx=" .. id
                triggerJSON(energyURL, scriptVar .. "_energy")
        local function makeTodaysWaterCosts()
            local waterTodayCost
            if waterCost then
                waterTodaysCost = dz.data.energyCosts.waterFixedDay
                dz.log("WaterFixed: " .. waterTodaysCost,dz.LOG_FORCED)
                waterTodaysCost = waterTodaysCost + ( water.counterToday * dz.data.energyCosts.CostWater / ( dz.data.energyCosts.DividerWater * 100000))
                dz.log("WaterToday: " .. waterTodaysCost,dz.LOG_FORCED)
           return dz.utils.round(waterTodaysCost, 2)
        local function makeTodaysGasCosts()
            local gasTodayCost
            if gasCost then
                gasTodaysCost = dz.data.energyCosts.gasFixedDay * 10000
                gasTodaysCost = gasTodaysCost + gas.counterToday * dz.data.energyCosts.CostGas
           return dz.utils.round(gasTodaysCost / 10000, 2)
        local function makeTodaysElectricityCosts(t)
            local today
            for i, record in ipairs(t) do
                if record.d == dz.time.rawDate then
                    today = i
            local electricityTodaysCost
            if electricityCost then
                electricityTodaysCost = dz.data.energyCosts.electricityFixedDay * 10000
                if today then
                    electricityTodaysCost = electricityTodaysCost + t[today].v * dz.data.energyCosts.CostEnergy
                    electricityTodaysCost = electricityTodaysCost + t[today].v2 * dz.data.energyCosts.CostEnergyT2
                    electricityTodaysCost = electricityTodaysCost - t[today].r1 * dz.data.energyCosts.CostEnergyR1
                    electricityTodaysCost = electricityTodaysCost - t[today].r2 * dz.data.energyCosts.CostEnergyR2
           return dz.utils.round(electricityTodaysCost / 10000,2)
            if device == nil or value == nil then
                return
        if not ( item.isHTTPResponse ) then
            if not ( getCosts(electricity.id) ) then
                -- logWrite("No or outdated costs. Next time the costs will be there")
                return
            -- logWrite("-- costs are there; get energy data")
            getEnergy(electricity.id)
        elseif item.trigger == ( scriptVar .. "_energy" ) then
            updateCustomSensor( electricityCost, makeTodaysElectricityCosts(item.json.result))
            updateCustomSensor( gasCost, makeTodaysGasCosts())
            updateCustomSensor( waterCost, makeTodaysWaterCosts())
            makeCostTable(item.json)
DaanV
Post by DaanV »
Thanks for your swift reply!
This is a familiar script. I have come across it and tested it before. The script seems to be working without errors.
There is just one problem: my fixed costs are calculated per day instead of on a monthly base. I tried to change that in the script, but it turns out my knowledge is not sufficient to change it.
If you could fix that, I would be very grateful.
DaanV wrote: Thursday 02 May 2019 13:41 There is just one problem: my fixed costs are calculated per day instead of on a monthly base. I tried to change that in the script, but it turns out my knowledge is not sufficient to change it.
What are your daily fixed costs for Gas, Power and Water ?
DaanV
Post by DaanV »
the fixed costs per day for electricity are -0,11286
the fixed costs per day for gas are 0,45619
I don't have a smart water meter
DaanV wrote: Thursday 02 May 2019 14:38 the fixed costs per day for electricity are -0,11286
Please have a look at this one. If you use the same script-name make sure you delete <domoticz_dir>/scripts/dzVents/data/ __data_<scriptname.lua> before first run of this new script.
return  {
                    marker  =   scriptVar},
        -- input Devices
        -- outPut Devices
        -- fixed Transport + contract costs per Year / Month or Day in Euro's
        local electricityFixedMonth = 6.31    -- either electricityFixedyear, electricityFixedMonth or electricityFixedDay or comment this line
        local gasFixedYear = 75.72            -- either gasFixedyear, gasFixedMonth or gasFixedDay or comment this line
        local waterFixedDay = 0.2052          -- either waterFixedyear, waterFixedMonth or waterFixedDay or comment this line
        local function getDaysForYear(year)       -- Returns number of days in given or current year
              return (year%4==0 and (year%100~=0 or year%400==0) and 366 or 365)
                            method = "GET",
                local daysThisYear = getDaysForYear()
                dz.data.energyCosts.electricityFixedDay = ( electricityFixedMonth and ( electricityFixedMonth / daysThisMonth )) or
                                                          ( electricityFixedYear  and  ( electricityFixedYear / daysThisYear )) or
                                                            electricityFixedDay
                dz.data.energyCosts.gasFixedDay = ( gasFixedMonth and ( gasFixedMonth / daysThisMonth )) or
                                                  ( gasFixedYear  and  ( gasFixedYear / daysThisYear )) or
                                                    gasFixedDay
                dz.data.energyCosts.waterFixedDay = ( waterFixedMonth and ( waterFixedMonth / daysThisMonth )) or
                                                    ( waterFixedYear  and  ( waterFixedYear / daysThisYear )) or
                                                      waterFixedDay
                                "&idx=" .. id
            if waterCost then
            local gasTodayCost
            if gasCost then
            local today
                    today = i
                if today then
                return
                return
DaanV
Re: Showing energy costs for double tarrif meter  [Solved]
Post by DaanV »
Thanks again. Thanks to your help, I've solved the puzzle. Turns out I was doing a couple of things wrong:
1. There is an option in the script to use the gasFixedDay/elecricityFixedDay command instead of yearly.
2. Apparently the T1 tariff in Domoticz is the nighttime tariff, whereas most energy supplier see T1 as the daytime tariff.
Just to be sure and for other people with similar questions, this is the script I used in the end:
return  {
            on = { timer = { "every 1 minutes" },           -- using 6 minutes because Stroom and Gas are updated very frequently
        -- input Devices
        local electricity = dz.devices("Stroom") -- P1 device or comment this line
    --    local water = dz.devices("Water") -- Water meter or comment this line
        -- outPut Devices
        local electricityCost = dz.devices("Stroomkosten") -- define this virtual sensor as Custom sensor or comment this line when not used
        local gasCost = dz.devices("Gaskosten")   -- define this virtual sensor as Custom sensor or comment this line when not used
    --    local waterCost = dz.devices("waterCost today")   -- define this virtual sensor as Custom sensor or comment this line when not used
        local electricityFixedDay = -0.11286    -- either electricityFixedyear, electricityFixedMonth or electricityFixedDay or comment this line
        local gasFixedDay = 0.45619            -- either gasFixedyear, gasFixedMonth or gasFixedDay or comment this line
    --    local waterFixedDay = 0.2052          -- either waterFixedyear, waterFixedMonth or waterFixedDay or comment this line
                            method = "GET",
                                                            electricityFixedDay
                                                    gasFixedDay
                                                      waterFixedDay
                                "&idx=" .. id
    --    local function makeTodaysWaterCosts()
    --        local waterTodayCost
    --        if waterCost then
    --            waterTodaysCost = dz.data.energyCosts.waterFixedDay
    --            dz.log("WaterFixed: " .. waterTodaysCost,dz.LOG_FORCED)
    --            waterTodaysCost = waterTodaysCost + ( water.counterToday * dz.data.energyCosts.CostWater / ( dz.data.energyCosts.DividerWater * 100000))
    --            dz.log("WaterToday: " .. waterTodaysCost,dz.LOG_FORCED)
    --        end
    --       return dz.utils.round(waterTodaysCost, 2)
    --    end
            local gasTodayCost
            if gasCost then
            local today
                    today = i
                if today then
                return
                return
    --        updateCustomSensor( waterCost, makeTodaysWaterCosts())
DaanV wrote: Thursday 02 May 2019 19:39 I've solved the puzzle. Turns out I was doing a couple of things wrong:
Your welcome. Please note that the only area you need to modify settings is between the lines
If you don't need one or two meters you can just remove or comment the lines there.
The logic in remaining part of the script takes care of the rest.
EddyG
Post by EddyG »
Nice script. :D
I get an error:
2019-05-02 19:48:00.499  Status: dzVents: Error (2.4.18): dailyEnergyCost: An error occured when calling event handler utility_cost
2019-05-02 19:48:00.499  Status: dzVents: Error (2.4.18): dailyEnergyCost: /home/pi/domoticz/dzVents/runtime/Domoticz.lua:172: attempt to perform arithmetic on local 'x' (a nil value)
I have no "Water" yet. I commented 'Water' out.
Any idea?
DaanV
Post by DaanV »
waaren wrote: Thursday 02 May 2019 19:49
Thanks. I had not realised that indeed. I'll correct that straight away.
EddyG wrote: Thursday 02 May 2019 19:53 Nice script. :D
I get an error:
Any idea?
Sorry. A bit over enthusiastic so posted before finishing all tests. Can you try this one ?
            put today's electricity and (optional) today's Gas and (optional) todays Water usage costs in custom virtual sensor
            Collect information from a P1 device and a Gas and water meter device
return  {
        -- When change anything between these lines make sure you remove
        -- <domoticz_dir>/scripts/dzVents/data/ __data_<scriptname.lua> before next run of this script.
        -- input Devices
        local electricity = dz.devices("Power") -- P1 device (required)
        -- outPut Devices
                            method = "GET",
                                                            electricityFixedDay
                                                    gasFixedDay
                                                      waterFixedDay
                                "&idx=" .. id
            if waterCost then
                local waterTodaysCost = dz.data.energyCosts.waterFixedDay
            local gasTodayCost
            if gasCost then
            local today
                    today = i
                if today then
                return
                return
EddyG
Post by EddyG »
Sorry, still same error. Now with debug on.
2019-05-02 22:24:00.488  Status: dzVents: Debug: dailyEnergyCost: ElectricityCost today ==>> previous value: 1.2 ; new value 1.21
2019-05-02 22:24:00.489  Status: dzVents: Error (2.4.18): dailyEnergyCost: An error occured when calling event handler utility_costs
2019-05-02 22:24:00.489  Status: dzVents: Error (2.4.18): dailyEnergyCost: /home/pi/domoticz/scripts/dzVents/scripts/utility_costs.lua:110: attempt to index global 'water' (a nil value)
2019-05-02 22:24:00.489  Status: dzVents: Info:  dailyEnergyCost: ------ Finished utility_costs.lua
I will try to disable all 'water' variables, I only did the first.
P.S. No error if all 'water' variables are disabled.
