Sorry please don,t think I am Lazy ,just cannot work it out .
I have attached some pictures..... Switch page plus Scenepage all icons too rather small.. looks like three columns but one not being used
usually about double the size and no text over lay ,,,
yes checked settings but I just cannot see were the setting is ?? what I need to set
- mutantx
- ohdear2.jpg (156.94 KiB) Viewed 373 times
- ohdear.jpg (283.17 KiB) Viewed 373 times
- waaren
Re: Sorry please don,t think I am Lazy ,just cannot work it out
What do you see when you change your User interface theme to "default" ?mutantx wrote: Friday 26 April 2019 20:52 Switch page plus Scenepage all icons too rather small.. looks like three columns but one not being used
[Setup] [Settings] [System] System Setup -> User Interface: -> Theme: "default"
[Apply settings]
And clear cache when you have done this .
- mutantx
Well switched to default theme and cleared the Cache switched back but the same problem ,,,darn it
I will stay with another theme since it is only happening in that theme ,,,thanks for your comment
