Lahim
Re: machinon theme
Post by Lahim »
I have same problem.
Freshly installed this theme and "Unable to create or update theme settings uservariable, Try to reset the theme" each time I open Domo web page. Checked ond Chrome and Vivaldi. Chrome with cleared all history.
Nothing helps.
DewGew
Domoticz version: V4.10618
Re: machinon theme
Post by DewGew »
Lahim wrote: Monday 29 April 2019 21:45 I have same problem.
Nothing helps.
Are you running domoticz stable or beta ?
Lahim
Re: machinon theme
Post by Lahim »
Stable
DewGew
Re: machinon theme
Post by DewGew »
Lahim wrote: Tuesday 30 April 2019 8:06Stable
Problem is domoticz API handle uservariable diffrent before V4.10456.
There is a solution here: https://github.com/EdddieN/machinon-dom ... issues/242
Lahim
Re: machinon theme
Post by Lahim »
Ok, I will check it. Thank you.
cmartens75
Re: machinon theme
Post by cmartens75 »
First of all, a big thank you for the creators of this theme! It is really beautiful.
I have a question how I can replace the standard doorbell icon by the Machinon bell icon or another icon. Besides that, I would like to know if there is an icon for displaying gas usage available in the Machinon theme. Now the standard Domoticz icon is being displayed which does not fit with the other icons.
Thanks in advance for your reaction.
Schermafbeelding 2019-04-30 om 22.08.30.png (18.95 KiB) Viewed 3125 times
Schermafbeelding 2019-04-30 om 22.12.38.png (22.72 KiB) Viewed 3125 times
Lahim
Re: machinon theme
Post by Lahim »
@DewGew - yes, now it is working. Thank you.
But I can not understand why most swiches are in "Scene" section.
vamp
Re: machinon theme
Post by vamp »
Hello there,
On Floorplan, if i use a standalone humidity sensor, i see the old icon.
If i use a device that is add more info (temp, humidity, etc..) it show the new icon.
It possible to change the individual sensor to a new icon?
DewGew
Re: machinon theme
Post by DewGew »
Lahim wrote: Tuesday 30 April 2019 23:01 @DewGew - yes, now it is working. Thank you.
How do you mean?? Post a screen dump
DewGew
Re: machinon theme
Post by DewGew »
cmartens75 wrote: Tuesday 30 April 2019 22:18 Hi,
Try latest beta there i new icons
cmartens75
Re: machinon theme
Hi DewGew,
I have installed the beta version of the Machinon theme via:
cd domoticz/www/styles
git clone https://github.com/EdddieN/machinon-domoticz_theme.git machinon-beta
cd machinon-beta
git checkout beta
After that, I have restarted Domoticz. However, the icons have not been changed. Do you have another idea how to solve this?
Lahim
Re: machinon theme
Post by Lahim »
@DewGew
Here it is.
As you see - first 2 are scenes, rest are switches. But only 3 switches are in good section = ""Światła/Przełączniki" (Lights/switches)
DewGew
Re: machinon theme
Post by DewGew »
Lahim wrote: Thursday 02 May 2019 12:17 @DewGew
Here it is.
Strange. If you have same issue on default theme its domoticz issue.
DewGew
Re: machinon theme
Post by DewGew »
cmartens75 wrote: Wednesday 01 May 2019 22:14 Hi DewGew,
cd machinon-beta
git checkout beta
Clear cache and appcache
Lahim
Re: machinon theme
Post by Lahim »
@DewGew - no, on standard themes, everything is OK.
cmartens75
Re: machinon theme
Performed an browser cache and app cache removal, unfortunately without success.
CV8R
Re: machinon theme
Post by CV8R »
Hi All,
Really like the look and feel of the theme but kept getting the messed up presentation of the page per post on Page 1 by landaisbenj » Tuesday 10 July 2018 16:52.
Cache clear, local store etc didn't fix it.
I use Linux on x64 not Pi and run Domoticz with a modified webroot (for reverse proxy). When I remove the modified webroot the page loads correctly.
Cheers
CV8R
Hi, not sure if there has been any solution to this issue when using the modified webroot. I have tried updating stable and beta, cleared cache etc but no resolution.
I am not sure if I should open a github issue?
CV8R
quirk
Re: machinon theme
Post by quirk »
Hi CV8R,
Yes, please report the issue on Github, I'll take a look on it.
David
DewGew
Re: machinon theme
Post by DewGew »
A new great version of machinon theme released today. Version 1.9.0
rron
Re: machinon theme
Post by rron »
Thx,
It works very good. :D
