Sharing : Afval kalendar in text sensor
Re: Sharing : Afval kalendar in text sensor
Thanks you guys for script works perfect
Since 2 weeks it doenst work anymore
2019-04-10 12:54:00.283 Error: LUA: @AFW Error: Empty result from curl command
When curl the website it also doenst curl (empty)
When curl other website or https://www.mijnafvalwijzer.nl/nl/111AA/6/ it works
- jvdz
- Domoticz version: 4.107
Which script version are you using?
What does the LOG say when you set Debug to True?
You can PM me your postcode/huisnummer info when you want me to do some testing to see what is going on.
Jos
Jos
- Domoticz version: 2022.2
Nice script.
seems to work very good.
2 questions
if i want complete months(eg januari) is this as simple as changing al the strings
local nMON={"januari","februari","maart","april","mei"
i changed april but also the format to mmmmm and then i got April04
with mont mmm it is ok but not sure if this is the way to go.
second question, is there a way to change the color of the text
2 questions
019-04-11 08:45:00.395 Status: LUA: @AFW:Failed loading default JSON.lua... trying /home/pi/domoticz/scripts/lua/JSON.lua
2019-04-11 08:45:00.395 Status: LUA: @AFW:Loaded JSON.lua.
2019-04-11 08:45:00.395 Status: LUA: @AFW:AfvalWijzer module start check
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :tuinafval;14;12
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :dummy2;2;10
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :takken;14;14
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :pmd;14;14
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :restafval;8;45
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :grofvuil;14;12
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :gft;14;12
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :plastic;14;12
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :dummy1;0;1
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :papier;14;12
2019-04-11 08:45:00.395 Status: LUA: @AFW:afvaltype_cfg :kerstbomen;14;12
2019-04-11 08:45:00.395 Status: LUA: AfvalWijzer module start update (v20190112-1653)
2019-04-11 08:45:00.395 Status: LUA: @AFW:=== web update ================================
2019-04-11 08:45:00.426 Error: LUA: @AFW Error: Empty result from curl command
I have tried many differnt postcode but still doenst work for example 9202EM 210
Much thanks for youre help!
- jvdz
Looking fine for me:
You are sure you can access the internet and resolve the domain as you seem to get an empty result back from the curl query?
Could you Email or PM me your script so I can check what the difference is?
Jos
@AFW:Loaded default JSON.lua.
@AFW:Using user config file: alvalwijzerconfig.lua
@AFW:afvaltype_cfg :gft;19;1
@AFW:afvaltype_cfg :pmd;19;1
@AFW:afvaltype_cfg :grofvuil;19;1
@AFW:afvaltype_cfg :restafval;19;1
@AFW:afvaltype_cfg :dummy1;2;10
@AFW:afvaltype_cfg :tuinafval;19;1
@AFW:afvaltype_cfg :plastic;19;1
@AFW:afvaltype_cfg :papier;12;5
@AFW:afvaltype_cfg :kerstbomen;19;1
@AFW:afvaltype_cfg :takken;19;1
@AFW:- start looping through received data -----------------------------------------------------------
@AFW:web_afvaltype:gft web_afvaldate:2019-01-02
@AFW:...gerd-> diff:-99 afvalyear:2019 afvalmonth:01 afvalday:02
@AFW:web_afvaltype:gft web_afvaldate:2019-01-09
@AFW:...gerd-> diff:-92 afvalyear:2019 afvalmonth:01 afvalday:09
@AFW:web_afvaltype:plastic web_afvaldate:2019-01-15
@AFW:...gerd-> diff:-86 afvalyear:2019 afvalmonth:01 afvalday:15
@AFW:web_afvaltype:gft web_afvaldate:2019-01-23
@AFW:...gerd-> diff:-78 afvalyear:2019 afvalmonth:01 afvalday:23
@AFW:web_afvaltype:plastic web_afvaldate:2019-01-29
@AFW:...gerd-> diff:-72 afvalyear:2019 afvalmonth:01 afvalday:29
@AFW:web_afvaltype:gft web_afvaldate:2019-02-06
@AFW:...gerd-> diff:-64 afvalyear:2019 afvalmonth:02 afvalday:06
@AFW:web_afvaltype:plastic web_afvaldate:2019-02-12
@AFW:...gerd-> diff:-58 afvalyear:2019 afvalmonth:02 afvalday:12
@AFW:web_afvaltype:gft web_afvaldate:2019-02-20
@AFW:...gerd-> diff:-50 afvalyear:2019 afvalmonth:02 afvalday:20
@AFW:web_afvaltype:plastic web_afvaldate:2019-02-26
@AFW:...gerd-> diff:-44 afvalyear:2019 afvalmonth:02 afvalday:26
@AFW:web_afvaltype:gft web_afvaldate:2019-03-06
@AFW:...gerd-> diff:-36 afvalyear:2019 afvalmonth:03 afvalday:06
@AFW:web_afvaltype:plastic web_afvaldate:2019-03-12
@AFW:...gerd-> diff:-30 afvalyear:2019 afvalmonth:03 afvalday:12
@AFW:web_afvaltype:gft web_afvaldate:2019-03-20
@AFW:...gerd-> diff:-22 afvalyear:2019 afvalmonth:03 afvalday:20
@AFW:web_afvaltype:plastic web_afvaldate:2019-03-26
@AFW:...gerd-> diff:-16 afvalyear:2019 afvalmonth:03 afvalday:26
@AFW:web_afvaltype:gft web_afvaldate:2019-03-29
@AFW:...gerd-> diff:-13 afvalyear:2019 afvalmonth:03 afvalday:29
@AFW:web_afvaltype:gft web_afvaldate:2019-04-03
@AFW:...gerd-> diff:-8 afvalyear:2019 afvalmonth:04 afvalday:03
@AFW:web_afvaltype:plastic web_afvaldate:2019-04-09
@AFW:...gerd-> diff:-2 afvalyear:2019 afvalmonth:04 afvalday:09
@AFW:web_afvaltype:gft web_afvaldate:2019-04-12
@AFW:...gerd-> diff:1 afvalyear:2019 afvalmonth:04 afvalday:12
@AFW:...Noti-> i_daysdifference:1 afvaltype_cfg[s_afvaltype].daysbefore:1 hour:19 min:1
@AFW:web_afvaltype:plastic web_afvaldate:2019-04-23
@AFW:...gerd-> diff:12 afvalyear:2019 afvalmonth:04 afvalday:23
@AFW:...Noti-> i_daysdifference:12 afvaltype_cfg[s_afvaltype].daysbefore:1 hour:19 min:1
@AFW:-End --------------------------------------------------------------------------------------------
@AFW: Found:12 apr 19 Groente, Fruit en Tuinafval ; 23 apr 19 Plastic en kunststof ;
Jos
I am using windows server with a direct connection trough internet.
I am also using the plug-in buienrader witch works fine to get data from xml.buienrader.nl
- jvdz
It seems you aren't using the latest version of the script. PMed you the latest version with your information which seems to work fine when I tried.
Does that work for you too?
Jos
Jos
- Dutchsea
- Domoticz version: v2023.2
Just picked up "script_time_huisvuil-opzet.lua" version "20190121-2100" from GitHub for my town Hillywood (=Hilversum
The website is for the Gooi en Vechtstreek area (https://inzamelkalender.gad.nl) and also made by "Opzet"
(It was a handy tip to check the bottom of the webpage for this name)
After some some trail and error (I am no coder whatsoever) its works perfectly. My compliments and thanks to Jos, Zicht and other contributors!
Just one question; in the debug mode I get an update in the Domoticz log each minute. Is that expected behaviour?
Raspberry PI 3B on USB drive, Debian version: 12 (bookworm), Domoticz 2024.7
Aeon Z-Wave G5 stick, RFXCOM, Sonof Zigbee 3.0 Dongle plus E, Nefit Easy, Fritzbox, Buienradar, Sonos
- jvdz
Yes, that is why it is called Debug and should only be enabled when debugging. So just set to to False when things work and the update process will only happen the any of the specified times in the table.
cheers,
Jos
thxs! Works also great for city named BussumDutchsea wrote: ↑Friday 12 April 2019 22:17 Just picked up "script_time_huisvuil-opzet.lua" version "20190121-2100" from GitHub for my town Hillywood (=Hilversum)
- Domoticz version: Stable
Jos thanks, it also works well with dar.nl, after some minor changes in the cfg_table.
Jan
Jan
- Domoticz version: 4.9
Script works great but....
Yesterday configured is all and in the evening received the email that today garbage is collected so far so good
Only thing is that I received 13 emails with this message send within a minute
Does anybody have an idea why?
- jvdz
How are you running the script?
There are 2 options why this happens normally:
1. You haven't named it correctly as script_time_xxxxxxx.lua when using files for the time event.
2. you are using the internal LUA script editor and didn't change the event type from ALL to TIME.
Jos
Jos
Hi Jos,
Thanks for the quick response. Wasn't aware I had to change it to time trigger
Did I miss this part? Couldn't find it on the Github page aswell unless its covered by "These Domoticz time scripts".
Anyhow, just changed it. Let's see what happens next week
Cheers!!
Cheers!!
- jvdz
mmm, well the text starts with:
I am not using the internal editor at all myself but have seen that mistake made already so many times in these forums that one could wonder whether the default in that dropdown should be INACTIVE, forcing to make a decision for a eventtype when creating a script event.
Either way, I am always open for proposals to more this more clear! Just create a PullRequest for an update of the readme for better install instructions.
Jos
and the filenames are script_time_restofname.lua, so I though that would be pretty much of a no brainer that these are TIME event script, but can imagine it can be a little difficult when starting this stuff.These Domoticz time scripts will retrieve ....
Jos
- Domoticz version: BETA
Jos
Great work your script!!!
My WAF is very happy with the message she get ............... and i am also
Is there perhaps a option to send the message to more email accounts???
I use now:
Are there very great changes?
So do i need tot update or?
I use now:
ver="20190112-1653"
- jvdz
mmm .... This one is open for a lot of pun remarks but I am assuming you mean wife.
The script uses the standard event SendEmail notification and as far as I know that doesn't support it.:
commandArray['SendEmail'] = notificationtitle .. '#' .. notificationtext .. '#' .. NotificationEmailAdress
Several changes made but no drastic ones. Github does contain the commit log of all changes.Derik wrote: ↑Monday 29 April 2019 21:22 I use now:Are there very great changes?Code: Select all
ver="20190112-1653"
Jos
Nice script.
2 questions
eg, highlight the first on on top in red
2 questions
- jvdz
Just change the array and that should do it:Gravityz wrote: ↑Thursday 02 May 2019 15:38 2 questions
Everything is possible when you put your mind to it, but that requires changing some of the scriptlogic and add this to that first line:
txt = txt..' <font color="red">'..web_afvaldate .. " = " .. web_afvaltype .. "</font>\r\n"
