W10 : make domoticz cast to chromecast & GoogleHome
zicht
Domoticz version: 2023.1+
Post by zicht »
** Only for Windows **
Just found this on the web : https://www.rlatour.com/cast/index.html
Installed it and made a lua function :
function Cast(ctext,cdevice,cvolume)
	casttext=""
	cvolume=tonumber(cvolume) if cvolume==0 or cvolume==nil then cvolume=40 end
	if cdevice~=nil then casttext=casttext..' -device "'..cdevice..'"'  end
	if ctext~=nil then casttext=casttext..' -text "'..ctext..'"' end
	casttext=casttext..' -volume '..tostring(cvolume)
	casttext='start /b /realtime Cast.exe -background'..casttext
        print(casttext)
	os.execute(casttext)
Not the niced code, but working.
I used the os.execute and this slows down a lot... so i added "start /b /realtime" to speed things a bit up.
Now a can let google home and other chromecast say things by calling this function.
sorry : I am not a coder and have no clue how to do it on RP or linux, i just try to find sollutions for my needs (and then share it) ...
Brutus
Re: W10 : make domoticz cast to chromecast & GoogleHome
Post by Brutus »
Thnx for sharing.
Will look into this. Already have it running on my Windows Machine Casting to TV and so on.
Looking for some new speakers with google cast in it will be a nice option now!
Greetings.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
zicht
Post by zicht »
Your welcome.
I have got some more experience with it now : it works best to cast to an ip adress. Messages to an ipadress are more reliable being delivered.
The inbuild text2speach is only englisch... You can use google tts to construct an mp3 with your text message in any language :) this way it sounds also like it is comming from google home .. same voice.
Below a partial sample. Message,mp3 is written in the domoticz directory (where nssm.exe is) and cip is the ipholder for the target device.
mkfile='curl -s -G "http://translate.google.com/translate_tts" --data "ie=UTF-8&total=1&idx=0&client=tw-ob&&tl=nl" --data-urlencode "q='..ctext..'" -A "Mozilla" --compressed -o message.mp3'
cfile='C:/PROGRA~2/domoticz/message.mp3'
os.capture(mkfile)
casttext=casttext..' -file '..cfile
casttext='start /b /realtime Cast.exe -background '..cip..casttext
I made and input template in the custom tab, making it possible to send messages to any room i want from the in home domoticz website ...
