Since latest beta's i experience domoticz offline when browsing domoticz (mostly when i change from the tab other to the tab with the lamps or weather. This is only happening since approx march. (v_4_10532 ??)
So i am wondering if something changed in domoticz or my router is creating problems. (I do not apply all updates, only once or twice a month)
After deleting browser history on my android, domotics is not longer offline, i have to log in again and it works untill i start to change tabs again and then showing offline again.
Thinking outloud : "it could be browser timeout, sessions mechanism or https mechanisms changed in domoticz ? " It used to work flawless before. or could it be related to : https://www.domoticz.com/forum/viewtop ... =6&t=27268
On local network i use only http and https is only used from outside (to protect my login details a bit more against sniffing)
Https is not testable from local network as my router blockes the loopback. When on connected locally i experience same problems on https when using local ip... A restart of domoticz or the entire hardware does not make any change.
Current version :
Version: 4.10621
Build Hash: 1687198d
Compile Date: 2019-04-27 10:30:16
dzVents Version: 2.4.18
Python Version: 3.5.3 (v3.5.3:1880cb95a742, Jan 16 2017, 15:51:26) [MSC v.1900 32 bit (Intel)]
Any thoughts where to start looking ?
Best regards
Has something changed in HTTPS or user session ? DOmoticz Offline problems
zicht
- Domoticz version: 2023.1+
zicht
Re: Has something changed in HTTPS or user session ? DOmoticz offline problems
Additional testing makes me assuming that domoticz is now giving offline as soon as my mobile ip changes. (Mobile Ip changes some times when traveling) Clearing the browser history and a new login is the solution at that point.zicht wrote: Sunday 28 April 2019 14:16 Hi,
Is this intended behavior ?
